11-30-2020, 01:34 PM
#31
Originally Posted by 1000MPH
Sorry to bug you on this...
Your setup looked way easier than using my old laptop with TechStream but that Toyota enhancement is an $80 add-on. Is that what is needed on top of the OBD Fusion app ($10) and Carista Dongle ($27) to pull Transmission temps?
Toyota Enhanced Diagnostics for Windows | OBDSoftware.net
The enhanced diagnostics is an OBD Fusion in app purchase for $10, I bought it for my 2011 4Runner and my 2016 Highlander.
11-30-2020, 01:52 PM
#32
I've read all of the comments here and watched the entire video, all of this is excellent information, however, I am a bit confused after reading some of the back and forth regarding whether or not to change the filter EVER or what interval to replace the filter... While I am very comfortable with tools and general repairs, mechanical maintenance on a vehicle is new to me (besides engine oil changes).
Here is my situation:
- I just bought a 2016 Trail Premium with 97K miles, drove it from CA to VA and crossed the 100K mark during the trip. It drove great, no issues whatsoever.
- The carfax shows that it was always serviced at dealerships by the previous two owners.
- Based on the fact that it is a '16 with 100K miles I am sure it was taken on many trips and the owners' commute must have been long (likely highway)
- In addition to the above, the previous owner had left their home address in the GPS address book and I googled it, they lived way out in the mountains and based off of the satellite images it looked like a lot of dirt road.
With that said, the maintenance records are scarce (besides the Carfax) and I am unsure of when the various fluids were last replaced. I had a trusted toyota mechanic give it a look over before the trip and he replaced the front rotors, brakes all around and did an oil change. Nothing else was noted other than the front struts must have been replaced within the last 20K miles with OEM.
Now that I am in VA, I'm starting to learn more and more about the maintenance of the vehicle and wanting to do all of my own servicing from here on out.
My questions:
1) Should I simply drain and fill the trans or should I go in and all in and replace the filter?
2) If you were in my shoes, what other fluids would you tackle right away? (rear/front diff, transfer case, etc?)
Any advice is greatly appreciated!
~smee
[ Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
Reason: Typos
11-30-2020, 02:09 PM
#33
- In addition to the above, the previous owner had left their home address in the head unit system and I googled it, they lived way out in the mountains and based off of the satellite images it looked like a lot of dirt road.
My questions:
~smee
If it were me and I just bought it with 100K I’d personally do it all. I’d do the full trans service, diffs, t-case, brake fluid flush, fresh coolant, air filter, pollen filter, spark plugs, set the tire pressure in the spare because neither the pervious owner or their shop has ever actually checked that - no one does. The fact that your questioning it means you have your uncertainties about it. A known baseline reset and the piece of mind that it comes with it counts for something.
11-30-2020, 02:29 PM
#34
Thank you. I think that I knew this was the answer but just wanted someone else to say it so I didn't feel crazy. You're right about needing a baseline, I know I'll sleep better at night.... and I certainly intend to drive this vehicle into the ground.
Good note about the spare tire.
Looks like I have a lot of work to do and your video is going to be a life saver!
I am also utilizing the spreadsheet and info from this post for other servicing: Beginner Fluid Maintenance
11-30-2020, 03:44 PM
#35
I would add checking or replacing the serpentine belt and cleaning the MAF and throttle body. Both are cheap and easy to DIY.
My MAF and TB were pretty clean at 110k but looking online at vids, excessive dust and dirt could be a sign of air filter neglect or a lot of off-road use.
12-01-2020, 12:29 AM
#36
Good call. I picked up some MAF cleaner and TB cleaner while I was out today. Going to order the belt.
Edit: Just placed a hefty order through a local dealer... Tackling the ATF, Transfer Case, Rear/Front Diff first and a few other items:
12-01-2020, 11:39 AM
#37
I have the same app with the Toyota plug-in but can't find the trans temp. Is it one of the prebuilt sensors?
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
12-01-2020, 11:57 AM
#38
There’s a lot of talk on here about cost and availability of the OEM fluid for diffs and especially the T/C. Looks like you found a dealer willing to actually order and ship the liquid gold?
Also some talk on the serpentine belt: Toyota vs. “OEM” Bando.
If possible, could you post a pic of the belt you get from Toyota to compare?
12-01-2020, 12:07 PM
#39
You don't need a dongle, software, techstream, scanner or any other hardware to set fluid level in an A750E(2WD) or A750F(4WD) 4R 5th Gen /Tacoma 2nd Gen transmission.
All you need is a jumper wire and the instructions found on the first 2 pages of the following URL:
How to Drain/Refill Automatic Transmission | Tacoma World
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
12-01-2020, 12:50 PM
#40
Diagnostics-> PID values -> Menu -> Select PIDs -> Toyota, Lexus, Scion -> Engine and Electronic Controlled Transmission
Then select your values.
12-01-2020, 12:53 PM
#41
You don’t buy diagnostic ability for reading trans temp. You buy it for being able to read and clear faults from every control in the vehicle and we’ll as see diagnostic data and measured values of anything and everything. Seeing actual trans temp is just one of many many uses.
12-01-2020, 01:57 PM
#42
I agree, but some of the discussion in your fluid change thread centers around determining ATF fluid temp.
I was merely pointing out that Toyota's built-in jumper wire method addresses that.
Yes - scanners are useful for problem determination.
12-01-2020, 02:59 PM
#43
Well, I was able to place the order and get a confirmation of the order. I will report back if they contact me saying "we can't order this".
Ordered from: Toyota Parts and Accessories Online - DARCARS Toyota of Frederick in Frederick, MD
Damn. I didn't realize this. Yes I will post a pic once I receive it.
12-01-2020, 04:23 PM
#44
Great Video, thanks Agent O.
Watching this video made me think...can 5th gen ATF be changed like the 4th gen? There are videos for a complete ATF change using the 4th gens 4runners ATF pump. Basically, find the trans cooler input/output. Then run the engine to pump out 2 quarts, put in two new quarts of ATF and repeat about 6x.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
12-01-2020, 04:35 PM
#45
I've always found the best Toyota WS deals on ebay. One of the better prices on there now is $104.99 for 12 qts. or $8.75 a qt. - free ship. Local dealer wants $13.00 a qt.
toyota Lexus Scion atf ws World Standard Transmission Fluid 12qts 00289-atfws | eBay
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
