Old 11-16-2020, 07:29 PM #16
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Originally Posted by <<<< View Post
LED panels for dome light that this site sells will short and smoke at best or catch on fire at worst. I lucked out (I guess) because my shorted and melted the heck out the dome light fixture and didn't burn my ride to the ground. I replaced the whole dome light and put single LED bulb in there instead of CH panel after that. I think the problem was spring adapter connector but either way everything was toast and didn't trigger the fuse which tells me issue wasn't just short at posts but rather internal issue with LED Panel circuitry. Close call and I hope to prevent anyone from fire by removing or not ordering those dangerous panels.
Thanks for this
Why am I not surprised
Poorly developed and not tested properly Chinese junk that funds a Communist Army.
There were Chinese LED Helmet and Handlebar lights with lithium batteries for cyclists that were starting peoples houses on fire when they were being charged. I happened to buy a set and found out later. I kept them in a steel container outdoors when I was charging them and storing them.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 08:36 PM #17
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Rich is correct. Beware of crappy LED retrofit automotive bulbs, home AC LED bulbs, and other products from manufacturers you’ve never heard of. They can fail early at best and cause fires in the worst case. It’s not fair to lump them all under the Chinese junk category (even though it seems that’s usually the case). Because almost everything we buy is made in China. But you have to do some research to find a reputable brand.
Another observation: I tried a high power LED dome light for the back seat area once. At night it was so bright it would temporarily blind the passengers when they got in the back seat. I went back to a lower power bulb after that.
Old 11-18-2020, 03:52 AM #18
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Originally Posted by CollinJ View Post
Install seems pretty basic on the arc light, minus having to drill a couple small holes? I don’t have one but I’ve been considering getting one so now you’ve got me wondering how it’s not simple or easy to mess up?
Also, I don’t see the map lights on Meso’s site at all? Just the rear dome light for the 5th Gen
With the arclight map lights and rear hatch upgrades you can pull the whole unit and make the install in the bench and simply snap the fixtures back in place.
The hard part is with the dome light, it doesn't come out or disconnect the way the other lights do. It's practically hardwired in with no disconnect so you have to install it in place on the ceiling. Makes it hard to reach and you get tired holding it up to make all the changes.
nglayton is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 09:11 AM #19
Agent_Outside's Avatar
Agent_Outside Agent_Outside is offline
Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice
So remove a couple screws and pull the whole overhead console down and work on it at a bench. I put mine together at the kitchen table. This is like the people trying to use tape to remove the front dome light bouu look at instead of taking 1-2 minutes to drop the housing and remove the bulb sockets from above as intended.
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 02:22 PM #20
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Archlights version is in stock. I can't say enough good things about it.
Those are pretty nice, but that pushbutton looks like... well, it doesn't look as nice as the rest of the pacakage..
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 02:37 PM #21
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Yeah, the push button turned me off of those. I have the Arc Light white LED panels in the rear and they are amazing though
Old 11-18-2020, 04:15 PM #22
edgesalon's Avatar
edgesalon edgesalon is offline
edgesalon is on a distinguished road
edgesalon's Avatar
thanks for the post and the info glad that you got lucky man, i guess i will wait for now
18 FunRunner
edgesalon is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 12:12 PM #23
GA4RNR's Avatar
GA4RNR GA4RNR is offline
GA4RNR is on a distinguished road
GA4RNR's Avatar
I'll add another comment for the cartrimhome leds. When I bought them the first time, there was a push button that was used to toggle between the red and white lights. One light broke and I ordered a replacement since I had already drilled holes in the lens covers. The replacement no longer incorporates a push button but a relay instead so it now routinely toggles between white and red on it's own. I regret giving them extra money for the replacement and will eventually replace them with something else. I wouldn't recommend them. I replaced my map lights with lasfit lights (very happy with them) and now I'm looking for a replacement for the map and dome. Might try arc, meso or try the lasfits for those as well....
GA4RNR is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 01:04 PM #24
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
I used wonder why people would buy a $40-$45,000 vehicle and then put the cheapest quality Chinese garbage on it, but nowadays you can’t even find quality non-Chinese garbage to put on it…
Hell, half of the “Japanese” parts are made of Chinese components.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
dome , fire , led , light , short
Smoke source for DIY smoke machine? Majindan Off Topic 2 01-11-2019 09:22 AM
Fire! Fire extinguishers are great investments!!! Red88TopangaCa Classic T4Rs 13 07-06-2014 06:41 PM
Please help!! Shorted dome...smoke from steering column!! Ohana5947 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 10-19-2012 04:07 PM
3vze white smoke then blackish grey smoke hoe_nah Classic T4Rs 9 10-15-2012 05:38 PM
Few pics from all the smoke from the fire up here near Fort Collins, CO STRRAYNGE 3rd gen T4Rs 25 05-20-2012 12:35 PM
