Old 11-29-2020, 03:19 PM #1
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
5 tire rotation and tpms / valve stems
From what I’ve read the ecu only recognizes four tpms sensors?
If so what aftermarket valve stems do you five wheel rotation people run?
I was thinking about just running simple rubber ones from now on, putting a sticker over the light, and calling it a day.
All my old race cars did just fine without the system.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 11-29-2020, 03:45 PM #2
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
I've got 5, all with TPMS. Just picked up #5 a few months ago (thanks agin ryguytheman)
Haven't rotated in #5 yet, when it's time I'll look up the relearn procedure.
I've also thought about going without.....as so many do.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 11-29-2020, 04:36 PM #3
Banned
Banned
Interesting... I think you need tech stream and all that jaz. Are you talking about having to plug it in every rotation to relearn?
Old 11-29-2020, 05:09 PM #4
vdog2000002 vdog2000002 is offline
vdog2000002 is on a distinguished road
I have a 2020 Limited and it has 5 TPMS and displays all 5 pressures on the dash. After doing some research, the 5th TPMS seems to be only available on the Limited models.
5 tire rotation and tpms / valve stems-20201129_150447-jpg
vdog2000002 is offline   Reply With QuoteReply With Quote
Old 11-29-2020, 05:49 PM #5
Banned
Banned
Yeah I use a scanguage to monitor pressures via the obd port. Only gives me 4. Spare looks like a normal rubber valve stem.
I’m going to be mounting my 5th wheel on my bumper so that would be an issue if I had a limited.
Live readout is nice to have but idk if I want to go to discount tire every time I rotate my wheels. Programmer setup seems expensive. Rubber valve stems have more give too... Torn.
Old 11-29-2020, 08:06 PM #6
Cisco Kid's Avatar
Cisco Kid Cisco Kid is offline
Real Name: Jeff
Cisco Kid will become famous soon enough
Cisco Kid's Avatar
Real Name: Jeff
From the research I’ve done, none of the 5th gens had 5 tpms sensors until the ‘15 or ‘16 Limited. That may have changed with the most current model years though. Right now I have 5 sensors installed on my ‘13 Trail but the system will only allow 4 sensors to be programmed. The fifth sensor field is there but you can’t do anything with it.
2015 Limited, bone stock for now
Cisco Kid is offline   Reply With QuoteReply With Quote
Old 11-29-2020, 08:21 PM #7
Yeah I'm thinking about that option. Just one more step due to technology...
Haven't really started researching, but if the unit is too expensive, my tire guy might be inclined to do it for free....
Between outfits.
Old 11-29-2020, 08:43 PM #8
Banned
Banned
Discount does it for free but I don’t want to go every time i rotate.
Old 11-29-2020, 09:11 PM #9
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
I used to rotate and change wheel sets seasonally on my Audis, but now I let DT rotate my 5 wheel setup to avoid the TPMS light. I think having a toddler has made me lazy.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 11-29-2020, 10:09 PM #10
Banned
Banned
Some guy in the local truck group says he rotated five on his orp. I wonder if the orp and the limited share that tech feature.
Old 11-30-2020, 02:01 PM #11
Banned
Banned
Really hard to get a straight answer on this. Half the people on other threads I’ve made said it will work others say it won’t and idk who speaking from experience or not.
Old 11-30-2020, 02:30 PM #12
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
I don't rotate 5 tires, it hasn't been shown to be vastly cost effective over the life of the tires or the vehicle but YMMV.
My understanding is the T4R has 4 sensors and will only monitor 4 of them, and I know for a FACT my spare doesn't have a sensor, and the guys running and rotating 5 tires are probably just running 4 sensors with the spare in play having none or if they did install a sensor, it's not talking to the truck.
Most Toyota dealers will tell you there either is or isn't a sensor in the spare, my experience with two 4Runners, a 2013 and a 2015 is that there isn't, but seeing how the system is set up it only seems set up to "talk" to 4 tires, so even if you do have a fifth sensor, it's probably going to just talk to 4 of them and ignore one. It's not a very "smart" system to start off with.
This is the most likely theory I have.
Edit: apparently the newer ones *might* have them? Figuring out which might be another story. I'm in the process of getting a 2020 for my daughter, if I do, I'll bleed the spare to see if I can get the TPMS to go all REEEEE.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 12-02-2020, 11:46 AM #13
Banned
Banned
Discount said my tpms isn’t registering aka dead. Service manager stated the 5th couldn’t be added (grain of salt taken).
He let me get my 5th mounted and balanced with a rubber valve stem no questions asked. Only charged me seven doll hairs.
Looks like I’ll have to use my eyeballs and a mechanical gauge. How ever will I survive.
Shame tho. Seems like an antiquated tpms setup. There should be a reset button too.
Old 12-02-2020, 11:48 AM #14
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
That's weird because my 4th gen Limited senses the spare TPMS. Weird how they would go backwards on that.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
Old 12-02-2020, 12:26 PM #15
rochmpr's Avatar
rochmpr rochmpr is offline
Real Name: Krister
rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all
rochmpr's Avatar
Real Name: Krister
4runner can recognize 5 TPMS. I had 5 installed and always did 5 tire rotations with no issues. Wish the Tundra had the same capacity.
Sent from my SM-G965U using Tapatalk
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
rochmpr is offline   Reply With QuoteReply With Quote
running , simple , stems , tpms , valve
TPMS and tire rotation on 2017 LE BettysNephew 5th gen T4Rs 26 07-31-2017 09:12 AM
5 tire/wheel rotation, buy TPMS? munkel Engines / Suspension / Wheels / Tires / Audio / Accessories 1 08-19-2016 08:21 AM
Tire Valve Stem/TPMS NYC4RUNNER 5th gen T4Rs 5 11-14-2012 12:38 AM
Problem with Valve Stems on '05 LTD dimitri128 Engines / Suspension / Wheels / Tires / Audio / Accessories 12 08-22-2006 04:09 PM
