Originally Posted by SpaceBanana
As the title says, how the heck do I make one.
I recently got my Cali Raised Dual Lightbar and it come with three exposed wires. A ground and two positive, but I have no idea how to wire that to my switchpro.
I was thinking of adding a female pigtail two both positive wires and then using 18awg-3 with male pigtails then running it to the switch.
How the heck do I wire pigtails to one ground and will there be an issue going from 18awg to 14awg(pigtail) and then 14awg(pigtail) to 18awg. Im new to this
By dual light bar I am assuming its dual function such as amber and white lights that can be cut on separately. With that said the wiring to SwitchPro is pretty straight forward. Lets say switches 1 and 2 are open. All you need to do is put the ground under switch one ground, one positive under switch 1 positive, and the other positive on switch 2 positive. That's it! Switch one will cut on white light and switch 2 for amber, depending on what switch the positives are hooked to. If you want it opposite of how its initially hooked up (different light come on with different switch) then just swap the positives.
On the other hand, if by dual light bar you mean two rows of lights and there is a positive for each row, all you have to do is put the ground under switch one ground and the two positives under the positive on switch one. You will be under the 30 amp threshold per switch so its once again simple as it gets!
Sent from my SM-G950U using Tapatalk
