Old 11-21-2020, 06:15 PM #16
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Originally Posted by T4R_Canuck View Post
I like this!! Yes, way better idea.
I'm going to look into this idea a little more.
Any issues with snow and ice freezing the door shut or getting into the plug?
Sent from my SM-G960W using Tapatalk
Never had an issue although I’m in NC so can’t speak to climates with a lot of snow. I’ve had it like this for a few years now and no issues through any of the few snow and ice events we get here.
I tabbed a little rubber cap for the extension cord to keep rain out, but even without it it’s never been an issue
jhguth is offline   Reply With QuoteReply With Quote
Old 11-21-2020, 06:19 PM #17
And the noco charger itself I mounted on the plastic lid for the fuse box, it’s been there for years with no issue.
Old 11-21-2020, 09:34 PM #18
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
Well.. It's done. I still have to zip tie some wires and put a wire loom on to protect the positive and ground cable, but it is operational.
After some consideration, I choose the removable panel on the cowl. The plug gives me confidence that water won't be an issue, the location worked great for mounting the charger within reach and it looks clean and stealth when not in use.
If I ever choose to sell the vehicle, or just remove the charger, I can change that panel in the cowl in about 60 seconds and it'll look stock again.
Thanks to everyone for the awesome feedback and ideas.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
Old 11-22-2020, 11:12 AM #19
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Nice, looks good Ah I see you picked up one of the new models. That things is tiny compared to mine! Maybe time to look into an upgrade
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 11-22-2020, 12:22 PM #20
Thanks man. Yeah, I got the Noco Genius 2D on sale for $50 Cdn, normally $69. They are on sale direct from Noco for $39 USD right now. Its super small and took about 2 minutes to mount. Time will tell how well it works.
Old 11-22-2020, 12:45 PM #21
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Good job on the install. I have the NOCO 5 Amp but just use it occasionally on the bench. As long as you’re tending to your battery, take a look at the water level in each cell. My 3 year old original Panasonic needed a little water (distilled) in the cells closest to the pos and neg terminals.
Old 11-22-2020, 12:57 PM #22
Thank you for your input on the process.
I've got an Odessey AGM battery on order, just getting the charger installed in advance before the weather turns nasty cold. I'll be using this Costco battery for other purposes down the road. It hasn't been maintaining its voltage overly well since I bought the 4Runner, so I decided to make the jump to an AGM before winter.
I also keep a NOCO GB40 jump pack in my daily back pack just in case.
Until a month ago I'd never owned a NOCO product, now I've got 3, so I guess I'll get to field test some products.
Old 11-22-2020, 04:15 PM #23
KP Texan KP Texan is offline
KP Texan has a spectacular aura about KP Texan has a spectacular aura about
Looks like you got it figured out, but I went this route for my 4A battery tender (page 3 shows it):
Battery Tender for 4Runner?
I 3D printed a power port that mounts directly in my grille, with no cutting needed. The port also allows me to plug my little Viair compressor in directly to power, rather than popping the hood and using clamps.
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
KP Texan is offline   Reply With QuoteReply With Quote
Old 11-22-2020, 05:03 PM #24
Gotta admit, that's a pretty smooth solution to your battery charger issue.
The charger that I bought has a 2 prong 110 outlet plug on. I tested my front grill and wasn't convinced it could withstand being pushed and pulled on in the cold winter temps here.
Also, I have zero 3d printer skills...... so there's that. lol
Old 11-22-2020, 07:03 PM #25
Thanks! I like your solution too - blends in nicely and doesn’t look out of place. One other great thing about yours is that you can use it anywhere you have a 120V outlet. My charger gets left at home so I’m out of luck if I want to charge somewhere else.
2018 TRD ORP - Sold
Old 07-03-2021, 07:44 AM #26
woodsby woodsby is offline
woodsby is on a distinguished road
@T4R_Canuck Any chance you could post a picture of the underside of the cowl seal? I’m thinking about doing the same, but I had to relocate the relay block into that corner for another project. I’m curious what your install looks like under the cowl and going down into the engine bay.
woodsby is offline   Reply With QuoteReply With Quote
Old 07-04-2021, 03:29 AM #27
Will do. I'll try to grab a picture sometime tomorrow when I get a chance.
Old 07-04-2021, 05:22 PM #28
Not sure if this is exactly what you wanted, so let me know. I've circled an area where the hood hinge was rubbing on the cable at first but I just had to bend the cable a little more to avoid contact.
Excuse the dirt in the engine bay.... I like puddles.
Sent from my SM-G991W using Tapatalk
Old 07-07-2021, 10:04 AM #29
Thanks so much - this is a big help!!!
Old 07-16-2021, 05:00 PM #30
Got mine installed today. Thanks to @T4R_Canuck and @jhguth for the idea and help. I'm going to install an SAE input port on the passenger side cowl seal for plugging portable solar panels into my redarc bcdc charger next.
Question for anyone that's used the cowl seal - did you use the NOCO provided screws or did you use a machine screw and nut to secure this? Second, did you apply any silicone or sealant between the NOCO and the cover gasket and the cowl?
battery , fender , noco , option , plug
Power steering not cutting it after lift kilowhisky 3rd gen T4Rs 15 04-15-2019 12:16 AM
Previous owner tapped into spark plug wires - any ideas why? dkyleb 4th Gen T4Rs 12 03-10-2016 02:44 AM
Low Power Bad MPG - Need more ideas cashmoney 3rd gen T4Rs 50 06-28-2015 09:14 PM
Removing rear diff. fill plug.. any ideas? WXman 4th Gen T4Rs 15 03-13-2013 12:15 PM
HELP WITH A Power plug! cgscheer 4th Gen T4Rs 3 05-29-2012 07:04 PM
