11-16-2020, 12:44 PM
1/2" thick aluminum front strut spacer that isn't generic Ebay???
Need to add a little lift to the front and want to throw a strut spacer in. My googlefu is only showing me no name ebay stuff. I realize it is just a piece of aluminum but would prefer something from a reputable company.
Any suggestions?
Anyone run the poly ones from Wheelers Off Road?
11-16-2020, 12:48 PM
Any suggestions?
I put in the Rough Country leveling kit: 2in Suspension Lift Kit for 2010-2019 Toyota 4-Runner 4wd | Rough Country(R)
They are 1" spacer in the front (2" lift) and 1" rear. They work great. Be sure to to a wheel alignment.
11-16-2020, 12:55 PM
Originally Posted by fkheath
That is about an inch too much. I only need a half inch thick plate to get an inch more lift.
11-16-2020, 01:07 PM
I run the 1/4” wheeler poly spacers. They get the job done.
11-16-2020, 01:14 PM
2016 4Runner Trail Premium...Delivered 1/22/2016. Mods: OME Lift, Husky WeatherBeaters, Interior/Exterior LED, Console Vault, AVS Hood and Side Window Deflectors, 275/70/17 BFG KO2, Rigid Dually SAE fog lights, Rigid 20" E2 Hyperspot, Garmin Dash Cam 55, ToyTec HIDs, Aiden James Saber Pro LED high-beam bulbs.
11-16-2020, 02:09 PM
This Toytec spacer gave me 1" lift. TOP1-T Front Top Plate Spacer Kit
11-16-2020, 02:27 PM
Originally Posted by 03_4x4Runner
Do you recall if you had to use their longer studs or were the factory ones long enough???
From my understanding a half inch thick plate shouldn't require new studs but that isn't mentioned in their description at all.
11-16-2020, 02:28 PM
Not what you asked... but it's a cut ring of aluminum. It doesn't matter whether a name brand company sent the dxf file to the laser cut shop or a no-name company did. I'd buy the cheap one. You really can't screw it up unless it doesn't fit where it's supposed to. Almost any hard weatherproof material will work. You could probably even just go buy a cutting board at Costco and cut your own with a jig saw.
11-16-2020, 03:45 PM
I can't answer this. The dealer installed this for me when they replaced my XREAS shocks under warranty.
11-16-2020, 10:40 PM
I used to have those. Longer bolts were required, which means you have to breakdown the coil assembly. Dobinson’s sells a spacer plate, but I think it only gives a 1/2” lift.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
11-16-2020, 11:02 PM
Real Name: Kirk
Real Name: Kirk
Originally Posted by elite130
this!!^^^^
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
11-18-2020, 01:08 AM
Real Name: AJ
Real Name: AJ
Wheelers also makes/sells an aluminum version.
