11-19-2020, 05:06 PM
Real Name: Jason
Real Name: Jason
C4 Engine Bay Accessory Tray as ARB Single Compressor Mount
For those that are looking for an affordable ($25) mounting option for their ARB Single Compressor. Just need to drill new mounting holes and paint/coat.
C4 ENGINE BAY ACCESSORY TRAY
2015 SR5 Premium 4x4 Super White
TRD CAI - n-fab Nerf Steps - Philips X-treme LED fogs - XenonDepot Philips HID Low Beam - Interior & Exterior LEDs - Bilstein 5100 All Around: Front 1.75", Rear 1" Cornfed spacers - Prothane/Whiteline front & rear sway bar bushings - General Grabber ATX 265/70/17 - ARB On Board Air
11-19-2020, 05:30 PM
I don't have the dimensions of either, but I do have the Shrockworks bussman mount in this location. Based on that looking to be approximately the same depth below the hood, I'd be skeptical if an air compressor could mount there without clearance issues?
If it works, that's a great price for an underhood air compressor mounting plate!
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
11-19-2020, 05:34 PM
Real Name: Jason
Real Name: Jason
Well it certainly fits without an issue. I have had it installed a week now and nothing hits. I did add a 45 degree elbow so the connection is level, but that's only my OCD, not a clearance issue.
11-20-2020, 06:47 PM
That's awesome, nice find!!! Post up some pics for install ideas when you have a chance!
11-21-2020, 09:39 AM
Here's mine. Did have to drill new holes. Mounted the ARB switch straight to the battery (fuse block) in a sealed project box.
11-21-2020, 12:44 PM
Did the same thing back in April. Had to drill a few holes and the ran an AOB switch into an open factory switch location.
2010 4Runner Trail Edition Shoreline Blue Pearl - Suspension: Front Dobinsons IMS59-700 with C59-302 springs Rear Dobinsons IMS59-50705 with C59-599 springs and front and rear Treaty Oak KDSS spacers / LFD Front Skid Plate / RCI Aluminum Transmission and Transfer Case Skids / RCI Filler Plate / Gobi Stealth Rack / ARB Single Compressor mounted with C4 Accessory Tray / 265/70R17 Ko2
11-21-2020, 02:58 PM
I have been looking to get this also I'm curious if any 2020 owners have tried this and\or can provide pictures. I would need to modify the 2020 relay switch mount, similar to what is shown on Rago's site .
Would this approach work?
2020 ORP Mag Gray w/KDSS
Falken Wildpeak A/T 285/70/17 | Bilstein 5160/6112 | SPC Control Arm | RCI Rock Sliders | Rago Hidden Winch Mount | Badlands APEX 12k Winch | BOSS StrongBoxx Drawer System | BlackVue DR900S-2CH 4K UHD Dual-Lens Dashcam | Orange Boxx Molle rack system | Diode Dynamics Low Beam HID Conversion, High Beam LED Headlight, SS3 LED Fog Light
02-18-2022, 03:49 PM
This tray still holding up for everyone? Price has gone up a little, but still cheaper than a compressor specific mount. Looking to mount a single compressor.
2017 T4R TRD Pro Cement - Dobinsons 2/1" (300/599), IMS 700/701, Air Lift 1000 air bags (60804), Pelfreybilt hidden winch mount, Warn VR8 w/ Amsteel synth, 2021 ORP LED headlights, DD SS3 Sport yellow fogs, CBI steel skid plates, Rough Country 20" LED bar, Gobi stealth no rise w/ ladder, ARTEC sliders, ARB 63qt fridge, Canvasback liners, homemade spare tire hitch carrier, ARB single air compressor w/ Slee mount, bronze TRD Pro wheels
