Old 11-19-2020, 01:43 PM #1
frankdux's Avatar
frankdux frankdux is offline
frankdux will become famous soon enough
frankdux's Avatar
Chase Light Wiring Options
I recently picked up a set of S2's to run as chase lights on my 2020 ORP, and would like to avoid running the wires along the roof rack and down the gutter between the a-pillar and windshield.
Anyone here successfully able to find a good path down between the rear hatch and either wire 1.) through the cabin along the side trim or 2.) underneath the truck?
Pictures or additional insight would be greatly appreciated!
Thanks.
2020 4Runner TRD ORP | Southern California | Trail Life
frnkdux.t4r on IG
frankdux is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 01:48 PM #2
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
You can go all the way back and down the hatch, hoping that the wiring never interferes with the hatch closing/opening, since you'll have to run larger gauge wire due to the distance
You can run down the windshield like you said
You can get a marine hull passthrough and run specific wire that's designed to fit it and is waterproof. This would require drilling into the roof and then you'd run the wire down the a-pillars on the inside and through the firewall
llDemonll is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 02:50 PM #3
frankdux's Avatar
frankdux's Avatar
Thanks. I was planning on splicing 14awg wire with wires provided by Baja Designs.
frnkdux.t4r on IG
Old 11-19-2020, 03:55 PM #4
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
Mil-Spec ETFE Insulated Electric Wire (MIL-W-22759/16) | Pegasus Auto Racing Supplies
milspec wiring is where its at. i run mine down the front. but i'm also getting away with much smaller gauge wiring.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 07:19 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I got curious and looked up the S2 power limits for the Sport and Pro... they are a lot more efficient that I thought.
S2 Sport = 12 watts (~1 amp @ 12v) each
S2 Pro = 24 watts (~2 amps @ 12v) each
You can most certainly run smaller wires, or even tap into an existing circuit provided you have the headroom in the circuit.
I could see myself using 18-20awg for this depending on the length of run. Even 22awg would be acceptable for the Sport.
Old 11-19-2020, 07:26 PM #6
Bumbo's Avatar
Bumbo's Avatar
ETFE aka TEFZEL is what is generally used in professional race cars and F1 racing harnesses. Insulation is thin but if high quality, ideal for making harnesses to managing the loom size.
That said, I usually see TXL wire used for most standard automotive applications, especially for most hobby level installs.
Old 11-19-2020, 11:03 PM #7
Stembot Stembot is offline
Stembot will become famous soon enough
I am planning to run a pair of S2s as chase lights on my truck too. However, I got several premade wiring harnesses from BD because I didn't feel like trying to find the part number for the connectors they use. I'm planning to connect to my SwitchPro using an S2 upfitter harness, two 10' S2 extensions, and an S2 splitter. What kind of rack do you have and how are you attaching your lights? I am waiting until at least February for my Gobi to come in before I can install the lights. I'm planning to grab a couple of universal mounting brackets from Axia Alloys Axia Alloys – Axia Alloys.
Sent from my Pixel 2 using Tapatalk
My GearProject Page
Stembot is offline   Reply With QuoteReply With Quote
Old 11-21-2020, 02:12 PM #8
frankdux's Avatar
frankdux's Avatar
I have a Prinsu roof rack – thankfully the rear crossbar offers slots to mount stuff like lights.
But I’m sure you can do something similar with any popular rack brands.
frnkdux.t4r on IG
Old 07-26-2021, 06:51 PM #9
Greeny's Avatar
Greeny Greeny is offline
Real Name: Riley
Greeny is on a distinguished road
Greeny's Avatar
Real Name: Riley
Easiest and cleanest way by far is to go through the weather stripping for the rear hatch. Unsheathe a 2 inch section of the chord to reveal the individual thin gauge power and ground wires. Those wires can be put between the body and the weather-stripping without compromising the seal at all. There is plenty of room between the hatch and the body for chords and any connectors you may have to plug in as well.
All you have to do is run a power wire from the battery up front in to the back of the car, then you can plug in the harness for the chase light in the back with a short harness between the light and the power source and ground.
Can send pictures of my setup if desired.
Greeny is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 04:20 PM #10
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Pics!
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 11:06 PM #11
Greeny's Avatar
Real Name: Riley
Greeny's Avatar
Real Name: Riley
Okay got some pics, mines 3rd gen but the exact same thing can be done with a 5th
Chase/camp light
Sheathed chord from light can be squeezed though this gap. Open and close the tailgate slowly while trying to feed the chord in from edge of the tailgate, you'll find the sweet spot where the gap is big enough to pull it in.
My light came with a deutsch connector pigtail, I strapped it to the tailgate hinge just to prevent it from moving around in there. Plenty of space even when closed. The male plug is from the supplied harness which made things super simple.
Heres where I unsheathed the harness where it goes under the weather stripping.
I have power running from the battery up front to this little box behind the passenger wheel well, the ground is a nearby bolt in the body with the paint sanded away. Inside is just a few positive and negative terminals, that's where my harness is getting its power and ground. You don't need the box, a single wire would do fine, just get power to the trunk somehow, and find a ground that fits your harness.
You can also see the other side of the harness going under the carpet to the front of the car.
Harness wasn't long enough to bring to the dash, so it snakes under the carpet and trim to the B pillar, then under passenger seat to the centre console instead
And this one's pretty self explanatory.. switch lol
Old 07-29-2021, 01:48 AM #12
@Greeny thanks!
Old 12-15-2022, 11:21 PM #13
Lost in trees Lost in trees is offline
Lost in trees is on a distinguished road
Like the setup it’s exactly what I was thinking. How much clearance do you have from the light to the rear spoiler when open?
Thanks in advance!
Lost in trees is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 02:40 AM #14
honda250xtitan honda250xtitan is online now
Thanks in advance!
mine are mounted under the rear cross bar (its a 1x1 so shorter then his) and it's perfect.
honda250xtitan is online now   Reply With QuoteReply With Quote
Old 12-16-2022, 09:27 PM #15
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
I used the rubber wire channel from KC Hilites to make a smooth run along the edge of the windshield.
Universal Wire Hider
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
Old Tanker is offline   Reply With QuoteReply With Quote
chase , find , good , rear , wire
Portable amber chase light setup kboxvegas 5th gen T4Rs 16 09-02-2021 11:30 PM
TV / Home Wiring Options illzoni Off Topic 3 11-11-2019 05:01 AM
Need help with wiring options for 3000W inverter Lewis&Clark 4th Gen T4Rs 13 01-23-2019 12:57 PM
Elocker wiring options help 68ChargerJMP 3rd gen T4Rs 11 08-05-2018 08:34 AM
