Old 11-30-2020, 06:39 PM #1
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Front fender mount chop?
I have 33ish/34ish tires with an aggressive offset. Chopped out a lot of material today trying to get everything happy.
Seems like because of my kdss lean more material has had to come of the passenger side.
I’m potentially going to take out my fender mount under flex. I’ve had to remove the plastic corner cap because the tire makes contact with the only bolt securing it. At one point (prob a while back when I had wheel spacers for a few weeks) I hit that mount pretty good under flex and shook things loose in that corner.
I think people with big wheel setups chop this section? It “could” square off nicely. Just a matter of securing the bottom of the fender.
I figure I’m never going smaller then this tire and may go bigger so might as well get it done?
Front fender mount chop?-b4bc5ea7-2786-45b2-822f-931c8858a073-jpg  Front fender mount chop?-47976c5a-90c1-4768-ab97-3cbc025a0f76-jpg  Front fender mount chop?-1c490c4b-b6c2-4c56-bd49-e8f7c1ea0959-jpg
Mutant138 is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 09:39 PM #2
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Yeah that looks pretty similar to mine. Although My tires don't that close to the outside part of the well. Probably our offsets are different maybe you have less caster? I run right around 5. I do have a zip tie on the passenger side cause the inside attachment point got chewed up
I attached a couple pics although none are while compressed.
Front fender mount chop?-inner-well-jpg  Front fender mount chop?-inner-well-2-jpg  Front fender mount chop?-fender-6-jpg  Front fender mount chop?-fender-5-jpg
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 10:54 PM #3
Banned
Banned
Okay looks like I gotta trim a bit more. Thanks for sharing that.
Maybe not the whole mount. Wonder if anyone other then bushwhacker has some half decent overfenders.
Old 12-01-2020, 12:04 AM #4
cmilviper's Avatar
cmilviper cmilviper is offline
cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice
cmilviper's Avatar
I currently have SCS -10 offset wheels + 1.25'' Spidertrax spacers, which is very similar to the -38 offset you have. I'm also running 285-75-17 Toyo MT's, about 34.1''.
I LOVE the look/stance, but to this day, I am still removing my spacers before I hit the trails for the summer/fall seasons primarily, and at other random times if needed. Without the spacers, I clear off-road with the 34'' tires, no problem...Which is the reason I went with the -10 offset, so that I could remove the spacers, If I hadn't fixed the clearance issues, and still hit the trail.
With the spacers, I am still rubbing when the suspension is compressed, while turning, right there where you are.....the lower fender end-cap/plastic outer wheel well area. I've already cut & hammered some of the metal/lower pinch weld area, but I think I'm about to get a little more aggressive with it so that I can hopefully keep the spacers on full time...It also feels more stable to me with the wider stance, especially off-roading with the roof top tent.
If you hit that area hard enough, and enough times, you'll eventually knock your fenders out of alignment with the doors ect.
Aside from making sure you have max caster, that's about your only other option (more cutting)....aside from new fiberglass fenders ect.
I wouldn't worry so much about the KDSS lean, because it would rub in that same area, off-road with the suspension compressed, anyway. The trick is to clear with the full range of suspension travel, full lock to full lock.
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
cmilviper is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 12:33 AM #5
comtn4x4's Avatar
comtn4x4's Avatar
This is a really good point by @cmilviper , I got one to many good hits in on the pinch welds on my driver side and the fender got out of whack with the door. Took weeks to get it back to close to normal.
Also another add on to cmilvipers comment on offset. I run a pretty uncommon offset, +1 on 9" rims which helps with the rub. Maybe doesn't look as bad a$$, but functionally easier to deal with I think
Old 12-01-2020, 04:58 AM #6
SnoRnR's Avatar
SnoRnR SnoRnR is offline
SnoRnR will become famous soon enough
SnoRnR's Avatar
Hopefully you get it sorted without too much pain. Can’t wait to see the finished article. Is -38 popular in the SCS wheels? I’m looking at SCS was considering -10 but I’d love to fit -38 with 33/34s. I’m going aftermarket front bumper and probably do a BMC.
