Originally Posted by Jakeepoo3
That's correct. It mounts on the front member your tow I mean "recovery" points are welded through. I don't think plastic would do the trick.
I know the piece you mean, but the limited has a plastic section that bolts from the metal rad bar to the front plastic spoiler rear. The front section is plastic to plastic. Its only the rear connection that is plastic to metal. I have the plastic sandwhich piece that fits in there sitting in my garage. Now theres a gap as it doesnt fit right with the RCI skid plate. There is no metal under the the front of the limited plastic bumper at the bottom. The metal begins after the gap which is about 6 inches or so. Ill get you a pic if you want to see it.
