Old 11-24-2020, 01:54 PM #16
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Originally Posted by JeuTheIdit View Post
Never occurred to me before that location (I am assuming weather/temperature is the root cause?) might be a factor in battery life lol. Learn something new every day. I am in MN and always seem to get 4-5 years.
Very hot is very short life.
Moderate cold is long life.
Extreme cold is short life.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 02:33 PM #17
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Battry's
Get about 2 1/2 yrs out of Bosch (pepboys) in the desert heat ! And that's with no xtra stuff running off of it !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 06:33 PM #18
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
My experience is the OEM batteries do not last as long as a good aftermarket battery. The dealer always wants more money for an OEM battery than most after market so it makes more sense to me to buy after market.
Interstate actually makes most of the other brands of batteries. Getting a good price at Costco is the way to go.
fkheath is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 06:46 PM #19
yotadawgjr yotadawgjr is offline
yotadawgjr is on a distinguished road
I've had good luck with Interstate batteries on my 3rd gen, last two lasted 6 years before showing any signs of weakness. It's a 5 year warranty I believe. Never had an issue starting in the extreme cold either even on a non cold-weather oem starter
yotadawgjr is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 11:18 AM #20
psa5555 psa5555 is offline
Real Name: Scott
psa5555 is on a distinguished road
Real Name: Scott
Thank you everyone, who took time to share their knowledge and advice. It is very much appreciated!
I checked the battery health again this morning.. still low at 12.21V. I have looked at my options including the Odessey, Optima Red Top, Energizer AGM, Interstate MTP and the Kirkland. At triple the price, I decided against Odessey. The Interstate and Kirklands are almost identical. Costco's 48 Month Free Replacement and 100 month Pro-rating guarantee sold me, and at $119, it seems difficult to go wrong at that price. The Interstate was 50% more $ for basically the same battery, with way less warranty.
I've had a Kirkland battery in my other SUV for the past 4 years, and it has been nothing but rock solid. I guess I will get a chance to test another one out and see if it performs as well.
Again, Thank you all!
2018 T4R SR5 Premium - Classic Silver Metallic
psa5555 is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 03:41 PM #21
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
My 2014 with 109k miles just had its original battery replaced 2 weeks ago.
I was getting an alignment and they tested battery and gave me specs and said it should be replaced. I ended up grabbing an Interstate battery from Costco.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 10:20 AM #22
Packpride85 Packpride85 is offline
Packpride85 is on a distinguished road
I've had the best luck with Diehard batteries for aftermarket.
Packpride85 is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 12:16 AM #23
pianorocks06 pianorocks06 is offline
pianorocks06 is on a distinguished road
All good points here. Also adding that flooded batteries tend to be much more forgiving than AGM - AGM is great technology that can last much longer under certain conditions but are much more sensitive (not to mention expensive). In my experience, the top end AGM’s have a recombination catalyst which provides a host of benefits mainly maintaining saturation levels and reducing positive plate corrosion.
At the end of the day, any quality battery which is properly maintained will last longer than the most expensive one which is deep discharged, not fully recharged, or abused otherwise.
pianorocks06 is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 01:25 AM #24
4FL 4FL is offline
4FL will become famous soon enough 4FL will become famous soon enough
4FL 4FL is offline
My battery lasted just short of six years, after all the reading and stuff thinking I might get one of those fancy ones, I settled on a truestart at the end of it all, the Toyota branded battery. They had a sale going on, the dealership was basically down the street, so I just swapped it in the parking lot and got the deposit back for my old battery right there.
If I had extra electrical accessories or needed some sort of set up where I need to draw power, I would have went something else maybe.
2015 Trail Premium w/KDSS, nautical blue, tinted windows, factory running boards, Cooper Discoverer AT3 4S stock size.
4FL is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 04:38 PM #25
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Get the biggest DEKA/East Penn you can fit.
I am not familiar with their current line names, but Deka Ultimate batteries I have are going into their 9-11th years in service now.
(I do take them out 2-3 per year and put them on a BatteryMinder 2012
12V 2A Desulfating Battery Charger Maintainer | Worldwide Use .)
East Penn is one of the manufacturers.
Most other are just REBRANDS of East Penn, Johnson Controls etc.
Like the old Advance Auto "Autocraft Titanium" that is no longer sold, is a DEKA Ultimate.
11 years in service and now has a dead cell.
Others can talk about brands, but I can show the proof.
(I took it out and washed the top of it on Friday. BM 2012 is saying it has a dead cell)
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 07:02 PM #26
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Get any new 24F lead acid battery. It doesn't matter what brand. A new battery is a good battery. I went with NAPA Premium 84 month. Its East Penn. Also, Lead acid because the alternator is designed for charging Lead Acid batteries. My Panasonic lasted 5 years. It may have lasted another winter but not worth the risk. I kept the Panasonic. Not turning that in for $10. Some people can revive old lead acid batteries...
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 07:11 PM #27
My Toyota Dealer had a good sale on TrueStart in October. I almost got one. They wanted a $30 core charge, not for me!
I installed a TrueStart in my 3rd gen like that, in the parking lot. It was a fine battery. It lasted 5+ years before the 4runer was rear-ended by a Drunk, uninsured, unlicensed person.
1999 4runner
Old 12-21-2020, 08:48 PM #28
3kushn's Avatar
3kushn 3kushn is offline
3kushn is on a distinguished road
3kushn's Avatar
Originally Posted by s13koop View Post
Truth is most batteries all from the same place
Source: We haul batteries/cores
Its the warranty you're buying. I haven't the need for an Odyssey yet and anything I've bought so far for my vehicles has worked out pretty good for at least 4yrs.
I live in a warm climate though. Also, what happened in the last 5 years where batteries are hitting over $150??
This is the truth.
Brands are just that. Walmart, Auto Zone, Advanced, Napa, ..... all get their batteries from battery manufacturers. None own their own battery plant. And none want a bad name because of their batteries as its a common sale.
Although the Extended Warranty is mostly just an added charge on the same battery, there are some small differences. Meaning Lifetime warranty is a $ hook.
I had battery problems with an F150. The Dealer put in a "Lifetime" battery. When that went bad after several years, I got a $10 benefit when I needed a new one.
Battery sales is mostly a scam.
3kushn is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 09:55 PM #29
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Another vote for Napa batteries. They are all Deka East Penn as you said. Great quality.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 11:06 PM #30
updawg updawg is offline
updawg is on a distinguished road
In Texas My batteries go out like clockwork every 3 years. Finally just switched to Costco interstate when my wife’s car went out. Hopefully that is better. Screw autozone etc
updawg is offline   Reply With QuoteReply With Quote
batteries , battery , electronics , garage , vehicle
Need advice on a second battery. erik619 4th Gen T4Rs 17 01-13-2021 10:59 PM
Battery group advice CWccw 3rd gen T4Rs 16 05-16-2020 01:15 AM
Dual Battery advice and mounting options hoffmanmark 4th Gen T4Rs 0 07-23-2018 02:30 PM
Battery Advice Ron4RNevada 5th gen T4Rs 8 01-08-2018 03:25 PM
Any advice my dual battery setup plan? Rocky5000100 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 08-20-2013 07:02 PM
