Old 12-04-2020, 04:10 PM #1
videopuppy videopuppy is offline
videopuppy is on a distinguished road
1GR-FE typically a noisey motor?
I've had two 1GR-FE's and they both seem loud to me, sounds like valve train noise, but most will probably say its fuel injectors. Definitely more pronounced when cold and higher RPM's.
Anyone have any insight.... is this a "noisey" engine? Is the noise mostly from injectors or does this engine have a normal amount (normal = loud engine) of valve train noise?
TIA
Dave
videopuppy is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 04:13 PM #2
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Yes. Both in the 4Runner and FJ Cruiser flavors.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 04:39 PM #3
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Yes, the 3.4 made valve noise too. Its the sound of 300,000 miles. The additives in Toyota/Lexus oil may help. I'm using 5 quarts Mobil 1 and 1.5 qts of Lexus oil. It may be a little quieter? IDK if its the valve train or the injectors or something else. Do you have an insulated hood? Some 4runners have insulation under the hood.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 04:44 PM #4
smeerun's Avatar
smeerun smeerun is offline
smeerun has a spectacular aura about smeerun has a spectacular aura about smeerun has a spectacular aura about
smeerun's Avatar
When I first bought mine I had the same question: "Is my engine supposed to be this noisy? It sounds like a god damn diesel sometimes!"
All is normal friend: Engine noise sounds like diesel at idle
[Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
smeerun is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 05:29 PM #5
tls3601 tls3601 is offline
Real Name: Tom
tls3601 will become famous soon enough tls3601 will become famous soon enough
Real Name: Tom
My gear head friend says the injectors are noisy on them. I do think part of it is valvetrain noise though and mine is noisier when cold.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
tls3601 is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 05:51 PM #6
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
TIA
Dave
What kind of noise? If it is a soft clicking noise (sounds like a diesel engine), then it is the valves/lifters. If it is whirring noise, it is the cam shaft chains. Toyota is one of the few cars that use a chain for the cam shafts, unlike the rubber belts others use.
If either noise is soft, that is normal. I've never heard of fuel injectors making noise.
fkheath is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 11:11 PM #7
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
I wonder if that is carry-over from comments made at tacomaworld.com
Some people over there claim the single VVT-i engine noises originate from the fuel injectors.
In my opinion, if that's true, then someone has some really good hearing.
Whatever.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 12-05-2020, 07:17 AM #8
Matt831 Matt831 is offline
Matt831 will become famous soon enough
Not according to Scotty:
The End of Toyota Reliability - YouTube
Matt831 is offline   Reply With QuoteReply With Quote
Old 12-05-2020, 09:10 AM #9
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
Scotty is a pretty bright guy but definitely skeptical of every car manufacturer on the planet!
My last two 05 4.0 Tacomas were noisy especially when cold and my 4Runner is a bit noisier. Coming out of my development in the morning uphill it actually sounds pretty bad. However I have never heard a 5th gen that sounded any different and there are lots of them out there with well over 200k miles going strong. Mine hasn't hit 80k yet.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 12-05-2020, 01:01 PM #10
Real Name: Sparky
Real Name: Sparky
Mine has been called a UPS truck.
My California neighbors had complained to me about my “modified exhaust” and I told them it’s 100% stock, then another neighbor bought one and his is just as loud.
My FJC was just as bad.
Old and (c)rusty.
Old 12-05-2020, 01:17 PM #11
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Originally Posted by Matt831 View Post
Scotty checked the live data and found issues that don't make sense. Acceleration Sensor Voltage% fluctuating 15.6-16.0% at idle, Long Term Fuel Trims ranging from -3.9 to -4.7% which shouldn't be that high on a new vehicle. Lastly, Evaporative Emission monitor data incomplete, and Catalyst Monitoring Data Incomplete when the computer had not been reset or the battery disconnected. There were no codes. He thinks something is amiss in the electronics ... it's just not bad enough to throw a code.
Has anyone scanned their noisy vehicle and found anything?
Has anyone changed from 0W20 to 5W30 and eliminated the noise?
DougR is offline   Reply With QuoteReply With Quote
Old 12-05-2020, 01:31 PM #12
Real Name: Sparky
Real Name: Sparky
Scotty is a sperg who throws out unsubstantiated bullshit on his channel for clicks.
The fact he hasn’t been sued by car manufacturers for his ridiculous claims just shows you nobody takes him seriously.
Old and (c)rusty.
Old 12-05-2020, 01:43 PM #13
But....he is making money doing it.
Old 12-05-2020, 01:44 PM #14
Real Name: Sparky
Real Name: Sparky
Wait until he says something really inflammatory. Some corporation will shove a boot up his ass.
Old and (c)rusty.
Old 12-05-2020, 01:46 PM #15
DougR's Avatar
DougR's Avatar
I'm not talking about Scotty's character! I'm talking about the scan data! What is your diagnosis for those readings? What would you say about the fuel trims and incomplete data?
My question is directed to anybody with a noisy engine who has the capability to do a professional level scan of live and stored data. I'm also asking if anyone eliminated noise using 5W30.
engine , injectors , noise , train , valve
think my motor died last night( motor swap to jdm engine ?"s) IERunner 3rd gen T4Rs 32 08-20-2015 12:30 AM
when do struts, shocks, springs, typically need to be replaced? NJshadow93 4th Gen T4Rs 2 10-04-2011 12:54 AM
Noisey sunroof muddyYota 5th gen T4Rs 15 06-24-2011 11:19 PM
Noisey driver side seat beeper 4th Gen T4Rs 11 01-20-2007 01:40 PM
Do Oxygen sensors typically go out in pairs? phil123 Problems & Warranty Issues 14 09-11-2006 01:13 PM
