Old 07-16-2021, 05:59 PM #31
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
[QUOTE=woodsby;3656253]Got mine installed today. Thanks to @T4R_Canuck and @jhguth for the idea and help. I'm going to install an SAE input port on the passenger side cowl seal for plugging portable solar panels into my redarc bcdc charger next.
Question for anyone that's used the cowl seal - did you use the NOCO provided screws or did you use a machine screw and nut to secure this? Second, did you apply any silicone or sealant between the NOCO and the cover gasket and the cowl?
That's a very clean install, nicely done!.
I used the NOCO screws, I was going to upgrade them to small bolts with nuts but it has held really well as is so far.
I didn't use any silicone as the NOCO is a sealed unit except the rubber door, and I have zero concern about water getting through into the engine bay. As you can tell in my pictures, lots of dirty water finds its way in from other places.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 03:13 PM #32
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
I used the included screws, not machine screws. No sealant, the plug has a rubber ring but the cowl is also open to the elements underneath so no sense worrying about waterproofing there.
jhguth is offline   Reply With QuoteReply With Quote
battery , fender , noco , option , plug
Power steering not cutting it after lift kilowhisky 3rd gen T4Rs 15 04-15-2019 12:16 AM
Previous owner tapped into spark plug wires - any ideas why? dkyleb 4th Gen T4Rs 12 03-10-2016 02:44 AM
Low Power Bad MPG - Need more ideas cashmoney 3rd gen T4Rs 50 06-28-2015 09:14 PM
Removing rear diff. fill plug.. any ideas? WXman 4th Gen T4Rs 15 03-13-2013 12:15 PM
HELP WITH A Power plug! cgscheer 4th Gen T4Rs 3 05-29-2012 07:04 PM
