11-23-2020, 12:04 PM
TPMS opinion
All
Just bought 21 SR5P. Ordered TRD wheels and new tires. Am I better off having the tire shop break down my existing wheels and tires and use the TPMS, or buy a set and use them with the new wheels and tires? I was probably going to try and sell the factory wheels and tires.
Didn't know if you run the risk of damaging the TPMS while swapping. But seems like it would be easier to link to the vehicle.
Thanks for your help
11-23-2020, 12:11 PM
Real Name: Sparky
Real Name: Sparky
Yeah you can reinstall them, but you'll find it not worth the trouble or cost compared to buying new ones.
Old and (c)rusty.
11-23-2020, 12:18 PM
Real Name: Howard J. Turkstra
If you’re selling the original wheels, I would say to move the sensors onto the new wheels.
I have a spare set of rims that I bought TPMS “sensors” for that replace the caps for the valve stems, and the gauge plugs into the lighter in the center console. The gauge displays PSI for each tire.
I didn’t want to deal with paying a dealer to reprogram for different sensors every few months.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
11-23-2020, 12:26 PM
I never put my TPMS back on, haven't been bothered one bit. If it could actually read and display my individual tire pressures, then that would be a different story, but it doesn't. But I can see the value if you don't adjust your tire pressures often or at all.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
11-23-2020, 12:29 PM
If you do decide to get new sensors, be sure to buy genuine Toyota OEM sensors. Most of the non-OEM sensors sold by tire stores are junk.
11-23-2020, 12:31 PM
For Toyota, you are correct. But many car companies show the actual pressure at each tire -- GM cars for one.
TPMS opinion
I just wired around the TPMS, no matter what, it always shows good. No warning light, nothing.
11-23-2020, 12:36 PM
Of course, but this is a Toyota 4Runner forum. It should be obvious that my opinion relates only to the vehicle that this website is named after.
Build Thread
11-23-2020, 12:43 PM
tpms
Def cheaper 4 will cost you about 80$ . I switched mine but bought new gasket kit about 6$ a piece but 21' shouldn't need too ! I like them just due to fact that sometimes get lazy & don't look at them ! Nowadays always picking a screw or nail and just don't know till next morning & bam flat tire as your running late to work
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
11-23-2020, 02:24 PM
20+ 4runners show the pressure for each tire
11-23-2020, 02:29 PM
I did not switch mine over when I changed wheels. Could not get them to read correctly with the 4R (aftermarket). Dealership wanted way too much to “fix” the issue. Probably could have found a shop to do it better. I just did the wiretap instead (quick temporary solution).
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
11-23-2020, 02:30 PM
My dealer was incapable of activating and programing "aftermarket" Denso 550-0103 TPMS Sensors. They are the Toyota sensors. Exclusively for the value of not needing to deal with TPMS programming, use the existing TPMS sensors. Ur current TMPS sensors are new (battery life), and you are selling the wheels. Just swap the sensors, it'll be easier.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
11-23-2020, 02:36 PM
The 2020+ displays individual tire pressures in the gauge cluster FWIW.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
11-23-2020, 02:45 PM
In that case, I would transfer them over if I was in OP's position. The pre-2020 version is basically useless as far as I'm concerned.
Build Thread
11-25-2020, 07:53 PM
Thanks for the input. I'll plan on swapping them over
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
