Old 11-28-2020, 02:40 PM #1
djpg2000 djpg2000 is offline
djpg2000 is on a distinguished road
Question Help With Finding Door Ajar Tone
Hi! I've searched and searched for a thread on this but I can't find one. When I lock my doors and a door is ajar, there is a long tone that sounds. It sounds like it's coming from the driver's side of the engine bay. Can anyone tell me where it's coming from and how to disable it?
- 2011 Toyota 4Runner 4.0L V6 4WD Trail Premium Edition w/ KDSS
- ToyTec Ultimate 3" Lift Kit w/ Rough Country V2 Rear Shocks Instead of Bilstein
- Safari Snorkel
- BFGoodrich All Terrain T/A KO2 Tires LT285/70R17 121R E
- 2" Bora Wheel Spacers
djpg2000 is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 02:54 PM #2
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
It's supposed to do that to alert you that all doors aren't closed. I believe it should also prevent the doors from locking until they're fully closed. If you fully close all the doors and hatch, then lock the doors, does the beep go away?
thennen is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 04:08 PM #3
I know it's supposed to do that but I want to know where it is and how to disable it. The problem with my car is that it's beat up and has water damage from off road use so it always thinks a door is ajar.
- Safari Snorkel
Old 11-28-2020, 04:16 PM #4
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Lightbulb Pizio
So just tried this & it worked . In the door jamb is black rubber button which when engage turns off . I was going to unplug this to turn it off however when (allen wrench) , 1 turn & it turned off , tighten up back on easy ! As for the pizio that will be in the fender well probably be brake booster ,it will be a MOFO to get out but is doable & its just plugged in . Should be a cluster of or bundle of wires running into fender , keep listening & you'll find it . I liked easier approach 1 turn off !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 04:35 PM #5
thennen's Avatar
thennen's Avatar
Gotcha - didn't know that. Maybe oljedi11950 has the fix. Otherwise, might be a dealer-adjustable setting in software.
Old 11-28-2020, 04:48 PM #6
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Have you looked at a Carista?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 04:52 PM #7
I did the door jamb buttons first but they don't respond so it's gotta be a wiring issue or an ecu or something. I gotta find the buzzer.
- Safari Snorkel
Old 11-28-2020, 05:01 PM #8
thennen's Avatar
thennen's Avatar
Did you physically disconnect each door jamb switch and the hatch switch? Or physically short them? Sorry, I'm not sure which condition - open switch or closed - that the vehicle is looking for to determine a closed door. I would guess it's looking for all the switches to be closed, as gunk would typically serve to prevent contact.
Old 11-28-2020, 06:14 PM #9
I disconnected each one. On the door that's messed up it doesn't matter whether I push in the button or unplug it, it still says the door is open.
- Safari Snorkel
Old 11-28-2020, 06:25 PM #10
Unhappy Pizio
Did you try unplugging drivers side switch ? That will kill em all . But like I said the noise maker(pizio) is in the inner fender well drivers side by brake booster , you'll see the bundle running into fender . On my son's 11' it was easier to get to it from inside wheel line but more of a hassle ! CANNOT turn off thru Carista
Old 11-28-2020, 06:29 PM #11
Pizio
Not sure which fuse it might be but might try that ? Or dis-connect battery for a bit
Old 11-28-2020, 07:57 PM #12
So, you're saying that unplugging the driver's door jamb button will disable all of them? I have an 11 4runner too..lol
- Safari Snorkel
Old 11-28-2020, 07:59 PM #13
I was looking at the fuse list but I can't determine which one it would be. I'm sure it other has other things connected to the fuse as well so that probably wouldn't be a good option.
- Safari Snorkel
Old 11-28-2020, 08:12 PM #14
thennen's Avatar
thennen's Avatar
So if you know which door is messed up, can you replace or bypass that switch? Or perhaps I’m missing something. Because it sounds like you have determined that the other switches are good.
Old 11-28-2020, 08:27 PM #15
Pizio
Yes however , make sure you tape it ,use something to keep it from disappearing into door jamb ! I did this & beeping was gone . It's a very short line with the plug , pretty sure drivers side is main plug !
ajar , coming , door , searched , sounds
Door ajar light on AzHic13 3rd gen T4Rs 37 02-07-2022 03:11 PM
DIY: Replace door courtesy / door jamb switch (fix door ajar light and door sensor) andrewbares 3rd gen T4Rs 17 05-16-2021 03:17 PM
door ajar light stays on, not a door switch or hatch, what else could it be Steve240 3rd gen T4Rs 9 12-30-2018 03:50 AM
Another door ajar thread JtuckerSvces 3rd gen T4Rs 17 07-10-2018 07:56 PM
3rd Gen door ajar alarm yc4runner Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-16-2010 01:38 AM
