Old 11-19-2020, 06:55 PM #1
GNB GNB is offline
GNB is on a distinguished road
GNB GNB is offline
2015 TRD Pro- Brake Pad Replacement Question
I need to replace the rear brake pads on my 2015 4Runner TRD.
The rotors look fine, no vibration , etc.
Is it necessary to have the rotors turned, or can I simply replace the brake pads?
I had no issues just replacing the pads on my prior Toyota Sequoia.
Thanks
GNB is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 11:36 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Just replace the pads. No need to machine the rotors if they are smooth and not warped. I never replace/machine rotors unless there is a good reason.
fkheath is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 11:38 PM #3
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Agree.
Always amazed by people who say you must change rotors every time you change pads.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 10:17 AM #4
GNB GNB is offline
GNB GNB is offline
Thanks for the replies !! This has been my approach in the past .
I've done brakes on several cars over the years. Besides new pads, do I need to purchase any other hardware , or just replace / re-use the shims and pins, etc?
Thanks !
Old 11-20-2020, 11:28 AM #5
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Toyota has two different pads. Make sure you get the OEM's. The Ones they use on their brake jobs are a different Toyota number and have seen several posts on here that they squeal and don't last. Here is the part number I use, I have a 2012 TE. I am on my 3rd set with 210,000 miles. I replaced my rotors as a precaution after my first set of pads went 100k. 04466-60140 look at post 6 here Squeaking when breaking.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 11:45 AM #6
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Thanks !
You can clean up and reuse if they aren't bad. Sometimes pads already come with a new hardware kit. No idea if the Toyota ones do.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 11:56 AM #7
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Toyota dealer in Ft. Collins did this to me after I insisted on OEM Toyota and sold me these POS pads. I'm squeaking like a MUNI bus and can't wait until the fronts wear down enough to replace all 4.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 01:50 PM #8
Surfinguru Surfinguru is offline
Surfinguru is on a distinguished road
I went with these. Search via Amazon:
Toyota Genuine Parts 446660140 Rear Brake Pad Set
As noted in the comments, the parts did come in Toyota/Lexus branded box. No issues/squeaks etc.
2024 Ice Cap | TRD ORP | KDSS | TRD Pro Wheels | BFG KO2's 285/70/17
Surfinguru is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 02:52 PM #9
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
I'll jump on the brake pad boat, since I literally just replaced them a couple fo weeks ago
I used OEM pads and shims, and caliper grease (OE, SuperLube, CRC, whatever you want as long as it is brake grease) Model year doesn't matter as long as it is a 5th gen.
Fronts:
Pads: 04465-60320
Shims: 04945-60090
Rear:
Pads: 04466-60140
Shims: 04946-60141
OE Caliper grease: 08887-80609
As others had mentioned if your rotors still look good, smooth, not warped and are within wear spec:
Front:
Standard thickness :
32.0 mm (1.26 in.)
Minimum thickness :
29.0 mm (1.14 in.)
Rear:
18.0 mm (0.709 in.)
Minimum thickness :
16.0 mm (0.630 in.)
Then leave them
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 09:00 PM #10
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Fronts:
Pads: 04465-60320
Shims: 04945-60090
Rear:
Pads: 04466-60140
Shims: 04946-60141
Front:
32.0 mm (1.26 in.)
Minimum thickness :
29.0 mm (1.14 in.)
Rear:
18.0 mm (0.709 in.)
Minimum thickness :
16.0 mm (0.630 in.)
Then leave them
Did you need any additional clips for the rears?
I see some in tech drawings but I haven’t needed to replace my brakes yet so I could not confirm.
Here’s a link to what I mean.
2010 Toyota 4Runner Trail Disc Brake Anti-Rattle Clip Set (Front, Rear) - 0494722050 | Sparks Toyota, Myrtle Beach SC
I got replacement pins and springs for the fronts but still had this question on the rears.
1000MPH is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 11:00 PM #11
jrandom's Avatar
jrandom's Avatar
This is the first pad change I have done on the truck since it was new, so everything was OE. The set of OE rear pads had two in the box, the old pads had only two, IIRC the were on the dif side pad and bottom (obviously double check when you pull them)
2013 TE w/ KDSS Nav
Old 11-21-2020, 01:06 AM #12
1000MPH's Avatar
1000MPH's Avatar
Thanks.
Those should be the pad wear indicators.
I did find my answer in this DIY article where he calls them “brake pad abutment clips”.
Toyota 4Runner Rear Disc Brake Pads Replacement Guide - 2010 To 2016 Model Years - Picture Illustrated Automotive Maintenance DIY Instructions
I’m going to order a set of the parts I linked to above just in case I need them.
Old 11-21-2020, 01:18 AM #13
1000MPH's Avatar
1000MPH's Avatar
By the way...
Just noticed that Toyota Parts and Accessories - Official Online Store Currently has free shipping on $75 or more. Order those rotors and other heavy stuff now!
Old 11-21-2020, 01:19 AM #14
jrandom's Avatar
jrandom's Avatar
Yep, you’re absolutely correct. I just cleaned those with a stiff bristle brush and brake cleaner, didn’t even remove them, apart from brake dust they looked nearly new. Definitely nothing wrong with replacing them while it apart, pretty minimal cost. Lol I would have had I known
2013 TE w/ KDSS Nav
Old 02-01-2023, 06:19 PM #15
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
You can identify the Toyota brake pads by color.
The low end ones are all black.
The factory OEM brakes are blue. The back of the front pads are blue and the rear pads have a blue stripe.
The TRD pads are red around the edges.
Lexington is offline   Reply With QuoteReply With Quote
brake , pads , replace , rotors , trd
brake line replacement with lift question? yotachief 3rd gen T4Rs 1 12-28-2013 09:50 PM
brake rotor and pad replacement question 994runna 3rd gen T4Rs 6 11-04-2012 12:42 AM
Brake Rotor replacement question huckleberry668 Maintenance/Detailing 12 10-01-2007 07:18 PM
Brake replacement, ABS question fun4runner Maintenance/Detailing 2 08-13-2007 01:35 PM
