Old 11-18-2020, 02:04 PM #1
xcalbr2 xcalbr2 is offline
xcalbr2 will become famous soon enough
Heater issues/cold air issues
Hi all and early Happy Thanksgiving!
I have a 2012 Limited with 122xxx and the automatic dual climate control.
Last winter I had more heat than I could stand with it set on 69. This year seems to be chilly air even on 77/78 and its not that cold out yet.
Feels like I am getting too much cool air in the cabin.
Anything you can recommend I check? I did a forum search for heat and didn't find much that was relevant.
I did have the pass air bag replaced early this spring and not much heater use afterwards. Also had Radio out about a month ago to install accessory mount.
Coolant is not low, flushed out by Toyota early spring, engine temp gauge seems to be running where it should. If turn heat to HI or 80's it will get plenty hot but still seems to me to be a draft on drivers lower.
Thanks
X
xcalbr2 is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 02:22 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I think you have to figure out how the system works. By that I mean systems where you can set a temp in degrees, have control programs that use sensors that tell a computer to make adjustments to keep the temp where you set it. Perhaps previous work like air bag replacement created problems. A connector could have been left off or similar issue could affect how the system functions.
Our SR5 doesn't have the ability to set the temp in degrees, so it's pretty basic. The other causes could be a duct (removed for air bag replacement or other service) or a blockage (check cabin air filter) there have been reports of leaves and other stuff found in the filter area. I'd also scan for codes - sensor failure, etc.
Old 11-18-2020, 04:08 PM #3
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Check the blend door servo.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 04:52 PM #4
hvac
Any more info on that?
I see stuff for 4th gen but not 5th...
Old 11-20-2020, 12:53 PM #5
bump
Bump
any more info/ideas
Old 11-20-2020, 01:02 PM #6
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
stuck thermostat
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 12-07-2021, 12:59 AM #7
Tyjgordon Tyjgordon is offline
Tyjgordon is on a distinguished road
Similar-ish issue
I have a 2011 sr5. Passenger side has no heat. Have the dash broken down and and blend motor seems to be doing everything it’s supposed to do for each blower setting and temp setting. The passenger side isn’t getting any heat from the core it seems but drivers side functions completely normally. And passenger side has cold ac.
Tyjgordon is offline   Reply With QuoteReply With Quote
air , early , heat , heater , spring
Heater issues AK Kilted Guy 3rd gen T4Rs 19 11-01-2017 02:41 PM
A/C then Heater Issues Jbot 3rd gen T4Rs 0 03-19-2017 01:32 AM
Heater issues juicehead666 4th Gen T4Rs 0 11-20-2014 11:23 AM
Heater issues JC41 3rd gen T4Rs 1 10-20-2014 10:58 AM
Heater issues Girlinthedark Classic T4Rs 4 11-26-2012 08:28 PM
