Old 02-01-2021, 05:39 PM #1
transistor's Avatar
transistor transistor is offline
transistor is on a distinguished road
transistor's Avatar
Grounding point for dual battery?
I'm installing a house battery on the passenger side of my engine bay (connected to the starter battery through a blue sea ml-acr). Would it make more sense to connect the house battery to the grounding point right next to it, or run a cable to the ground on the starter battery?
Also, should I upgrade starter battery body ground wire to the same size I'm using for the positive connection?
transistor is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 07:41 PM #2
ruff4runner's Avatar
ruff4runner ruff4runner is offline
ruff4runner will become famous soon enough ruff4runner will become famous soon enough
There is no need to cabling to the other side of the engine bay, just ground it to the body ground closest to the battery. Just make sure you fuse the positive as close to the terminal as possible. I'm partial to the Blue Sea Systems MRBF Terminal Mount Fuse Blocks as they mount right on the battery terminal insuring that the entire length of cabling is fused.
There is no reason to upgrade the starter battery ground.
Here's my set up. The ground is just next to the auxiliary battery on the fender although everything connected to my auxiliary is grounded to a common busbar and then through a shunt.
Grounding point for dual battery?-20191209_201458-jpeg
2019 TRD ORP with stuff bolted to it and my Alaskan Malamute benevolent overlord, Farley. KN6HZJ
ruff4runner is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 07:42 PM #3
spartacus's Avatar
spartacus's Avatar
If it's isolated system then you can ground it to chasis at the closest spot. Upgrading the ground wire doesn't hurt. Single ground disconnect for both batteries will be more convient when disconnecting power' to' work on the vehicle.
Old 02-01-2021, 07:48 PM #4
umidkusername umidkusername is offline
umidkusername will become famous soon enough
Do you happen to have a write up for your setup?
umidkusername is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 07:51 PM #5
transistor's Avatar
transistor's Avatar
Looks nice! Just ordered those fuse blocks. Thanks
Old 02-02-2021, 06:59 PM #6
Sorry no. I used a Redarc BCDC and there Redarc SBI12 solenoid so I can jump my starter battery. I also used the shrockworks dual battery kit that includes a smog pump relocation kit that moves the air pump to the firewall. Using the shrockworks kit allows you to use the second factory battery mounting tray that 5th gens have. My first dual battery setup, I put the battery in front of the passenger firewall which is not as balanced and is not properly reinforced.
Here is the basic layout.
Grounding point for dual battery?-screen-shot-2021-02-02-2-42-53-pm-png
battery , ground , grounding , point , starter
Dual Battery Setup or Portable Battery Punjabi408 5th gen T4Rs 31 11-16-2020 01:54 AM
Dual Battery Planning, Dual Group 31s mikeySA 3rd gen T4Rs 10 11-04-2017 04:25 PM
Grounding second battery question JSparky 5th gen T4Rs 8 11-28-2016 05:01 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
3rd gen amp/sub issues - grounding point? t4rain Engines / Suspension / Wheels / Tires / Audio / Accessories 10 05-15-2013 08:31 PM
