Old 04-07-2022, 09:04 PM #1
skag1T skag1T is offline
skag1T is on a distinguished road
Temporary remove passenger seat
2018 SR5
I am planning a couple weeks of vacation and planning for an overlanding / camping adventure.
I am thinking to remove the passenger seat to gain some storage space (I already removed the back seats and made a sleeping platform, etc.), I understand it is fairly simple process and need to disconnect the battery before unplugging the airbag harnesses.
My question - after I disconnect the harness and remove the seat, will i have any issues when i re-connect the battery and drive around for a while ?
Is there a dongle I can get to connect to the airbag harness to trick the computer ?
Any input appreciated.
Thanks !
skag1T is offline   Reply With QuoteReply With Quote
Old 04-09-2022, 09:54 PM #2
bootown's Avatar
bootown bootown is offline
bootown is on a distinguished road
bootown's Avatar
Here's my story. I did this in my old Sequoia so that I could fit a kayak inside on a long road trip. Now, I may have forgotten to disconnect the battery when I put the seat back in but I'm not sure. Anyways 4,000 miles later I put the seat back in and the airbag light never went off. Brought it to Toyota. They said the issue could be the seat airbag, a short in the wiring or the ECU. Replacing the ECU was $2,000+ and if it didn't work there was no refund on the part. Seat and wiring checks were also crazy expensive.
I bought a used seat and tried that. Didn't work. Very luckily found a ECU on ebay and that fixed it.
If you do take out the seat none of your airbags will work during that time just fyi
bootown is offline   Reply With QuoteReply With Quote
Old 04-10-2022, 06:37 AM #3
IslandJim's Avatar
IslandJim IslandJim is offline
IslandJim will become famous soon enough
IslandJim's Avatar
Thought that if the air bags were deployed the vehicle wouldn't be able to start up? Wouldn't it do the same thing if the air bags are disconnected?
2019 ORP KDSS MagGrey RSG Sliders/ICS Fab above console mount
IslandJim is offline   Reply With QuoteReply With Quote
Old 04-10-2022, 06:17 PM #4
@bootown - ouch, thank you for that bootown.
okay I will have to re-think this then.
Very annoying that you cannot do what you want with your own car.
Looks like disconnecting the airbag fried the ECU then ?
How about if you keep driving without the seat, will that work indefinitely ?
Old 04-11-2022, 01:35 PM #5
bootown's Avatar
bootown's Avatar
Not necessarily just disconnecting the airbag. It was either driving around with an airbag absent or maybe I forgot to disconnect the battery when I hooked the airbag back up after the trip. I have disconnected the airbags and taken both seats out many times without issue, same for steering wheel airbags, just never reconnected the battery until everything was hooked up again.
Not sure I understand your second question
Old 04-11-2022, 04:20 PM #6
Soneill's Avatar
Soneill Soneill is offline
Soneill will become famous soon enough
Soneill's Avatar
That is only for vehicles that have an inertia switch on the fuel system.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
Soneill is offline   Reply With QuoteReply With Quote
Old 04-11-2022, 05:21 PM #7
Whippersnapper02's Avatar
You'll have to get a scanner that can clear SRS codes. I would just leave the seat in.
Old 08-09-2022, 05:25 PM #8
Born2Wander Born2Wander is offline
Born2Wander is on a distinguished road
I'm planning on doing this so I can put my dog's bed up front – I travel with her for months at a time. I *finally* figured out how to do this with my Sprinter, and had done it before in a Suburban. It came down to finding the right resistor to bridge the airbag harness lead to keep the SRS light from coming on. Found this thread as I'm looking for the correct resistor value for the Toyota.
Born2Wander is offline   Reply With QuoteReply With Quote
Old 08-09-2022, 07:02 PM #9
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
With the seat out, it will trigger the airbag light. The light will go away once reinstalled and maybe a batt reset. The code will stay, so if lets say a dealer scaned it they would find the old stored code and make repairs off that.
Just use a scanner that also does airbag codes and erase it. Autel makes some good scanners cheap that do regular, airbag and abs code reading.
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
airbag , disconnect , harness , remove , seat
How hard is it to remove the passenger fender panel? Pyral 3rd gen T4Rs 13 08-07-2021 04:26 PM
How to remove passenger kick pannel rageandlove 5th gen T4Rs 5 04-23-2021 11:05 AM
How to remove passenger kick panel? seeking3rdgen 4th Gen T4Rs 6 04-21-2021 11:20 PM
Water build up in my passenger side floor and behind passenger seat a4runner97 3rd gen T4Rs 12 03-23-2013 01:48 PM
Little Passenger Seat to make SR5 7 Passenger Dunk50 For Sale: Non-T4R Items 2 10-08-2012 08:28 PM
