11-19-2020, 06:55 PM
2015 TRD Pro- Brake Pad Replacement Question
I need to replace the rear brake pads on my 2015 4Runner TRD.
The rotors look fine, no vibration , etc.
Is it necessary to have the rotors turned, or can I simply replace the brake pads?
I had no issues just replacing the pads on my prior Toyota Sequoia.
Thanks
11-19-2020, 11:36 PM
Just replace the pads. No need to machine the rotors if they are smooth and not warped. I never replace/machine rotors unless there is a good reason.
11-19-2020, 11:38 PM
Agree.
Always amazed by people who say you must change rotors every time you change pads.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
11-20-2020, 10:17 AM
Thanks for the replies !! This has been my approach in the past .
I've done brakes on several cars over the years. Besides new pads, do I need to purchase any other hardware , or just replace / re-use the shims and pins, etc?
Thanks !
11-20-2020, 11:28 AM
Toyota has two different pads. Make sure you get the OEM's. The Ones they use on their brake jobs are a different Toyota number and have seen several posts on here that they squeal and don't last. Here is the part number I use, I have a 2012 TE. I am on my 3rd set with 210,000 miles. I replaced my rotors as a precaution after my first set of pads went 100k. 04466-60140 look at post 6 here Squeaking when breaking.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
11-20-2020, 11:45 AM
Thanks !
You can clean up and reuse if they aren't bad. Sometimes pads already come with a new hardware kit. No idea if the Toyota ones do.
11-20-2020, 11:56 AM
Real Name: Sparky
Real Name: Sparky
Toyota dealer in Ft. Collins did this to me after I insisted on OEM Toyota and sold me these POS pads. I'm squeaking like a MUNI bus and can't wait until the fronts wear down enough to replace all 4.
Old and (c)rusty.
11-20-2020, 01:50 PM
I went with these. Search via Amazon:
Toyota Genuine Parts 446660140 Rear Brake Pad Set
As noted in the comments, the parts did come in Toyota/Lexus branded box. No issues/squeaks etc.
2017 MGM TRD Off Road Premium | KDSS | TRD Pro Wheels | BFG KO2's 265/70/17 | Xenon Depot 5k HIDs
11-20-2020, 02:52 PM
I'll jump on the brake pad boat, since I literally just replaced them a couple fo weeks ago
I used OEM pads and shims, and caliper grease (OE, SuperLube, CRC, whatever you want as long as it is brake grease) Model year doesn't matter as long as it is a 5th gen.
Fronts:
Pads: 04465-60320
Shims: 04945-60090
Rear:
Pads: 04466-60140
Shims: 04946-60141
OE Caliper grease: 08887-80609
As others had mentioned if your rotors still look good, smooth, not warped and are within wear spec:
Front:
Standard thickness :
32.0 mm (1.26 in.)
Minimum thickness :
29.0 mm (1.14 in.)
Rear:
18.0 mm (0.709 in.)
Minimum thickness :
16.0 mm (0.630 in.)
Then leave them
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
11-20-2020, 09:00 PM
Fronts:
Pads: 04465-60320
Shims: 04945-60090
Rear:
Pads: 04466-60140
Shims: 04946-60141
Front:
32.0 mm (1.26 in.)
Minimum thickness :
29.0 mm (1.14 in.)
Rear:
18.0 mm (0.709 in.)
Minimum thickness :
16.0 mm (0.630 in.)
Then leave them
Did you need any additional clips for the rears?
I see some in tech drawings but I haven’t needed to replace my brakes yet so I could not confirm.
Here’s a link to what I mean.
2010 Toyota 4Runner Trail Disc Brake Anti-Rattle Clip Set (Front, Rear) - 0494722050 | Sparks Toyota, Myrtle Beach SC
I got replacement pins and springs for the fronts but still had this question on the rears.
11-20-2020, 11:00 PM
Originally Posted by 1000MPH
This is the first pad change I have done on the truck since it was new, so everything was OE. The set of OE rear pads had two in the box, the old pads had only two, IIRC the were on the dif side pad and bottom (obviously double check when you pull them)
2013 TE w/ KDSS Nav
11-21-2020, 01:06 AM
Thanks.
Those should be the pad wear indicators.
I did find my answer in this DIY article where he calls them “brake pad abutment clips”.
Toyota 4Runner Rear Disc Brake Pads Replacement Guide - 2010 To 2016 Model Years - Picture Illustrated Automotive Maintenance DIY Instructions
I’m going to order a set of the parts I linked to above just in case I need them.
11-21-2020, 01:18 AM
By the way...
Just noticed that Toyota Parts and Accessories - Official Online Store Currently has free shipping on $75 or more. Order those rotors and other heavy stuff now!
11-21-2020, 01:19 AM
Yep, you’re absolutely correct. I just cleaned those with a stiff bristle brush and brake cleaner, didn’t even remove them, apart from brake dust they looked nearly new. Definitely nothing wrong with replacing them while it apart, pretty minimal cost. Lol I would have had I known
2013 TE w/ KDSS Nav
02-01-2023, 06:19 PM
You can identify the Toyota brake pads by color.
The low end ones are all black.
The factory OEM brakes are blue. The back of the front pads are blue and the rear pads have a blue stripe.
The TRD pads are red around the edges.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
