Old 11-16-2020, 08:01 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Residue Front Wheels
I noticed what appears to be oily residue on the inside barrel of both front wheels. I did my 100k maintenance yesterday which involved new brake pads, rotors, coolant, oil, greasing driveshaft and tire rotation.
The residue was not there yesterday when I put the tires back on. First things I checked were fluid levels: coolant, brake fluid and motor oil appeared fine with no signs of leaks or drop in level from what I could tell. I checked the calipers and brake lines as best as I could without removing the wheels and it all appeared dry. I was very careful when I removed the calipers and used zip ties to hang them up so I wouldn’t risk stretching any brake lines.
Has anybody experienced this? I don’t have time to remove the front wheels at this very moment, but I quickly got under the vehicle and couldn’t see anything out of the ordinary. The only oily substance I could see are the coating from the new rotors. I only cleaned the braking surface of the new rotors, not the internal. I wonder if there was enough oil coating from the inside of the new rotors to do this?
Chilow is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 08:24 PM #2
chester4Run chester4Run is offline
chester4Run is on a distinguished road
New brakes can shed a bit as the machining wears off the rotors. Semi-metallic pads also shed darker dust than ceramic pads. There is probably nothing wrong, but clean out your wheels and drive a bit after your rotors lose the machine marks and see if the problem persists.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 08:40 PM #3
It doesn’t look like brake dust. It’s like oil stains all over the inside barrel of the front wheels. Also checked the CV boots and no signs of leaks from there.
Do you guys spray brake cleaner on the inside of new rotors or just the pad surfaces front and back? That’s the only part that looks oily. I attached a picture and highlighted the area in yellow.
Residue Front Wheels-6198f1d9-efcf-4c3c-b4b9-a449a9a2a630-jpeg
Old 11-17-2020, 11:03 AM #4
I don't usually clean the oil off new rotors at all. I let it wear or evaporate off. It seems unlikely you'd have a brake fluid leak at all four wheels, so if you're seeing the staining on all of them, I still think it's probably shedding/wear-in. To be clear, I'm talking about both the pads and rotors shedding, which is usually a mix of oil, metal, and pad material that sticks to the wheel. I clean it off with water and dish soap, then wax the wheel. The task pairs nicely with tire rotations and beer.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
Old 11-17-2020, 12:05 PM #5
apc9199's Avatar
apc9199 apc9199 is offline
apc9199 will become famous soon enough
apc9199's Avatar
Rotors are cast steel and are dipped in an anti-rust coating (thick oil/grease) to prevent rust while in transit and storage. The area that you highlighted tends to hold a lot of that coating. When the rotors get warm it melts and gets flung outward into the wheel hub. That probably what you're seeing...
apc9199 is offline   Reply With QuoteReply With Quote
Old 11-17-2020, 01:08 PM #6
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
^ this
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 11-17-2020, 01:10 PM #7
That’s reassuring to hear! Thanks all!
brake , front , residue , wheels , yesterday
Should I be concerned about this? Oily residue on left front of engine przm 4th Gen T4Rs 7 05-20-2016 08:57 PM
Best way to remove wax residue? azn toyo 3rd gen T4Rs 9 07-03-2014 09:04 PM
Awk sticker residue or some ish 3rd gen king 3rd gen T4Rs 12 05-27-2012 04:52 PM
Residue from icy/salty roads? Steak Maintenance/Detailing 5 03-09-2009 08:37 PM
Oil residue on inside rear wheels/1998 4runner californiak 3rd gen T4Rs 41 09-05-2007 01:57 PM
