Old 11-23-2020, 04:29 PM #1
DwightS DwightS is offline
DwightS is on a distinguished road
TRD Skid Plate on a 2018 SR5
Forgive me if this has been asked. I’m looking at the TRD Skid Plate for my wife’s 2018 SR5 Premium. Looking online at the Toyota parts websites, some say that it will not fit, some say it MAY fit... My question is, will it fit?
Thanks for your help!
Dwight
DwightS is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 04:33 PM #2
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
If you have a TRD Skid Plate Read This!
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 12:00 AM #3
fkheath fkheath is online now
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Dwight
I put the TRD skid plate on my 2018 SR5 4Runner. It fits fine.
There are two versions. The early version has the "TRD" recessed in the metal (stamped) but not colored lettering. The later version has red "TRD" plastic lettering in the recesses, however the size of the recess is different between the two.
The red plastic lettering is easily knocked off if you hit a rock -- I did! Fortunately, there are replacement lettering from Tufskinz:
TUFSKINZ Be sure to get the right size. The Tufskinz letters come in different colors too, not just red. Skid Plate Inserts - Fits 2010-2020 4Runner TRD Skid Plate | TufSkinz
When I was looking for the TRD skid plate, they were VERY hard to find, for the factory would not supply them to the dealers; they wanted to keep all production for new TRDs. I did finally get one through my local dealer, but it took awhile.
fkheath is online now   Reply With QuoteReply With Quote
Old 11-24-2020, 12:09 AM #4
Originally Posted by the_fornicator View Post
Yes!. I had that problem as well. You have to be careful in aligning the bolts into the mounting points.
Since you have to remove the skid plate to change the oil, I worry that the monkeys at the dealer may strip the threads on the bolts/nuts!
Old 11-24-2020, 07:02 AM #5
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Dwight
It will fit as long as you don’t have kdss.
If you do, modification is required.
Best Regards,
Saker
Old 11-24-2020, 01:04 PM #6
Jeff_DML Jeff_DML is offline
Jeff_DML will become famous soon enough Jeff_DML will become famous soon enough
The SR5 has a skid plate so does the TRD version even do much or people just get it for looks? I guess it does seem a bit beefer though.
2018 SR5P+3rd row, 285 KO2, 5100+Dobinsons 300/505
Jeff_DML is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 02:43 PM #7
It's not much beefier. It's just aluminum so will crumple/have to be replaced the second it has to put up with much.
I got the TRD skid plate just for looks.
Old 11-24-2020, 03:27 PM #8
Saker's Avatar
Saker's Avatar
What do you think the stamped skid would have looked like after hitting a 18” dia pole across the roadway.
This skid more than likely saved my life by lifting my front end up rather than crumpling upon impact!
So that’s my answer, you may disagree.
TRD Skid Plate on a 2018 SR5-687803ce-045b-467a-a4a2-cc6f12416386-jpeg
Best Regards,
Saker
Old 11-24-2020, 06:26 PM #9
The original skid plate is pretty thin metal, while the TRD plate is 1/4" aluminum; it is much sturdier. I can attest to that. Last year, while off roading, I hit a good size rock that took off one of the TRD letters, and made a pretty good gouge in the metal. I'm sure the thin sheet metal would have fared much worse.
To answer your question, I bought it for both looks and utility. After hitting that rock, I'm glad I did.
fit , plate , skid , sr5 , trd
2014-2018 TRD SKID PLATE TUFF SKInz insert des moines ia $35 18 trd off road For Sale: T4R Items 2 05-01-2019 10:27 AM
TRD Pro skid plate 2018 K9trainer 5th gen T4Rs 1 10-05-2017 04:24 PM
2018 interior lighting/skid plate swim.bike.run 5th gen T4Rs 9 09-29-2017 04:16 PM
SoCal - Aftermarket 4th Gen 4Runner Skid Plate + Filler Plate - $250 boxtree619 For Sale: T4R Items 2 02-04-2017 10:00 PM
