03-08-2021, 06:51 PM
Calling everyone with rotopaX
So I am looking for RotopaX ideas. I am looking to carry fuel and water. I have a LFD rear bumper. Is it possible to put a pax on the outside of the spare tire or iniside. Also do I need the plate or just the 1, 2, 2.25, and 4 Gallon Extension? I would love to use a 2 gallon water and a 4 gallon fuel since I don't think 2 gallons would do much. What do you have? Do you like it? Do you have pictures?
Would this work?
RIGd UltraSwing Rotopax Mounting Bracket - RIGd Supply
Thanks for reading and I look forward to seeing your setup.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
03-08-2021, 07:12 PM
You could probably mount one of the Gamiviti Spare receivers behind/through the spare. Spare Receivers — Gamiviti
03-08-2021, 08:43 PM
Originally Posted by Old Tanker
Thanks I will contact them to see what they have. Since my spare is on the bumper I have no hitch so I would need a plate and then another plate. I wish I knew how to weld I could just make one.
The Build
03-08-2021, 10:02 PM
That doesn't mount to your hitch. It mounts to the tire mount (on your bumper swing-out, not a stock tire mount) and adds a receiver, and you can attach a rotopax mount to that new receiver.
03-08-2021, 11:27 PM
Real Name: Kirk
Real Name: Kirk
Would this work?
The Rigd Supply setup works great. 2200 miles recently with the 4 gallon unit between the tire and the hatch.
Easy on and off, not having to climb on the roof to get 30 pounds of fuel down, solid and simple.
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
03-08-2021, 11:29 PM
I have several RotoPax for my ATV, but not for my 4Runner. They are a great product.
The RIDg swing arm for the spare looks like a great idea. The link you provided is just al bracket to add a RotoPax to the swing arm; you would still need the swing arm. Since the RotoPax sits between the tire and the hatch, you would only be able to have one RotoPax mounted, otherwise it would be too thick. Thus, you could not use the RotoPax extensions to add a second Pax.
The RIDg adapter does not come with the RotoPax mount, so you would need to buy the RotoPax mount ( Rotopax Deluxe Pack Mount | eBay). That would allow you to mount any RotoPax from 1 gallon to 4 gallon (the RIDg picture shows a 4 gallon).
03-09-2021, 03:30 PM
I have a 4 gallon Rotopax on my roof sitting flat. I have the extension and plan on putting a 2 gallon water and a 2 gallon gas tank fit together to go on top of the 4 gallon gas. Currently with only 1 4 gallon gas tank I use the center hole, but once I get the 2 gallon water and 2 gallon gas I will have no choice but to use the outer two holes.
Negatives, because they sit flat I have had some leaks. You will have to take them off especially if you are losing altitude and release the pressure from time to time. Hassle. Second, wind resistance. I haven't noticed much noise since I have a wind fairing on my LFD setup but with a second one added who knows. Gas mileage will also go down.
I do not really want a rear bumper so I keep my spare underneath. I haven't figured out a location to mount the Rotopax except for my roof. I have seen some outside molle panels on the rear window but they are held on with a suction cup on the bottom so not sure about that. There are some ladders you can attach them too but I don't want or need a ladder.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
03-09-2021, 08:55 PM
AMLOR
Got pics?
The Build
03-09-2021, 11:38 PM
Got pics?
RIGd does, RIGd UltraSwing Rotopax Mounting Bracket - RIGd Supply
Dispensing advice 24/7. Usually free and sometimes worthwhile! @4xoa on the gram.
03-10-2021, 07:17 PM
Originally Posted by 1Louder
I don't see that working with the LFD rear bumper.
The Build
03-10-2021, 07:20 PM
Are those the LFD crossbars? I just bought 2 and a wind fairing.
The Build
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Rotopax
swim.bike.run |
5th gen T4Rs |
3 |
12-01-2019 04:23 AM |
Rotopax 4.5 gal.
Off-Camber |
5th gen T4Rs |
1 |
11-30-2019 12:52 AM |
Rotopax
swim.bike.run |
5th gen T4Rs |
26 |
03-21-2018 01:52 AM |
rotopax gas can
kolelt |
Off Topic |
26 |
01-08-2015 10:40 PM |
Rotopax
Buckles |
4th Gen T4Rs |
7 |
09-17-2013 09:10 PM |
