Old 12-01-2020, 01:44 PM #16
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Here is a better shot.
Front fender mount chop?-1d60ae6c-a1d9-4b61-b1e1-e49d56418002-jpg
Mutant138 is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 01:47 PM #17
Banned
Banned
Cozy
Front fender mount chop?-59fe4f40-3e84-4f87-a41b-df77a261d80a-jpg
Old 12-01-2020, 02:07 PM #18
Banned
Banned
Drivers side I didn’t go as crazy on. We will see how it goes. Slowly but surely.
That’s it for working on it today.
Front fender mount chop?-734d1048-37ed-4bc2-9bba-4a7f65fa5cdb-jpg
Old 12-01-2020, 02:54 PM #19
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Originally Posted by Mutant138 View Post
4-5 something like that
Working on it rn. Still made some awful sounds on the way to and from Ace to pickup cut off wheels for the Dremel.
Hopping this will work...
Good luck, this can be a very frustrating process. I wasn't able to resolve my rubbing with 285/75's and 305/70's till I got the caster to 5*.
So your saying it's rubbing now even going over curbs?
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 03:06 PM #20
Banned
Banned
It shouldn’t now I hope lol. Cut everything out with rub marks.
Truck could prob use an alignment anyways so will see about getting 5 degrees.
Old 12-01-2020, 03:09 PM #21
rochmpr's Avatar
rochmpr rochmpr is offline
Real Name: Krister
rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all
rochmpr's Avatar
Real Name: Krister
Cut it out. I did that a long time ago with the bottom of the fender flare as well. Had to use a self tapping screw to secure the bottom of the fender to the body afterwards, which was in a very nondescript location.
Sent from my SM-G965U using Tapatalk
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
rochmpr is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 03:13 PM #22
Banned
Banned
See that was my next thought too.
Just cut out the bs. Bend the fender tab and secure it.
I sure would like to see a pic of that.
Old 12-01-2020, 04:09 PM #23
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
i went the 295 setup on -38 scs. Mine is about where yours is at (latest post) but was able to snap the black cap back on.
Think my caster is around 4.5?
Not much help but hopefully confidence your almost there.
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 04:41 PM #24
rochmpr's Avatar
Real Name: Krister
rochmpr's Avatar
Real Name: Krister
The first picture shows about where i cut it. The second, shows how it looked when I took an inch out of the fenders for the 315/75's
Front fender mount chop?-bmc-2-1-jpg
Front fender mount chop?-20180423_100251-1-jpg
Old 12-01-2020, 05:38 PM #25
Banned
Banned
Nice man thanks for the input. I figure with these cuts I'm halfway to 35's.
Wow you cut out a ton. I'm definitely considering this.
Old 12-02-2020, 01:51 AM #26
Banned
Banned
Just for informations sake. The way it’s cut now I’m no longer rubbing on normal road conditions.
I’m still betting on rubbing under flex.
Planning on testing on it this weekend. Debating cutting more before going.
Still debating cutting the mounts off and securing the fender to the body. Need to take a better look back there, get my hands on the body/fender again, and think on it.
Old 12-03-2020, 04:16 PM #27
ragin_cajun ragin_cajun is offline
ragin_cajun will become famous soon enough
Good Luck! Such a frustrating process, you don't want to go too far, but you just want it to be over with!
ragin_cajun is offline   Reply With QuoteReply With Quote
corner , fender , flex , mount , wheel
Body Mount Chop?? Doozi 4th Gen T4Rs 16 05-04-2023 09:21 AM
Mount Chop Mod Necessary? eRock_runner 5th gen T4Rs 44 11-24-2020 10:22 AM
13 LTD Body Mount Chop ? Shogun 5th gen T4Rs 1 02-19-2018 07:51 PM
Need body mount chop in OC Ttn333 So Cal 14 06-25-2015 06:00 PM
Body Mount Chop? 01grander 4th Gen T4Rs 8 04-01-2013 01:01 AM
