Old 12-14-2020, 08:19 PM #1
Bruin1md's Avatar
Bruin1md Bruin1md is offline
Bruin1md is on a distinguished road
Bruin1md's Avatar
Slip Indicator light going on........
..........I hope this hasn't been addressed in a prior thread, so forgive me if it has.
I have a 2020 TRD pro that I've put 11,350 miles on in just over a year.
A few days ago I reversed the truck down my driveway staying on the incline, and then put it back into 'drive' to go up the drive at a very slow speed. When I did so, the slip indicator light went on and I heard that grinding noise for just a second or two.
I took the truck into the dealership on Saturday and they looked at it over the weekend and today. They checked it out thoroughly and told me they couldn't find anything wrong.
They checked the VSC system, TRAC system, active traction control, hill start assist control system, etc: NO issues with any of them. They reassured me of this.
I haven't done any significant off roading yet-- in fact my first venture was set for next month.
Their diagnosis was that the rear tires simply are losing traction for that brief second going back up hill after the car has been reversed downhill, although the stock Nitto's still seem to have good tread.
Has anyone else dealt with this and are there any thoughts as to the cause (i.e. is this simply my rear tires starting to lose traction at 11.5k miles?). Do I need to be concerned and take it to another Toyota dealership?
Other this new issue, the truck has been amazing and running great and I've put several long trips on it.
Bruin1md is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 09:33 PM #2
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
No.
I do not believe you have any issues with the truck or tires... Vehicle stability control (VSC) is very sensitive on all 5th gen 4Runners and when you switched into the drive on the incline your truck probably rolled (moved) backwards a bit (inches..?) consequently triggering VSC... it worked as designed.
FYI: My truck does the same thing.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: http://www.toyota-4runner.org/5th-ge...estion-50.html thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 09:36 PM #3
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Mine also does the same if it detects the car going back just a little on a hill.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 09:46 PM #4
SilverFox2020 SilverFox2020 is offline
SilverFox2020 is on a distinguished road
Sounds like your Runner is doing it’s job. I have a house in the NC mountains up really steep gravel roads with a steep gravel driveway. I exercise my traction control all the time, it makes some strange noises but I’m used to it by now.
SilverFox2020 is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 11:21 PM #5
Bruin1md's Avatar
Bruin1md's Avatar
thanks for the replies and reassurance, guys.
It's just that it's never happened before, so that's why I was a bit alarmed that it's only happening now with the same reverse, and driving forward on an incline (driveway)
Old 12-14-2020, 11:51 PM #6
smeerun's Avatar
smeerun smeerun is offline
smeerun has a spectacular aura about smeerun has a spectacular aura about
smeerun's Avatar
This has happened to me a couple of times and I too thought something was wrong. As others have mentioned, the vehicle is just doing it's job. Love this beast!
[Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo Open Country A/T III 265/70/17 (TE Wheels) | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs (Amber) | Diode Dynamics XPR Backup LEDs | Lasfit Blinker LEDs Front/Rear | Several big items on backorder... :
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Diode Dynamics LEDs (throughout)
smeerun is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 11:27 AM #7
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 has a spectacular aura about shrub1 has a spectacular aura about
shrub1's Avatar
Normal.
shrub1 is offline   Reply With QuoteReply With Quote
drive , put , system , traction , truck
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
VSC/Slip Indicator light always on mrtifftiff 5th gen T4Rs 6 08-24-2019 12:31 AM
Help :slip indicator light albaboun 5th gen T4Rs 1 01-02-2014 10:09 PM
Slip Indicator Light jumpstart 3rd gen T4Rs 2 05-12-2013 03:33 PM
Slip Indicator Light HNTMUP 3rd gen T4Rs 2 01-29-2009 10:27 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
