Originally Posted by dwib44
Upgrading to 3 inch lift. Deciding between:
Kings extended travel with adjusters, OME 2889 rear springs, and Camburg uniball upper arms
vs
Old Man Emu BP51 3" Medium Load Kit
Any strong opions on which is better? Cost difference is only about $300.
Which is better offroad, which is better on road? Has any one tried both?
Check out this video, skip to 12 minutes in particular
https://www.youtube.com/watch?v=-MsK...ature=youtu.be
King's vs BP-51's
5th Gen 4R - Suspension choice help King vs OME BP-51 - Starting build | OVERLAND BOUND COMMUNITY
There's lots of other info out there. I can't speak personally to either as I haven't run either, however, I'd consider seriously if race style shocks are really what you need.
