Old 12-15-2020, 08:27 PM #1
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
3 Way Switch (SPDT) help
I've searched and searched...
short question:
Does anyone know of any 3 way, On/Off/On , SPDT switches that will fit in the factory switch locations?
I know that Meso Customs has made some for his puddle light harness:
Longer question:
I just bought the Diode Dynamics SSC2 LED Pods and they have two functions (Standard light & backlight) and their harness comes with this switch:
I was hoping to replace that with a nice in dash factory looking option, if that's not possible, drilling out a factory blank to put the above switch in might work but it's nearly the same width as the blank...
Open to any ideas or mounting options...
Having said that I would rather not drill a hole for the above switch into the dash.
Thanks.
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 09:00 PM #2
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
short question:
Longer question:
Thanks.
I looked all over for the same kind of switch that you’re looking for and could not find one. What I wound up doing was buying the Meso switch. I’d encourage you to do that also, and soon, since most of his items sell out quickly. Get either the 4Runner switch/harness or the Tacoma variation, it’s the same switch. It’s expensive but was worth it to me.
Your other option is to modify a 4Runner switch blank. Except it’s kind of an ugly job. The backside of the switch has all sorts of extra plastic you have to cut away and it’s kind of a mess.
3 Way Switch (SPDT) help-8e84ba65-36f0-4419-8329-c7be8bc48da5-jpeg  3 Way Switch (SPDT) help-56c2122e-8fea-41cf-bdc7-851d705a3cad-jpeg  3 Way Switch (SPDT) help-a07c5d74-4a47-49dc-a491-b0adb700b596-jpeg
Old 12-15-2020, 09:06 PM #3
jawkdna's Avatar
jawkdna's Avatar
Happy to support Meso..
my only question is his switch has 10 pins and mine has 3...
wiring n00b, not sure where those 3 connections should be made.
XXX
Old 12-15-2020, 09:32 PM #4
jawkdna's Avatar
jawkdna's Avatar
actually, I'm assuming this would be it...
XXX
Old 12-15-2020, 09:52 PM #5
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Check out the light switches made by anytime back up camera.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 10:25 PM #6
jawkdna's Avatar
jawkdna's Avatar
Boom! Exactly what I needed!
THANK YOU
XXX
Old 12-15-2020, 10:27 PM #7
Banned
Real Name: Mark
Banned
Real Name: Mark
Here’s how I used the switch connections for my application. I wired up an anytime control of the puddle lights earlier this year using the Tacoma harness/switch before Meso came out with his wiring harness for the 4Runner.
Check the pins with a multimeter set to ohms to be sure of the switch operation for your setup.
3 Way Switch (SPDT) help-0119cf8d-9ede-4e61-96b2-9b283d11a369-jpeg
Old 12-15-2020, 10:54 PM #8
THANK YOU
I was in your shoes awhile back...Scoured the internet for threads/forums that could provide a solution...nearly gave up and went with that circular switch you posted. Eventually gave up for awhile and then one day on the trail, I turned on my front camera and was like ...LIGHTBULB this switch could work! lo and behold, they make one for lights lol
Old 12-16-2020, 11:00 AM #9
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
I went through the same search when I was wiring my lights in the rear bumper. I wanted to have the option of on/off/auto (when in reverse). I ended up drilling the factory blank and using the Rigid switch. It's ugly so I put it in the Party Mode switch location.
I contacted switch pros and their switch panel didn't have that ability at the time. Don't know if it does now or not.
I was surprised Air On Board didn't have them, or if they did I couldn't find them.
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Old 12-17-2020, 06:05 PM #10
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
Looks like this switch might work in place of the Blue sea PN2146. The big red switch that comes with the ACR for a dual battery set up.
I will have to do more research on this.
Anyone have thoughts on why this wouldn't work in that application?
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 12-19-2020, 06:37 PM #11
jawkdna's Avatar
jawkdna's Avatar
So I've got the anytimebackupcamera.com switch...
now I have no idea how to wire the 3 wires from the the Diode Dynamics harness and 3 way switch to the 6 wires of the anytimebackupcamera.com 3 way switch.
I've searched...
anybody know what's goes into these?
Diode Dynamics 3 way switch
Red=power
Blue=back light
Yellow=normal light
XXX
Old 12-22-2020, 10:57 PM #12
jawkdna's Avatar
jawkdna's Avatar
Bump for help...
XXX
Old 12-23-2020, 09:39 PM #13
Banned
Real Name: Mark
Banned
Real Name: Mark
I've searched...
Red=power
Blue=back light
Yellow=normal light
The anytime website doesn’t have very good documentation. You’ll need to get out your multimeter and flip the switch positions to figure it out. Use a 9 volt battery to verify which pins are used for illumination.
Old 12-23-2020, 09:59 PM #14
Hmmm I forgot how I did mine, could pull the switch out this week and try to figure it out again.
Maybe DD can provide some assistance in this case?
Old 12-24-2020, 06:31 PM #15
jawkdna's Avatar
jawkdna's Avatar
Reached out to DD and they didn't know...
Reached out to Anytimebackupcamera.com and haven't heard back...
Watch a ton of install videos on the Anytimebackupcamera system and finally figured it out...
NOTE this picture is just how I tested the wiring, I clipped the spade connectors and wired and used the proper connectors after I figured out the right connections.
Yellow->Green
Red->Red
Blue->Orange
This will but the mains on in position A, the backlight in position B.
If you want the switch lighted with the dashboard, use the blue & gray plus black ground. I didn't care about that step so I'm done.
Thanks!
XXX
dash , factory , harness , light , switch
AOB Switch Illumination Issue QUESTION/Trouble With Switch Fully Engaging FIX mbumpus11 5th gen T4Rs 11 10-23-2021 03:51 PM
Is rear window switch a SPDT, and ECT PWR a SPST? starclassic 3rd gen T4Rs 2 04-18-2017 09:04 PM
Stupid question. Seat heat switch light. How do you remove the switch? Gavin S. 4th Gen T4Rs 6 02-15-2016 02:02 PM
spdt switch for light bar Stiles97 3rd gen T4Rs 19 12-26-2015 10:42 PM
OEM SPDT/DPDT switch? tbst 3rd gen T4Rs 2 03-18-2015 02:53 PM