2019 TRD PRO
Gobi Stealth No-Rise / C4 Fab Sliders / Xenon Depot HID Low LED High / Goose Gear Drawer & Sleeping Platform / RAGO MSP / ARB Dual Compressor / Shrockworks Dual Battery / ARB Differential Breather /
SnoRnR is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 10:48 AM #7
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
running -8mm with 1.25" spacers , going to take some good amount of chopping if you hit the trails. I'm a city driver hah, and i still get some rub with bmc, and knocking in pinchwelds. i am getting a JBFabrications lower control arm pivot installed next week(fingers crossed) that will push my lower arms 1" forward. That should give me everything i need.
The wider stance is awesome for road feel. 4runner felt very unstable with just -8mm and no spacers.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 11:07 AM #8
ragin_cajun ragin_cajun is offline
ragin_cajun will become famous soon enough
I'm surprised you are getting that much rub on a 285/70, I looked through and didn't see mention of your offset other than it was aggressive. What is your suspension setup like?
ragin_cajun is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 11:15 AM #9
rayofsi's Avatar
rayofsi's Avatar
-38MM offset is tough to deal with.
Old 12-01-2020, 11:27 AM #10
Banned
Banned
Thanks for the contributions. My -10’s required a fair amount of chopping too so if anything it’s my unwillingness to sacrifice alignment for less chopping. At this point the fender mount is already somewhat compromised from rubbing on both sides and body alignment is... so so (without me hammering welds flat).
Anyone else care to share there chop setup lol.
I wonder if the dirt king or total chaos kdss LCA can help at all...
I really like how they relocated the tab for a fiberglass fender on this fitting 35’s article... photo won’t upload tho. Basically they cut out the original mount and put the tab up on the cab corner and put 3m undercoating over the flattened pinch welds.
I’m confident enough that my welding skills are poor enough for me to burn through the mounting tab first go with the gun. I wonder tho if I could jb weld or liquid nails the crap out of a tab.
Old 12-01-2020, 11:59 AM #11
rayofsi's Avatar
rayofsi's Avatar
Tacoma 05-15 Lower Arm Pivots
– JD Fabrication
have you seen this? Someone posted this and i ordered just recently. install next week. Some differences in mounting points, but i think any competent shop should be able to do it. I read the whole tacoworld thread on these, and they seem like a good idea.
Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s | Tacoma World
its a long thread.
i am running 285/75 on -40mm offset, wheels/spacers
Old 12-01-2020, 12:03 PM #12
I'm running a 18" -10 on my 2018, but have the Total Chaos UCA. I've also spaced the rear to eliminate the KDSS lean within very minimal variation from empty to full tank of gas.
Old 12-01-2020, 12:09 PM #13
Banned
Banned
– JD Fabrication
its a long thread.
I have kdss. It’s not coming out till/if it fails. Then long travel.
Old 12-01-2020, 12:23 PM #14
comtn4x4's Avatar
comtn4x4's Avatar
Mutant, what's your caster?
Old 12-01-2020, 01:42 PM #15
Banned
Banned
4-5 something like that
Working on it rn. Still made some awful sounds on the way to and from Ace to pickup cut off wheels for the Dremel.
Hopping this will work...
Front fender mount chop?-7fb76a3e-0b35-4a3d-ad54-a9c898c842f6-jpg
corner , fender , flex , mount , wheel
Body Mount Chop?? Doozi 4th Gen T4Rs 16 05-04-2023 09:21 AM
Mount Chop Mod Necessary? eRock_runner 5th gen T4Rs 44 11-24-2020 10:22 AM
13 LTD Body Mount Chop ? Shogun 5th gen T4Rs 1 02-19-2018 07:51 PM
Need body mount chop in OC Ttn333 So Cal 14 06-25-2015 06:00 PM
Body Mount Chop? 01grander 4th Gen T4Rs 8 04-01-2013 01:01 AM
