Old 12-15-2020, 12:56 PM #16
G-Cam G-Cam is offline
G-Cam is on a distinguished road
Originally Posted by fkheath View Post
Does your $1100 CAD include labor -- it must for the part only costs $400 US (2019 Toyota 4Runner Suspension Control Arm (Right, Front, Lower) - 4806860051 - Genuine Toyota Part) and can be found for less (Amazon.com: TOYOTA 48068-60051 Suspension Arm Sub Assembly: Automotive).
Even with the different exchange rates, the cost for the arm alone is far less than your $1100.
Edit: My bad! I just realized you need to buy TWO LCA, while the price I quoted is for singles.
Yes, both arms will be around $1,050 CAD (not including labour).
'12 Trail
Icon Stage 4 Billet
Stealth 6 Wheels with KO2's
Sliders
G-Cam is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 12:58 PM #17
Originally Posted by Jeremy556 View Post
Also need to figure in the replacement mounting hardware. Assume it will all have to be cut out. Here's what I used,
Luckily, my cam bolts actually move very easily, I have had a few alignments done in the past couple years.
'12 Trail
Icon Stage 4 Billet
Sliders
Old 12-15-2020, 12:59 PM #18
Originally Posted by y=mx+b View Post
Another option would be to rebuild your LCA. I used the Whiteline bushings. I've only had them on 4-5k miles, so no long term reviews from me, but they seem to be well recoginzed in the subaru and rally communities. Quality felt great and I expect them to way oulast any cheap LCA options. Ball joint brand is a hot debate, but Sankei 555 I've heard are great. I used Import Directs on a recommendation from another member that wheels pretty hard, no complaints with them either-boot quality felt really good.
I have a writeup where I cover both the LBJ and bushing replacement. You'd probably have to disregard the cam hardware PNs since I believe the 5th gen rear cam is larger, but the Whitelines came with a larger sleeve for the rear bushing for the 5th gens: Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures). Let me know if you have any questions, feel free to tag me or anything to get my attention, as I don't visit the 5th gen section as often
Great write up! Thanks for your input!
'12 Trail
Icon Stage 4 Billet
Sliders
Old 12-15-2020, 01:00 PM #19
One last thought: you say your trusted service guy says you need new LBJs. Never hurts to get a second opinion. The factory repair manual (cited earlier) gives the procedure for checking the LBJ. It is quite easily done.
I can't get that manual to open? Can you give me a quick run down on how to check them? Thanks!
'12 Trail
Icon Stage 4 Billet
Sliders
Old 12-15-2020, 01:01 PM #20
Originally Posted by 4runninDrew View Post
So, I have replaced many lower ball joints on tacomas. They are a slightly different arm than a 4runner LCA. For whatever reason the tacoma ball joints wear out and start to become loose, fairly often. The 4runner ball joint is way more solid. It depends what you want to do in terms of cost/durability. You can either replace the whole arm(s) and depending on where you live, the cam adjusters if they have seized, and then do an alignment. Or alternatively, you could replace the ball joint, but will have to be with an aftermarket one, which likely won't last quite the same as factory. I've done a couple 4runner ball joints, and when I've tried pressing the new one in, the control arm is just slightly too thick, so I've had to grind down a millimeter or two of the top, so that the new snap ring will fit.
What brand ball joint have you used?
'12 Trail
Icon Stage 4 Billet
Sliders
Old 12-15-2020, 11:06 PM #21
4runninDrew 4runninDrew is offline
4runninDrew is on a distinguished road
Mainly Moog, you can definitely get some decent miles out of them. But nothing compared to the OE arm w/joint.
4runninDrew is offline   Reply With QuoteReply With Quote
ball , joint , kdss , part , runner
Lower Ball Joint Chilow 5th gen T4Rs 3 07-22-2020 11:14 PM
Upper Ball Joint/Lower ball joint replacement Tigerfan86 4th Gen T4Rs 1 03-03-2020 03:10 PM
Tie Rod & Lower ball joint DannyLlama 5th gen T4Rs 26 10-29-2016 11:45 PM
Lower ball joint nut Stiles97 3rd gen T4Rs 7 07-25-2016 10:59 PM
2003 Lower Control Arm/Lower Ball Joint replacement Wahoo96 4th Gen T4Rs 5 01-30-2015 02:16 PM
