Old 11-18-2020, 09:08 PM #16
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
I wonder if some models of Toyotas in the recall have a panel and some don't. The service guy doesn't know which ones do or don't, and the service manager doesn't have time to educate them or trust them to remember which models do and don't, so they just tell everyone to remove any car seats from the back and then it's never a problem.
I think they'd probably prefer empty fuel tank if possible.
Old 11-18-2020, 09:08 PM #17
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias FŁnke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
I've deleted my 2nd row and I don't remember seeing any sort of fuel pump hatch under the carpet. Wasn't really looking for one tho.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 09:28 PM #18
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
If I recall they can release the electrical connection from a small hatch under the back seat. They actually need to drop the tank to change out the pump. I have a 2014 Trail and they dropped the tank to change mine out.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 11:10 PM #19
Jeremy556's Avatar
Jeremy556's Avatar
I've replaced my fuel pump on my 2011.
Under the rear driver's side seat, there is a small access panel that allows you to disconnect a wiring harness from the top of the fuel tank. It is impossible to replace the fuel pump without dropping the tank or cutting a big hole in the body.
ETA: 4th gen looks exactly the same as 5th gen, so if you are interested, watch this youtube video of someone cutting open the body to get the fuel pump through the cab.
4Runner Fuel Pump Replacement Without Dropping the Fuel Tank - YouTube
This is what the access hole looks like
You have to unscrew that large round plastic piece and remove this very large assembly that contains the fuel level sender and the fuel pump buried within it.
Old 11-18-2020, 11:52 PM #20
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Google found this
https://static.nhtsa.gov/odi/rcl/202...0V012-3310.pdf
1000MPH is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 12:36 AM #21
Saker's Avatar
Saker Saker is online now
Saker's Avatar
When my 2014 SR5 Premium went in for the fuel pump recall, they put it up on the rack, dropped the tank down partially, disconnected the harness, lines, dropped the tank and changed the fuel pump. Went back in reverse order.
Never removed the seat or got into the T4R as it was on the rack when it was replaced.
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Sakerís Ebony Build | Sakerís Previous 2014 Midnight Build | Scuba Mod| Scuba Mod w/ Locker | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Saker is online now   Reply With QuoteReply With Quote
Old 11-19-2020, 12:49 AM #22
Jeremy556's Avatar
Jeremy556's Avatar
After finishing mine up, I planned to do it this way if I ever had to drop the tank again. Easier to reach around the side of the tank than pull out the rear seat and carpet for the access panel.
Without aftermarket skid plates or rusted bolts to deal with, removing the tank is easy, just 2 straps/bolts holding it in place.
Old 11-19-2020, 01:28 AM #23
Saker's Avatar
Saker's Avatar
They sure made it look easy!
Best Regards,
Saker
Old 11-19-2020, 07:44 PM #24
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
So after a few emails I finally got to the bottom of it. The service advisor is obviously an idiot and a liar his boss confirmed the tank was lowered to replace the pump. Upon further inspection in the daylight today it appears that the bolts holding skid plate and straps are freshly over torqued.
Arnezie is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 08:45 PM #25
Jeremy556's Avatar
Jeremy556's Avatar
I would recommend you take them out (one at a time) and apply anti seize to them, especially in MI. I live in the desert and mine welded themselves in place to the point that I had to break off the threaded inserts in the frame to remove them and had to drill/tap new ones in the frame. It's not as strong as the original mounts, but my skid plate could easily support the tank without any straps.
Old 11-19-2020, 10:16 PM #26
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
ugh you guys are making me nervous. I guess I'll look closely in a few weeks when I have her up on the lift to change the oil and rotate the tires.
Had mine done yesterday.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 11:06 PM #27
Mark4runnar's Avatar
Mark4runnar Mark4runnar is offline
Mark4runnar will become famous soon enough
low pressure fuel pump recall
Ok so Iím at my dealer right now getting the fuel pump replaced under the recall and everything Iíve saw shows they have to drop the tank. My service guy just came to get me to remove the car seat in the back seat so they could access from the top ??? When I asked he said they donít drop the tank ???
The dealer did my recall / low pressure fuel pump replacement last week. The dealer (Bristol Toyota) told me that they needed access to the wiring ------under the seat, so I had to empty out the car, and they could only do the job if there was less than 1/3 of fuel in the tank.-------because the DO drop down the entire tank...........claim was it is a 5 hr job, so I had to leave it overnight....took my bike so I could get home--- no loaner car as part of the recall.
As far as I can tell they did the work and did not destroy anything?
Mark4runnar is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 11:42 PM #28
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Did they actually want you to remove the back seat or did you mean to say something else?
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 11:47 PM #29
Arnezie's Avatar
Arnezie's Avatar
The child car seat.
Old 11-19-2020, 11:58 PM #30
The child car seat.
OK - the "child" part wasn't in your opening post.
drop , fuel , pump , seat , tank
Replacement fuel pump Gerdo 3rd gen T4Rs 47 05-17-2016 01:51 AM
95 V6 petrol fuel pump replacement benny1009 Classic T4Rs 0 03-10-2013 08:19 PM
Fuel pump replacement time.... 77'911 Classic T4Rs 5 01-29-2012 02:10 AM
Fuel pump replacement Snowhawke 3rd gen T4Rs 3 12-17-2011 05:30 PM
Fuel Pump replacement chaos!! briansc92 Classic T4Rs 0 09-11-2011 09:20 PM
