Old 12-17-2020, 04:37 PM #1
amir_gh's Avatar
amir_gh amir_gh is offline
amir_gh will become famous soon enough
amir_gh's Avatar
XB Headlight top corner DRL issue
Put me on the list too. I wish they were more reliable. The DRL strips started to flicker for passenger side.I really need reliable LED headlight housing for my truck. I got them from headlight revolution. I hope at least they send me replacement quickly.
amir_gh is offline   Reply With QuoteReply With Quote
Old 12-17-2020, 05:35 PM #2
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Originally Posted by amir_gh View Post
Put me on the list too. I wish they were more reliable. I really need reliable LED headlight housing for my truck.
Check your battery and charging system. I did my retrofit about 7 years ago now, my morimotos still work perfectly, but do have a tendency to flicker if they are running on a weak battery.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 12-17-2020, 05:36 PM #3
amir_gh's Avatar
amir_gh's Avatar
I replaced my battery six month ago. I am sure its the headlight because iits only the passenger side.
Old 12-17-2020, 07:21 PM #4
kelkins kelkins is offline
kelkins will become famous soon enough
Yeah, mine have bit the dust twice now. Is it the corner led? I would request that you return both of yours for the 2nd gen models. A member on this forum was able to do just that not too long ago.
Be prepared for a “warranty charge” on your credit card. They do refund it, but the cost will be hundreds of dollars.
kelkins is offline   Reply With QuoteReply With Quote
Old 12-17-2020, 07:46 PM #5
Jono.ful's Avatar
Jono.ful's Avatar
Same deal here - but it's my driver's side that flickers when the juice is low. A relatively new battery is unlikely to be the cause of your issue, but it wouldn't be the first time I've heard about a DOA battery. It also doesn't eliminate the possibility of a charging system issue. The check the battery, put a meter on your battery and crank the truck over, watch for the voltage to drop significantly. To check the charging system, let the truck warm up and meter the battery, you should see about 14v.
Old 12-18-2020, 10:09 AM #6
amir_gh's Avatar
amir_gh's Avatar
Battery and charger are fine.
gen , headlight , housing , led , reliable
Flickering light bar Samm25 4th Gen T4Rs 11 05-25-2018 03:46 PM
Flickering Fog Lights ChildrenOfBodom 3rd gen T4Rs 10 05-13-2011 02:28 AM
HeadLights Flickering chip4rnr Classic T4Rs 0 02-05-2011 10:11 PM
Speakers flickering on and off Localmotion Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-15-2004 01:45 PM
