Old 11-23-2020, 02:54 PM #1
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
Quickflate
Saw a couple reviews on Morrflate, but seeing if anyone has used any other brand of the 4 tire quick inflate/deflate. I was looking at Runnin 4 Tacos QuikFlate.
Since the compressor mounts in the engine bay are all the way to the left or right, any issues with inflation? All the brands say to have the hose centered in the front of the vehicle to help with leveling the pressure among all the tires.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 03:02 PM #2
apc9199's Avatar
apc9199 apc9199 is offline
apc9199 will become famous soon enough
apc9199's Avatar
I have a Morrflate, but have not had a chance to use it yet. I am still finishing up my compressor install. Regarding the hose positioning, there is no effect on pressure leveling regardless of where the hose is during inflation. All 4 tires are going to reach the same pressure as long as they are all connected. The big thing to watch out for is to make sure you inflate on a level surface with all 4 wheels flat on the ground. If one is sitting up on a big rock while it fills, then you cap it and drive off of that rock, its pressure is going to drop a little bit (not much, honestly).
apc9199 is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 03:08 PM #3
trapshot68's Avatar
trapshot68 trapshot68 is offline
trapshot68 is on a distinguished road
trapshot68's Avatar
I just finished making my own 2-tire setup (well, copied a friend exactly, basically), and like said above, hose length/volume will determine equalization, not the actual placement. But should have equal length hosing, and then run a line from the compressor to the setup. And i'm placing in center more for convenience. I have a basic hook to hang on the hood latch, and the rear hatch handle when in use.
trapshot68 is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 05:30 PM #4
apc9199's Avatar
apc9199's Avatar
The hose length/volume doesn't make a difference either. You run the system with all 4 tires connected and valves open. They will naturally equalize as long as the weight on each tire is roughly the same as under driving conditions. When you stop the compressor, all 4 tires continue to equalize naturally. This is happening faster than your compressor can keep up with, so unless you have a restriction in one of the lines for some reason, they are equalized during filling and immediately after stopping the compressor. At that point you go tire-by-tire disconnecting each fill valve one by one. You only lose TINY amounts of air when disconnecting the fill valve, so the pressure in each tire remains extremely close to the others through the whole process.
Old 11-23-2020, 07:28 PM #5
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
4 hoses plus a compressor hose seems like a lot of stuff to deal with on a trip.
IMO - Put an air line fitting near the front and one near the rear and use one 15 ft hose. You will have to go to each corner and do them separately but it's not that much extra time.
To deflate, I use Trailheads. Walk around, install one on each wheel, then go back and get around again and take them off. My co driver does two each way.
I use a CO2 tank which gives 30 second fill ups from 15 to 36 so it's quicker than a compressor.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 07:43 PM #6
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Its actually not too bad! After I got used to it, it only takes me 5 mins including set up to air up all the tires from 16 to 40. And I'm going slow to lol
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
bay , centered , engine , left , pressure
