11-29-2020, 08:33 PM
Ordered 2" Suspension Lift... what's next?
Hello! I've ordered a Eibach Coilover + Rear Adjustable Spring/Shock Kit along with some Dobinsons UCAs; I'm going to adjust this kit to approximately 2 inches of lift all around.
What are some things that would save me headache before getting these installed? Is a 2" lift going to affect my suspension in ways I'm not expecting? I also bought a BMC plate just incase I need to fit larger tires in the future.
Mods are in my signature for an idea of what I'm currently working with. Thanks for your time!
"HANZO" 2015 TRD PRO: SSO Front Bumper w/ Stage 2, SCS F5's (17x9-38), 285/70/17 Falken Wildpeaks, 2" all-around Dobinsons IMS, JBA UCAs, Slee Sliders, BMC, Warn Winch, LED High/Low, DD SS3 Fogs, Rigid Lightbars (Amber/White light), Nise Rack, Extended Diff Breather. Road Trip 2021 - YouTube
11-29-2020, 08:39 PM
Hit the dirt
Surf the sand
Climb over parking lot divider
Enjoy it Mike
11-29-2020, 09:11 PM
Originally Posted by Mudballz
Hit the dirt
Surf the sand
Enjoy it Mike
Haha well that's a given!
Just trying to get ahead of any issues I'll encounter before/after the lift is installed. I've read alot, and I think issues only arise when trying to lift the front/rear over 2 inches, but I'm just making sure I'm not missing anything
11-29-2020, 10:44 PM
With uca on your good for at least 2.5 lift just get a very good alignment and your golden
Mike
11-29-2020, 11:31 PM
Rehab.
At some point, you will end up in rehab to stop the mods.
Until then, I can quit any time I want to!
11-29-2020, 11:34 PM
Real Name: BobH
Real Name: BobH
Maybe Bilstein 5100 or 5160 for the rear to handle 2 inches extra travel ??
11-30-2020, 02:29 AM
The set comes with some rear shocks so I think I'm set! Thanks.
12-01-2020, 12:12 AM
The 4Runner from the factory comes with a slight "rake", i.e. the nose is lower than the back end by about two inches. So, most people raise the front more than the rear, then the vehicle looks "level". Most people think it looks better that way -- more purposeful.
I used the Rough Country leveling kit which raised the front about 2.5 inches and the back one inch.
12-01-2020, 05:23 AM
Thanks! I'll play around with it and see how I like it. Maybe 2" front with 1" rear will be the ticket.
12-01-2020, 09:40 AM
Hit the dirt
Surf the sand
Enjoy it Mike
Basically this honestly.
I did a similar lift last week then went wheeling this past weekend.
You'll learn real fast what you need or didn't need. It's fun to learn as you go.
I'd suggest a front alignment afterwards. I did but my friend did not. He noticed a slight pull and I noticed some slight positive camber
00-JZX100
10-Trail Ed.
12-02-2020, 02:28 AM
I'm starting to gather there's not much adverse effects for a 2" lift all around. I'll definitely get the 4runner aligned after the lift. Thanks!
12-02-2020, 01:20 PM
Can you clarify what you mean by this? How are the rear springs/shocks adjustable?
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
12-03-2020, 02:13 AM
LOAD-LEVELING SYSTEM (Rear) (For +250lbs of Added Weight)
The complete Eibach Coilover suspension kit 2.0 has adjustable height rear springs as well as a height adjustable front coilover. The shocks are none adjustable.
Above is a link to the height adjustable rear springs. Hope this helps!
