Old 11-25-2020, 08:07 PM #1
Chilow Chilow is offline
Chilow is on a distinguished road
Striped License Plate Screws
Help! I was attempting to remove my license plate frame to put on a registration sticker, but both of the screws were on super tight and stripped. I used one of those stripped screw extractors and it made it worse so now both are beyond extraction. How do I go about removing them? Can it be done from the back? Behind the hatch plastic panel?
Chilow is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 08:55 PM #2
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Can you drill it out and tap it for a larger size? Or maybe just use a larger size self-tapping screw?
Old 11-25-2020, 09:00 PM #3
PCRIDE4RUNNERORG PCRIDE4RUNNERORG is offline
PCRIDE4RUNNERORG is on a distinguished road
I had to do this, I used vice grips in an attempt to extract the rusted screw and the head broke off. I drilled it out, re tapped and used anti seize on the screws.
I canít remember the exact size but just the next size up. Dealer charges $60 per hole FYI
PCRIDE4RUNNERORG is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 11:18 PM #4
DougR's Avatar
DougR DougR is online now
DougR will become famous soon enough DougR will become famous soon enough
DougR's Avatar
YouTube has 12+ videos on how to fix this problem. Search for "stripped license plate screw". It's better to visually see how its done to figure out if you have the tools, interest, time and ability to fix it.
DougR is online now   Reply With QuoteReply With Quote
Old 11-26-2020, 12:14 AM #5
fkheath fkheath is offline
fkheath has a spectacular aura about fkheath has a spectacular aura about fkheath has a spectacular aura about
1. Drill it out slightly smaller than the original.
2. Use a screw extractor tool in the new hole (lots of WD40)
3. Use a tap to clean out the hole after the old screw has been removed.
4. Use stainless screws from now on.
If the old threads or hole is too damaged, drill and tap to the next larger size.
I've replaced all my license plate screw with stainless and never have a problem.
fkheath is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 12:36 PM #6
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a name known to all MeefZah is a name known to all MeefZah is a name known to all MeefZah is a name known to all MeefZah is a name known to all MeefZah is a name known to all
MeefZah's Avatar
I'd use a dab of grease or anti- seize on the replacement bolts, once you extract the old ones and clean up the threads with a tap. Fairly common issue, unfortunately.
I actually use anti-seize on all the bolts I remove from the 4R... skid plate bolts come to mind. Future You will thank Present You in two years.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 02:45 PM #7
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
I was in Colorado for a long time so they had become fused to the truck.
I tried tapping them, and their heads just snapped off.
Nothing I could do could get them out. I had to go to the dealership to cut the damn things out.
And they struggled with it for like 30 minutes.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 02:55 PM #8
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
I know this doesn't help at all, but it has always been a pet peeve of mine how the holes would always rust. So, from the second I purchased the vehicle, I pulled the bolts out and caked them in marine-grade anti-seize. Then, I put silicone washers on either side of the license plate before bolting things back in.
Maybe something to keep in mind after you fix em up.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Bilstein 5100s (w/ 2" Toytech Superflex), 285/65/18 duratracs (E), 18x9 Volk TE37 // 2003 Black Limited (2UZFE) aka Blacky Chan: stock
the_fornicator is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 03:20 PM #9
spartacus's Avatar
spartacus spartacus is online now
spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all
spartacus's Avatar
Unhappy
you can try a left hand drill bit.
spartacus is online now   Reply With QuoteReply With Quote
Old 11-26-2020, 09:19 PM #10
Ferd_4R Ferd_4R is offline
Ferd_4R will become famous soon enough
Same thing happened to me last year.
Had to remove the inside panel and cut the damn thing out.
Ferd_4R is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 10:25 AM #11
GripT4R GripT4R is offline
Banned
GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light
Banned
Hit them with your purse.
GripT4R is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 11:33 AM #12
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner has a spectacular aura about 08TxRunner has a spectacular aura about 08TxRunner has a spectacular aura about
08TxRunner's Avatar
Originally Posted by gript4r View Post
hit them with your purse.
lmao.
08TxRunner is offline   Reply With QuoteReply With Quote
extraction , license , plate , screws , stripped
Ughhh- rusted license plate light screws Hapeacres 4th Gen T4Rs 12 11-20-2020 08:28 PM
License Plate Screws apache67 5th gen T4Rs 16 02-27-2020 09:04 AM
Dagnabit -- License plate light screws chester4Run 5th gen T4Rs 8 02-06-2020 03:30 PM
License Plate Screws/Bolts MaliciousClout 4th Gen T4Rs 11 06-30-2018 11:37 AM
need some help - license plate screws stuck theliman Maintenance/Detailing 8 01-09-2014 06:50 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
