Old 02-11-2021, 10:55 AM #16
1Louder 1Louder is offline
1Louder will become famous soon enough
Originally Posted by PhillySilver View Post
Does anyone know of a similar product without LEDs? I want to add a dual port charger to my 2020 TRDORP and there seems to be a decent number of options but they all have LEDs of some sort. Looking for one without. Don't mean to hijack thread, have not reached my number to start new thread yet.
With mine if the cords are plugged in you don't see the lights. I just always leave the cords in. Some people have taken them a part and pulled the led's. While they may exist I was not able to find one on Amazon. If you don't want one that plugs into an existing switch plate then Blue Sea and other companies have lots of options without an LED.
Dispensing advice 24/7. Usually free and sometimes worthwhile! @4xoa on the gram.
1Louder is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 10:58 AM #17
steraser steraser is offline
steraser will become famous soon enough
OP---have you done this swap yet? I am thinking of going the opposite direction and swapping mine 12V out for the dual USB. Interested in a trade?
steraser is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 11:15 AM #18
PhillySilver PhillySilver is offline
PhillySilver is on a distinguished road
Thanks for the reply. I was thinking of ordering one and trying to carefully take apart and remove the LED.
PhillySilver is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 12:43 PM #19
AgentKooper AgentKooper is offline
AgentKooper will become famous soon enough
Originally Posted by matoolie View Post
I think the USB port is a “port” installed option
When I ordered my 2021, I chose the dual USB as an option and was told it had to be done at the factory (which they were able to do). Don’t know what that means for the OP, but wanted to clarify that.
2021 4Runner TRD Pro (Lunar Rock)
AgentKooper is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 08:47 PM #20
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
Probably dependent on regions. As a result, “officially” could be factory only in some regions. But thanks to internet can be purchased and added at anytime.
Integrated Dual USB Powerport 00016-00225 | Sparks Parts
https://www.ebay.com/p/6024658171
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 11:57 AM #21
aggrobot's Avatar
aggrobot aggrobot is offline
aggrobot will become famous soon enough
aggrobot's Avatar
Originally Posted by luppercut View Post
Do you know if that dual USB port can be purchased? I’m trying to find one like it.
I was able to order dual USB port/plugs and have it installed through the dealership. I had it done about a week after I bought my limited. I never used the cigarette lighter, but my limited still has a lighter ‘port’ in the armrest.
aggrobot is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 11:10 PM #22
Stembot Stembot is offline
Stembot will become famous soon enough
I installed the 00016-00225 kit last weekend. It cost about $47 from my local dealership. I discovered this mod and got the installation directions from TIS for which I bought a 2-day pass for a separate issue. The installation is very easy, make sure you use the drill template to locate the hole correctly or you risk interference between the port and the console rear vent tube.
Sent from my Pixel 2 using Tapatalk
My GearProject Page
Stembot is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 09:53 PM #23
ltsatch ltsatch is offline
ltsatch is on a distinguished road
Damn, you beat me to it! Have you done the swap yet, will the hole have to be modified for the LED plate?
ltsatch is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 06:33 AM #24
I have not. Looking at a pic of the part on eBay, it looks like no modification is necessary as the part is round behind the plate. I may look around at other aftermarket USB options. It doesn't particularly look "stock" as it sits in front of the dash rather than inset as the data port USB. Another minor annoyance, the cover swings down on the dual port while the cover swings up on the data port. Small but annoying to me. Functionally it should be an easy swap, I'm just a little stuck on the aesthetics and not really in a hurry. I can always use the rear seat Ports if I need to charge multiple devices.
Sent from my Pixel 3 using Tapatalk
Old 03-17-2021, 11:53 PM #25
Not sure which 4R model you have but in my previous 12 Trail I mounted two dual data/charge receptacles in the heat seat blanks in the console. That said it was for an aftermarket Sony head unit so I could have car-play in that 4R. These units fit perfectly flush in the those slots. Also fit in the blank slot to the left of the steering wheel if available. Amazon.com: Cllena High Speed Dual Port USB Car Charger with Audio Socket for Toyota Series,USB Charging for Mobile Phone, Samsung HTC and More (3.3A + Audio)
Remove the 2021 4Runner Dual USB charger & replace it with a normal power socket?-718mhvbcpal-_ac_sl1500_-jpg
Old 10-31-2021, 01:14 PM #26
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
I think the USB port is a “port” installed option for vehicles in Toyota’s southeast region that replaces the cigarette lighter socket from the factory. Toyota Part number 00016-00225. The OP seems to be in GA SO makes sense.
I would think a search of Toyota parts would result in finding the original lighter socket.
Not a huge fan of the kit. It looks more OEM than an adapter plugged into the cigarette lighter, but ...
1) It's not future proof. The world is moving to USB-C and
2) It requires wire tapping, which a lot of folks don't mind, but which always gives me the willies.
But I can see the appeal.
rageandlove is offline   Reply With QuoteReply With Quote
Old 10-31-2021, 02:42 PM #27
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
USB-C on the DEVICE side. Majority of chargers still use USB-A on the brick itself.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 10-31-2021, 05:40 PM #28
achtung6 achtung6 is offline
achtung6 is on a distinguished road
The dual USB power port is a port or dealer (or even user) installed option. The '21 models come from the factory with a 12v outlet next to the dash mounted USB port. I opted to have the 12v outlet replaced with the port installed accessory on my '21 TRD Pro.
I suspect dealers are specifying this option be installed along with other accessories once the trucks arrive in port. I kind of wish I had not ordered this as it's much cheaper to buy yourself, simple to install and I'd still have the 12v outlet which I could place somewhere else in the truck should I choose but that's another matter. When you order this option, the 12v outlet is removed and not included with your truck :-(
achtung6 is offline   Reply With QuoteReply With Quote
Old 10-31-2021, 05:45 PM #29
What they told you is inaccurate. At the port, they removed the 12v outlet and replaced it with the dual USB outlets. I also ordered this (have the same truck as you). I regret it because I paid $200 for this and they left some scratches on the garnish near the plug presumably when they installed this accessory. I could have done this myself and saved $150 AND the scratches to the surrounding plastic.
Old 01-07-2022, 10:25 PM #30
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
I added one of these to the center console storage. Replaced the factory cigarette lighter.
Remove the 2021 4Runner Dual USB charger & replace it with a normal power socket?-1-jpg  Remove the 2021 4Runner Dual USB charger & replace it with a normal power socket?-5-jpg  Remove the 2021 4Runner Dual USB charger & replace it with a normal power socket?-6-jpg
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
charger , detector , i’d , power , radar
Front turn signal dual filament socket with 3 wires available? cwilliams563 4th Gen T4Rs 5 08-05-2020 09:40 PM
Trickle Charger on Dual Battery Setup Havik 5th gen T4Rs 11 03-29-2019 12:05 PM
DC Power Socket (lighter) quit working. Ralph Blake 4th Gen T4Rs 0 10-15-2017 09:49 AM
Can I make my power socket constant? nortex 4th Gen T4Rs 7 06-14-2013 06:39 PM
added 12v power charger - only works when headlights are on?!? matthewkristof Engines / Suspension / Wheels / Tires / Audio / Accessories 2 09-29-2012 06:13 PM
