How to correctly store tires? | Continental tires
"In cold weather or in warm, tires should never be stored in the open air, even under a protective covering. Think cool, dry, moderately ventilated – and of course out of the sun. Your basement or another climate-controlled space is ideal. If there is a heat source in the room, the tires must be shielded from it. Most garages, sheds and attics undergo a range of temperatures, precipitation and humidity. You want to avoid these fluctuations."
michelin says:
Tire Storage | Michelin
"If you are storing outdoors (recommended for a short time only), raise tires off the ground and use waterproof covering with holes to prevent moisture build-up."
I think the garage is fine. I leave my BMW motorcycle there unmoved for 6 months. Now to find room.
