06-07-2021, 10:46 AM
Do I need new bump stops?
I have a OME 3 inch lift and went to 33 inch tires. I am using the stock bump stops and never thought about upgrading them or anything. I do notice that when I hit a bump it is like riding over a brick.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
06-07-2021, 11:02 AM
"heavy springs" might have something to do with that.
all you need to verify is that the shocks arent the limiting factor to your up travel, if they are you will blow them out. Make sure the bump stops engage before the shocks bottom out. cycling the suspension without the springs, just the shocks installed is the best way. The rear is easier to do obviously.
06-07-2021, 12:09 PM
You can get away without them. But adding Durobumps definitely softened up those landings.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
06-07-2021, 01:12 PM
+1 for Durobumps. Even vehicles that don't off road should have these as it makes everything from speed bumps and deeper dips to heavy duty off roading a much smoother experience.
And yes, ensure your shocks aren't bottoming out first. There are bump stop extensions that push them downward to engage earlier. It's basically just a block of metal lol.
06-07-2021, 02:04 PM
It was OME shocks and spring all around and I added Dirt King UCA's. How do I make sure the shocks aren't bottoming out?
The Build
06-07-2021, 02:26 PM
With the frame supported high enough, take the springs out, leave the shocks mounted and cycle the suspension with a jack until either the bump stops begin to engage or if the shocks begin to bottom out then measure how much the bump stops need to come down to prevent the shock from hitting itself.
06-07-2021, 03:07 PM
I'm weary of those extensions and the factory bumps, I have around 2.5" lift in the rear and I hit my factory height bumps still
06-07-2021, 03:44 PM
All depends on shock body lengths. If the collapsed length allows for the stock bump stop height, I think that's preferable.
I know one of Toytec's rear kits uses the extension, and wasn't sure as to why, but I imagine it's to have a longer shock body which increases oil capacity. Anyone else know why they do this?
06-07-2021, 04:10 PM
they call it a "long travel" kit for the rear. it gets alot of droop but it also limits up travel so the shock doesnt top out. i think thats the one youre referring to.
06-08-2021, 12:48 PM
the aftermarket bump stops are softer than stock... So even if you hit, its softer, vs. a sudden jolting stop.
06-08-2021, 01:33 PM
I tell everyone basically this:
If you do the type of driving where you do bottom out, and often, upgrading the bump stops is a great idea so that you get a softer absorption when it does bottom out.
The stock ones are really quite firm.
And yeah, some extended length shocks require them due to their longer compressed length (they would bottom out before the bump stops would engage), but in OP's case, that won't happen with the OME's. He just needs better rear bump stops. I run Timbren on my 4runner.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
06-08-2021, 01:56 PM
I just posted a set of Duro Bumpstops (brand new in bag) under the For Sale section...
2016 4Runner Trail Premium...Delivered 1/22/2016. Mods: OME Lift, Husky WeatherBeaters, Interior/Exterior LED, Console Vault, AVS Hood and Side Window Deflectors, 275/70/17 BFG KO2, Rigid Dually SAE fog lights, Rigid 20" E2 Hyperspot, Garmin Dash Cam 55, ToyTec HIDs, Aiden James Saber Pro LED high-beam bulbs.
