Old 11-26-2020, 03:34 PM #1
Agent_Outside's Avatar
Agent_Outside Agent_Outside is offline
Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice
Comprehensive Guide to 5th Gen 4Runner Trans Service
If anyone is interested I out together a comprehensive how to for doing a trans service on the 5th gen. Part numbers, torque specs, how-to, it’s all there.
https://www.youtube.com/watch?v=H3H9JGg_rF0&feature=youtu.be
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 04:01 PM #2
spartacus's Avatar
spartacus's Avatar
Good video. Would be helpful when I decide to do mine. Thankyou.
Old 11-26-2020, 04:08 PM #3
s13koop's Avatar
s13koop s13koop is offline
s13koop will become famous soon enough s13koop will become famous soon enough
s13koop's Avatar
Man I was just researching this. Great vid and straight to the point.
Thanks!
00-JZX100
10-Trail Ed.
s13koop is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 04:33 PM #4
Glad I could help
Old 11-26-2020, 04:40 PM #5
Thanks!
I tend to watch YouTube when I’m bored instead of tv, I’ve seen a couple videos that I’ve watched and thought to myself no that’s not right, or it’s easier to just do it this way, or shut up get to the point lol. A lot of people seem to be intimidated by “sealed” transmission, personally I’ve dealt with them professionally for the batter part of 2 decades. It’s really simple and the process straight forward and logical once you understand the steps you need to take and why you need to do them.
Old 11-26-2020, 05:33 PM #6
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
The Warranty and Maintenance Guide does not recommend replacing the strainer and yet under special operating conditions, it recommends changing the fluid every 60,000 miles. I suspect the large surface area of the screen is designed to hold all of the larger particles shed over the life of the clutch pack and still allow sufficient fluid flow through the strainer. There are three (3) ways non-metallic material is captured, in the fluid, coating the pan and in the strainer. Perhaps back flushing the strainer with used ATF is an option. Overall, a very good video.
DougR is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 09:16 AM #7
Your warranty and maintenance guide also stops at 120,000 miles. If you want to change it... great. If you don’t want to change it... great.
Old 11-27-2020, 10:51 AM #8
troopa4life troopa4life is offline
troopa4life is on a distinguished road
Nice video, thank you for sharing. I do mine every 15k as well, but I usually start putting my check plug back on at the 16:29 mark in your video. If you notice the flow of the fluid changes as it has now crested the top of the "check valve". I was wondering why you waited longer to put the plug back in? Would love your thoughts. Thanks again for posting.
troopa4life is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 12:00 PM #9
Theres a temperature range for removing the check plug. As long as you’re around that range and the fluid slows to a trickle your good. Anything beyond that your talking minuscule differences in fluid capacity, especially when it’s a system that in total holds 11.3 qts of fluid.
Old 11-27-2020, 01:02 PM #10
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Pretty good vid.
Factory manual says temp 1 needs to read between 104° and 113° if you want to be “by the book”.
Do you usually only do the one drain and fill per 15k?
1000MPH is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 02:28 PM #11
Originally Posted by 1000MPH View Post
Pretty good vid.
Correct, 40-45 C is the official spec, that along with torque specs, process, pet numbers, are all in the description on the video.
I drain every 15K when I have the skids off to do the diffs.
Old 11-27-2020, 02:51 PM #12
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
And magnets.
delloro is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 03:35 PM #13
DougR's Avatar
DougR's Avatar
Originally Posted by delloro View Post
And magnets.
The video shows the amount of magnetic material captured by four (4) magnets widely spaced around the pan after ~135,000 miles.
Three (3) ways non-metallic material is captured in a sealed transmission are: (1) very fine particles remain suspended in the fluid, (2) some particles cling to the pan and strainer and (3) large particles that would bind in close clearances are captured by a large surface area strainer that is likely to hold a lot of material without significant flow restriction.
These are robust design details that contribute to legendary Toyota reliability.
I rarely incur special operating conditions, so I recently exchanged 12 quarts at 114,000 miles and didn't open the pan. As a result of watching the video, I'm planning to wait until 180,000 miles to inspect and back flush the strainer with used ATF, replace strainer o-ring, clean the magnets, clean the pan and change 12 quarts of fluid.
Incidentally, in 2012, a GM TSB recommended no external transmission fluid exchange, drain and fill only, which implies do not open the transmission pan. I find it very hard to agree with that recommendation for obvious reasons that have been thoroughly discussed on this forum (and moreover, I would never buy a GM product).
Old 11-27-2020, 04:06 PM #14
delloro's Avatar
delloro's Avatar
I rarely incur special operating conditions, so I recently exchanged 12 quarts at 114,000 miles and didn't open the pan. I'm planning to wait until 180,000 miles to inspect and back flush the strainer with used ATF, replace strainer o-ring, clean the magnets and pan.
Oh crap what a maroon I am. D'oh!
Old 11-27-2020, 04:39 PM #15
DougR's Avatar
DougR's Avatar
I would never say that about you. Maybe your spouse would if you have one :-). Mine does all the time.
5th , comprehensive , gen , service , trans
James Baroud Explorer - Comprehensive Review & RTT Buyers Guide bagelsjustbagels General Discussions 6 08-12-2020 10:12 PM
Toyota 5th Gen 30K Maintenance/Service Buyers Guide ReluctantNomad 5th gen T4Rs 6 07-26-2016 11:45 AM
Trans service Robs08Runner 4th Gen T4Rs 21 03-27-2014 08:06 PM
Advice for trans service..... hdoggie24 Maintenance/Detailing 3 07-24-2011 04:39 PM
Sealed Trans service ? 8086bruce 4th Gen T4Rs 16 06-24-2010 08:29 AM
