Old 06-15-2021, 02:52 PM #1
RoamingScott RoamingScott is offline
RoamingScott is on a distinguished road
Retrofitting garage door overhead button in 2020
All, curious if anyone has found the part number from the premium trims like the Venture/Pro that have the integrated garage door opener button up by the off road controls. I'd love to just swap that panel and gain some functionality on my 2020 Off Road. Thanks!
This is the panel I'd be looking to get:
RoamingScott is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 07:21 PM #2
davem's Avatar
davem davem is offline
davem is on a distinguished road
davem's Avatar
That’s where the buttons are in my 2014 SR5P
'14 4Runner SR5 Premium Bilstien 1500's, Airlift bags, 275 70R 17 Cooper AT3's,Power Stop rotors & brakes, Xenon Depot 9005 Extreme Pro LED, Morimoto H11 2Stroke 2.0, AEM dry flow filter, Magnaflow exhaust, Sprint Booster
'19 Tundra Limited CM, 2.5/1 Bilsteins 5600's, Cooper AT3 275 70 18 on Method NV305's
'12 Subaru Legacy Limited
davem is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 07:47 PM #3
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
FYI the SR5P has it too.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 08:18 PM #4
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
I have the oem garage opener on my runner. Problem, the programmed button is always active. Even if truck is locked, if someone breaks the window and pushes the button... they can gain access to your garage.
Bad design.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 09:00 PM #5
08TxRunner's Avatar
08TxRunner's Avatar
Bad design.
What year? My '20 sure isn't like that and I've tested it. Edit, see that you have a '16.
Old 06-16-2021, 01:30 AM #6
Perhaps it was fixed at a later year ? But yes my 16 limited has this issue. I tested it by locking with the windows down for an hour. I reached in and pressed the garage opener and it opened.
Yours is 2020 and does not do this ? Perhaps I should get the one for the 2020 limited ?
Old 06-16-2021, 10:26 AM #7
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
You'll need a homelink overhead console. I retrofitted one into my Acura, you should be able to swap one into the 4Runner I would think. My SR5P came with it stock also
Old 06-16-2021, 10:30 AM #8
gsla72 gsla72 is offline
gsla72 will become famous soon enough
I thought about going this route for a long time. With the way Toyota wires their vehicles, I was worried that the harness for the homelink features/buttons would be different in my trail that did not originally come with the option. If memory serves, the pigtail for the overhead console may be different between the versions.
I ended up buying a frameless mirror and running a power wire to an add-a-fuse that only works when the key is in the "on" position. This keeps the buttons from being active when the car is parked. My 4R didn't have the auto-dim mirror originally, so I was able to add two features I didn't have with the mirror. If yours already has the auto-dim mirror you may not have to run the power wire all the way to the fuse box.
2017 Super White TRDOR: Bilstein 6112/5160, SSO Roof Rack, RSG Sliders, C4 Hatch Ladder, TRDP Skid Plate, Falken Wildpeak AT3W's, Scanguage II, ARB Diff Breather, SDHQ ABS Skids, Apex Overland Recovery Points, Outgear Solutions LCA Skids, AJT Design Knobs, Weathertechs, TRD Heritage Grille, Black TRDP F/R Valences, Black Emblems, Console Vault, Full RCI Underbelly, FJToyman Shock Skids
gsla72 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 01:07 PM #9
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Bad design.
This has always been the way integrated homelink has worked in my experience. It's always hot, just like a battery powered garage opener remote.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 02:01 PM #10
Seems the later years may have been powered off during lock.
Old 06-17-2021, 02:35 PM #11
IanB's Avatar
IanB's Avatar
If that's the case, it could be in the canbus circuitry that kills power to that circuit, or it could be a different homelink module than earlier models, but my money is on canbus differences. If you look up part #'s for each you can confirm if the homelink is the same.
Old 06-17-2021, 02:43 PM #12
KingPrat's Avatar
KingPrat KingPrat is offline
KingPrat will become famous soon enough
KingPrat's Avatar
Here's your part number. 81260-35690-B0
Quite the hefty price for homelink. $640 for console w/o sunroof w/ homelink.
Current - 2017 TRD ORP. Nautical Blue
Previous - "TRex" - 2004 Sport Edition V8. 2000 SR5 Sport
KingPrat is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 01:58 AM #13
Rottwagon Rottwagon is offline
Rottwagon is on a distinguished road
I have a 2019 trdp. No need for my home link setup. I’d actually rather use that space for aux switches. Can this be swapped out easily to someone that could use it??
Rottwagon is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 02:43 AM #14
StomblinBear StomblinBear is offline
StomblinBear is on a distinguished road
did anyone ever get back to you? i was hoping to do the same.
StomblinBear is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 07:06 PM #15
gakattack gakattack is offline
gakattack will become famous soon enough
As the OEM homelink buttons are always on (at least for most years), I don't recommend going the route that OP is wanting to do. Others have done this too, but here's a much cheaper and very easy route to go with a Subaru mirror:
Easy mod: Gentex HomeLink mirror from a Subaru
2018 ORP, 2001 S4 Tial605, 2001 Maxima, 2013 GS350
gakattack is offline   Reply With QuoteReply With Quote
button , controls , door , garage , road
Tuning button on my new 2020 4Runner....... Easydistracted 5th gen T4Rs 2 09-03-2020 08:37 PM
2020 SR5: Constant Power in Overhead Console? pinegreen 5th gen T4Rs 3 04-12-2020 10:48 AM
Garage door opener button nikon90s General Discussions 0 01-19-2013 12:17 AM
Custom garage door opener button LakeRunr 4th Gen T4Rs 16 09-04-2012 08:37 PM
Garage Door Opener Accessory Button Mod Fracture Engines / Suspension / Wheels / Tires / Audio / Accessories 5 01-29-2012 11:47 PM
