Old 11-22-2020, 09:03 PM #1
PittRunner PittRunner is offline
PittRunner is on a distinguished road
KDSS Polyurethane Bushings
I have knock when off roading , the clamps on my OEM bushings came off first off road trip. I was looking to up grade , the only place I can find that sells Polyurethane for KDSS is Siberian Bushings . Anyone else gone this route ? Bushing 1-01-3890 41mm. I have 2019 TRD Off Road , I believe these fit ?
PittRunner is offline   Reply With QuoteReply With Quote
Old 11-22-2020, 09:11 PM #2
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
I ended up going with rubber from Moog as I had an impossible time finding poly for my KDSS sway bars.
If you find some, please post where you found them. I'd be willing to do that job again to upgrade.
Sent from my SM-G960W using Tapatalk
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
Old 11-22-2020, 09:26 PM #3
Its in my original post Siberian Bushings OEM part is # 48815-60360. type this in and you get 1-01-3890 Polyurethane bushing. They make a complete kit for the Limit 4 Runner. This is the part # Toyota gave me. There bushing is 41mm inside , dont know if thats correct ?
Old 11-23-2020, 12:28 AM #4
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
They need to have a lot of flex. I don't think poly would be a good choice for this application.
Old 11-23-2020, 08:09 AM #5
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
I second this, I had them but got tired of the constant greasing to stop the squeaking. I believe they hurt suspension travel as well. I took them out and threw them as far as I could. Not a good application IMHO.
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 11:15 AM #6
grizzlypath's Avatar
grizzlypath grizzlypath is offline
grizzlypath will become famous soon enough
As an aside- I had the same issue after my first off road trip. One of the band clamps (there one on each side of bushing, two bushings on front sway bar) came off.
I haven't been able to confirm, but based on some forum research it seems like those bands may have been placed there during the assembly process and aren't really functional once the system is assembled and the bushing is clamped.
In the meantime I threw a stainless steel zip tie on there, but I doubt it's doing anything. In order to replace the existing band clamp you'd have to disconnect the sway bar at the LCA and slip the band clamp ring on from that direction which seems like a ton of work for something potentially non-functional.
grizzlypath is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 08:55 PM #7
intresting , i believe they claim the same stiffeness as OEM but last 3 times as long.My OEM bushings didnt last one trip, ( if that is whats causing the thump ) so if I put rubber back in ,I guess I would be changing them once a year ?
Old 11-24-2020, 01:37 AM #8
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
Why do you think that's what's causing the thump? Can you look down and see the bushing's missing? I'd check other things first, it's unlikely that the KDSS bushings are the issue.
llDemonll is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 08:23 AM #9
TRUSTYAXE's Avatar
TRUSTYAXE's Avatar
It sounds like something else is wrong, I highly doubt everyone is changing them annually.
Old 11-24-2020, 09:37 AM #10
i loosen mine and throw some grease on them. they squeak yearly otherwise but nope, haven't replaced them yet.
Old 11-24-2020, 09:54 AM #11
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
My bushings started clunking a while back. Took a while to troubleshoot. I replaced them all with OEM and clunk gone They do wear out over time and will make a clunk noise. My clunker was in the front. Fairly easy job.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 12:08 PM #12
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Have have replaced mine once, so far, in seven years. They do need to be replaced. Particularly if you have a lifted front-end, you can see that the bushing is being malformed from anything other than stock height. Like others, I lube them too.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 01:58 PM #13
Jivewalker's Avatar
Jivewalker's Avatar
Are you lubing them with petroleum based or silicone based grease like sil-glyde or something?
I am fragile.
Not like a flower.
But like a bomb.
Old 11-24-2020, 02:24 PM #14
jrandom's Avatar
jrandom's Avatar
I have tried regular nlgi2 grease and it worked fine but gets and holds to much grime. It would be okay if there wasn't so much motion. I pack my coil-over lower spherical bearing with marine waterproof grease front and back, it is exposed, and the grime layer protects the fresh grease underneath, since it doesn't move much I am going on six years with those bearings.
Since I don't regularly fjord through streams, PTFE dry lube. Same as I use on my uniballs.
Either:
Triflow
Tri-Flow Superior Dry Lubricant – Triflow Lubricants
or:
Super-lube
https://www.super-lube.com/dri-film-...-syncolon-ptfe
whichever is cheapest at the time.
2013 TE w/ KDSS Nav
Old 11-24-2020, 04:32 PM #15
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
I made the mistake of going down the rabbit hole and reading up on the Siberian bushings website.
KDSS Polyurethane Bushings-ee097756-856e-4c37-ac13-a3528e9efdf5-jpg
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
bushings , kdss , polyurethane , road , siberian
Feedback: Polyurethane Body Mount Bushings fourfive 3rd gen T4Rs 10 04-07-2020 01:50 PM
Anyone make polyurethane or 'synthetic elastomer' upper control arm bushings? Spktyr 3rd gen T4Rs 3 09-18-2019 06:47 AM
Steering rack polyurethane bushings: grease or no grease? fourfive 3rd gen T4Rs 14 05-07-2017 02:59 PM
Does anyone make polyurethane steering rack bushings for 4th gen? luke87gt 4th Gen T4Rs 8 02-01-2016 11:06 PM
Energy Suspension Polyurethane Bushings Daddy 4th Gen T4Rs 6 05-21-2015 11:37 AM
