Old 11-10-2020, 11:08 PM #1
TheJokingExplorer TheJokingExplorer is offline
TheJokingExplorer will become famous soon enough
Nightmare lift install
What’s up everyone! I bought and ribs had pro kit with JBA UCA’s. I paid a shop to have them install it because I’m moving to Az and just don’t have the time to do it right now. They seemed to have royalty f*cked this up. UCA boot was in backwards and then they didn’t even use the hardware that JBA supplied with the kit! I’m gonna have another shop fix all this shit but do I need new bushings? Are these ruined now? I know I need to contact contact JBA for new hardware but should I get bushing too?
TheJokingExplorer is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 11:22 PM #2
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I guess they didn't use the inner washers that retain the bushing in the UCA? How many miles since the butcher job? They might be ok if you don't put too many miles on it and get the washer installed properly. The inside of the bushing that the bolt slides through might be damaged though. Do you still have the inner washers?
Worse case scenario is you overnight some bushings from JBA and get it fixed right, or if thats not possible, you roll with the damaged bushings with the inner washers installed and once you get to AZ, you replace the bushings.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 11:46 PM #3
Ive got about five miles on it then I noticed that they screwed this up. I contacted JBA and am going to see if he will overnight me some washers. Hopefully this is an easy fix. No im guessing the ship just threw them out. I will call them in the morning.
Old 11-11-2020, 12:59 AM #4
NotaTRD's Avatar
NotaTRD NotaTRD is offline
NotaTRD will become famous soon enough NotaTRD will become famous soon enough
NotaTRD's Avatar
It would seem UCA installation is not this shop’s forte. Curious if you contacted the shop and called them out on their error?
2017 SW SR5
NotaTRD is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 02:24 AM #5
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
How did they install the UCA bolt backwards too??? It's so damn long that I left it in place as I didn't want to take it out, only to have issues reinserting it lol.
Yeah, that's pretty bad. I'd ask for some serious compensation - you can take this to the BAR for grossly incompetent work.
BAR = bureau of automotive repairs
Good luck!
perf0rmance is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 08:26 AM #6
I will contact them this morning. I noticed it last night when I stopped at the store on my way home.
Old 11-11-2020, 09:14 AM #7
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
If they are a decent shop any costs to correct the situation should be on them. I get things happen but that's a pretty obvious install issue. Is the other side the same way?
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 02:24 PM #8
Contacted them and essentially the guy said he left them out because there was no space for them. Unreal
Old 11-11-2020, 02:54 PM #9
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
You should post the shops info so others can avoid them.
mcat707 is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 03:01 PM #10
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
That is bad. I hate letting other people touch my 4runner. I would like to pay for service sometimes but this stuff always happens. I mean Always! How can anyone look at that install and be happy with it.
The washers didn't fit, OMG mechanic thinks he's an engineer. I think worst case is you'll need new bushings. How'd the alignment go?
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 03:27 PM #11
MaddoxPics's Avatar
MaddoxPics MaddoxPics is offline
MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough
MaddoxPics's Avatar
Is this a respected shop or the cheapest one out there? Either way just awful and one of the dumbest responses I've ever heard. Clearly shouldn't be touching vehicles, not even to do an oil change.
MaddoxPics is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 05:31 PM #12
Luckily I noticed it before I paid for an alignment. Also lucky that JBA is overnighting me new washers and bushings. Now it costed me an extra $127. I’m hoping that it just needs the washers put in and nothing else is damaged. Idk I’m still unsure of what to even do.
Old 11-11-2020, 05:32 PM #13
It had good reviews. (Which clearly means nothing ) I would have done this myself if I had more time and wasn’t getting ready to move across the country.
Old 11-11-2020, 05:51 PM #14
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
JBAs are a ***** to install but that doesn't let the shop off the hook. If you put it on a card I would tell the shop owner to refund you or you're going to file a dispute.
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 06:57 PM #15
Luckily I did put this on a card. They want me to bring it back but I don’t think I can.
hardware , i’m , jba , kit , shop
How many inches of jack stand lift do I need to install lift spacer/bushings? 4Runner4Runner4 4th Gen T4Rs 3 03-21-2020 07:37 PM
Worst Nightmare jahdai42 3rd gen T4Rs 6 10-11-2014 08:59 PM
Nightmare Brake Job KrazedJD 4th Gen T4Rs 10 03-22-2011 11:07 PM
Why NOT to install a body lift or use inferior lift products Sac State 4th Gen T4Rs 6 05-05-2005 03:23 PM
