12-11-2020, 12:21 AM
Real Name: Derrick
Real Name: Derrick
Thinking of going from 35's to 37's
I took advantage of the Black Friday sale AFC was having and purchased their fenders. The fenders have a 3" flare and 2" rise. I think we these fenders, I should now be able to clear 37" tires (I currently have 35s and they fit fine). I believe the front will fit, my question is will the rears fit or will I have to make more modifications in back to make it work.
Who has 37s and what did you do in the back to make them fit, if anything? Please let me know, thanks.
2015 Toyota 4Runner Trail Edition
Havik's Build Thread
12-11-2020, 01:44 AM
Real Name: Sparky
Real Name: Sparky
What are the vehicles in their promotional photos running?
Old and (c)rusty.
12-11-2020, 01:37 PM
To fit 37’s, the fabrication is extensive. The fender is not where the issues are. Check out this post from @amg_t4r on Instagram.
Login • Instagram
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
12-11-2020, 03:15 PM
Banned
Real Name: Tobias Fünke
Banned
Login • Instagram
Lmao
12-11-2020, 03:29 PM
Might be worth looking through.
cbielat's 2011 SR5 Build Thread
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
12-11-2020, 04:49 PM
Real Name: Derrick
Real Name: Derrick
Originally Posted by ryguytheman
Thanks, from his build it looks like the rears fit fine. I think with the glass fenders up front, I should be good to go. I've already done a lot of work like bending back or trimming pinch welds, etc.
12-11-2020, 05:39 PM
Originally Posted by Mutant138
Lmao
It's just a flesh wound.
12-11-2020, 08:15 PM
Real Name: MURDERED TRD
Login • Instagram
Looks like a Terminator arrived at that location.
12-12-2020, 01:22 PM
39's or GTFO!
12-12-2020, 05:05 PM
Id be more concerned about reliability of steering and drivetrain components than clearance when you go that big. When increasing the rolling mass that dramatically OEM components are destined to fail. It's probably fine for pavement and forest service road folks but not so much for people who drive offroad with any significance.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
12-12-2020, 06:27 PM
JD Fabrication Lower Arm Pivots
If I was looking at 37s I would do this instead of chopping the body apart. Moves the front LCA forward up to 1". The front seems to have much more room for clearance.
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
12-13-2020, 01:02 AM
Originally Posted by nimby
39's or GTFO!
Go big, or go home
12-13-2020, 05:13 PM
This is the solution. The marlin crawler long travel setup works great. The original Marlon crawler truck before the Marlin crawler long travel in-house design used an all-pro long travel that was relocated forward about 2 inches. That worked really well also. And that clears 40s. front range off road also has a 3rd gen 4Runner with a very similar setup.
At some point the axles are going to find the limit with the weight of the 4Runner and bigger tires. The steering rack is another concern id have. I'm not sure if you'll break it or not, but what I found is when I'm bound up in the rocks even on 34-in tires I sometimes can't turn. It simply doesn't have enough force and short of trying to really crank the steering wheel and break something, It just doesn't have enough force in the rack to move. I think that's why the Marlin system uses a heavy duty tundra size steering rack.
12-13-2020, 05:46 PM
There's a guy running 37's I saw on YouTube. I think he had to get quite a lot of work done as well.
Here's his video showing everything
https://www.youtube.com/watch?v=qDWvJ2BPIkY
YouTube
12-15-2020, 03:13 PM
Real Name: Derrick
Real Name: Derrick
I'm not worried about parts breaking, that is part and parcel of the hobby. I am worried about clearance. If I can't clear them, then I can't put them on, so no need to worry about things breaking. If you are worried about parts breaking, don't modify your 4Runner and stay on paved roads.
If I listened to all the nay-sayers, I wouldn't have 35's, a supercharger, 4.88 gears, and I would never do the trails that I have done.
As far as going big or going home... I agree!!! Believe me, if I could fit 40's I'd get them, forget 39's!
