11-25-2020, 09:06 PM
#46
Originally Posted by ElectroBoy
I bought the 1987 version new. It was a great vehicle and I was thrilled to have it, locking hubs and all.
...and roll-down windows, and push/pull locks...
They were sweet!
You could even get one without a back seat.
11-25-2020, 10:23 PM
#47
My experience with Ford locking hubs was that they suck sphincters
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
11-25-2020, 10:37 PM
#48
Real Name: Sparky
Real Name: Sparky
I was surprised to see Ford still using them on trucks well into the 2000s.
Old and (c)rusty.
11-25-2020, 10:41 PM
#49
Toyota provides different package on the 4runner because the market demands & needs there are people that do not have a need for 4X4 but want a SUV that is reliable and safe and comfortable to drive with a family
you should buy a vehicle that fits your needs so if you don't go hardcore off roading or go through the harsh weather & road conditions then you would not need 4X4 most off places that i have gone weather to the ski areas or off road areas i could have gotten away with a 2 wheel drive just needed better tires most of time and chains once in Mammoth.
18 FunRunner
11-25-2020, 11:58 PM
#50
Not all that surprising in regions with dry and warmer climates. I visit Southern Cali multiple times a year and I swear most of the Tacoma's I see running around are 2wd models so I doubt the 4runner is any different. Those folks just want the look and figure they don't need to pay a premium for something they won't use or care for.
Up north in places like MN and it's a different ballgame. Dealers here won't even order or stock 2wd models because it just doesn't sell here.
2020 Midnight Black Metallic 4runner Offroad premium
11-26-2020, 06:06 AM
#51
Originally Posted by Whippersnapper02
There's 2wd Jeeps too.
There used to be 2WD Wranglers. That stopped in 2009. The other vehicles in the Jeep brand are not real Jeeps.
11-26-2020, 01:24 PM
#52
Did you know they made a 2WD 4Runner?
I also thought the limited was all AWD, nope :-)
11-26-2020, 03:54 PM
#53
Real Name: Sparky
Real Name: Sparky
There’s literally no point in buying one if it isn’t.
Old and (c)rusty.
11-28-2020, 01:09 AM
#54
I gotta get me one of them 2WD TRD Offroads.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
11-28-2020, 03:41 AM
#55
Only in Sr5 and Limited models :-)
11-29-2020, 12:39 PM
#56
This will really throw you off...
Did you know they made a 4 banger 5th gen for one year?
The four-cylinder model gets a four-speed ECT automatic transmission
From
2010 Toyota 4Runner Rubicon Trail First Drive
2018 SR5P+3rd row, 285 KO2, 5100+Dobinsons 300/505
11-29-2020, 03:30 PM
#57
Originally Posted by Jeff_DML
"The 4.7L V-8 engine has been discontinued in the 4Runner, but the V-6 makes 10 more horsepower and gains an EPA estimated three mpg in the city and five mpg on the highway as compared to the V-8. But that's not all. Thanks to friction-reducing technology, the V-6 in the 4Runner makes an impressive 34 more horsepower and 12 lb-ft of torque than last year's V-6, even though it's exactly the same displacement. "
Why would anyone want a V8?
Sunroof
11-29-2020, 08:25 PM
#58
Because the V8 has more power at lower RPM.
The Dual VVT-i 1GR-FE, only has a HP advantage over the V8 at higher RPM. And of course it never matches the V8 for torque.
11-29-2020, 08:42 PM
#59
2009 Toyota 4Runner Limited 4WD 4dr V8 (Natl) Features and Specs
20 ft lbs plus or minus at 3400 rpm is not exactly a lot of low end torque and 3400 rpm is not exactly low rpm. With the added weight, lower mpg, less space to work ... V6 is a better idea imho
Sunroof
11-29-2020, 09:11 PM
#60
You're quoting the torque peak. The difference at the engines respective torque peaks is 28 lb-ft. The Dual VVT-i 1GR-FE also doesn't reach it's torque peak until 4400 RPM. It makes 28 lb-ft less torque at peak, AND you have to spin the engine 1000 RPM higher to reach it's lower torque peak.
To get the clearest view of the power difference between the engines, you have to compare the power curve of each engine from idle to redline.
Basically you have a heavier vehicle, making less power at the RPM these SUV's are typically driven at.
