Old 12-07-2020, 10:49 PM #1
Quiero Quiero is offline
Quiero is on a distinguished road
Are the TRD OR's factory lifted a bit? AKA is my truck lifted?
I bought a new to me TRD ORP which came as a CPO '18 with brand new 32" KO2's. Zero rubbing.
Is it just me or is it also lifted a bit? Compared to a plain jane SR5 it is, but I wondered if it was factory. It has Toyota marked shocks, black springs that look stock.
Edit: pics are not showing up =\. Does this place not like Imgur?
Quiero is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 11:09 PM #2
Engineer's Avatar
Engineer Engineer is offline
Real Name: Charles
Engineer has a spectacular aura about Engineer has a spectacular aura about
Engineer's Avatar
Real Name: Charles
unless something changed recently no - only the TRD pros come with a lift (small factory front IIRC)
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
Engineer is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 11:36 PM #3
Snowtrooper Snowtrooper is offline
Snowtrooper will become famous soon enough Snowtrooper will become famous soon enough
I’ve ran 32” KO2 on a TRD ORP 18’ for quite some time. Upon installation, the truck immediately looked taller than when it had the stock duellers. As far as I know, shocks/ springs are the same as the sr5.
The TRD pros are allegedly an inch taller up front but visually I can’t tell against my buddies’ 2020 pro when he was on his stock tires.
Snowtrooper is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 11:43 PM #4
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
It's the exact same suspension as the "plain jane SR5".
32s as in 265/70r17 (the stock size)???
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 11:44 PM #5
smeerun's Avatar
smeerun smeerun is offline
smeerun has a spectacular aura about smeerun has a spectacular aura about smeerun has a spectacular aura about
smeerun's Avatar
You forgot the ".jpg" in the image link... Hope this helps!
Rig looks sweet btw! 32" 265/70/17 is stock.
[Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
smeerun is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 11:51 PM #6
I’m going to guess the stock sized KO2 have slightly bigger circumference than oem tires, due to tread pattern.
Old 12-08-2020, 12:32 AM #7
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Not so. I replaced my OEM tires with the KO2 in the same size. The diameter specs are the same.
fkheath is offline   Reply With QuoteReply With Quote
Old 12-08-2020, 12:40 AM #8
Since the 4Runners from the factory are "raked" (nose down) by about two inches, most people "level" them by raising the front more than the rear.
You can check the level by measuring the distance from the center of the wheel to the bottom of the fender edge above the wheel. If your 4Runner is level, those distances will be the same.
I installed the Rough Country leveling kit on my SR5 which raises the front 2-3 inches and rear only one inch.
It is hard to tell from your picture, but it looks like your 4Runner is still raked.
Old 12-10-2020, 01:41 PM #9
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
the KO2s are slightly larger than the factory tires, but it's mostly just cause it looks more aggressive
jhguth is offline   Reply With QuoteReply With Quote
Old 12-10-2020, 08:38 PM #10
This is what I thought too as I’ve had them side by side. KO2 is definitely a tad taller due to the more aggressive tread but not by much.
bit , compared , factory , lifted , trd
Finally lifted my truck! Fermn 5th gen T4Rs 27 08-07-2020 01:29 AM
My truck went crazy after getting lifted... WTF dRGNpHNX 5th gen T4Rs 23 01-15-2018 05:48 PM
Jacking up your lifted truck Ther00ster 4th Gen T4Rs 17 01-29-2017 09:03 AM
Outdoing my buddys lifted Locked and lifted FJ on Chinaman Gulch JayRolla 3rd gen T4Rs 19 06-28-2015 03:01 AM
Lifting a lifted truck... TNTramair General Discussions 7 08-23-2012 09:12 AM
