Old 12-20-2020, 12:45 PM #46
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Originally Posted by Rainier42 View Post
Alcohol is the main ingredient in dry-gas. With E10, I don't believe one needs to add anything for water.
Agreed, as long as there is no phase separation.
seatia is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 12:24 PM #47
SoCalRunner's Avatar
SoCalRunner SoCalRunner is offline
SoCalRunner is on a distinguished road
Existing thread?
There should be a thread for "Dealer services to avoid" like the $85 cabin air filter replacement.
2016 T4R TEP | Maxliner floor mat | KO2 285/70/17/C | Precision Interior LEDs | Ceramic window tint | AVS Aeroskin deflector | Rhino Rack Pioneer Platform | SunSeeker Awning | Fox 2.0 front/rear no res | Icon 52700 | VTX Wheels | Side exhaust | Xenon Depot HID Low Beams & LED fogs
Round Rock, Texas
SoCalRunner is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 01:55 PM #48
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
The one cabin air filter they keep in the service department desk that isn't the actual filter they took out of your truck?
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 08:23 PM #49
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
I just did the fuel pump swap thing. Easy service. Drop off. Pick up in a couple hours. No rear seat removal like others have said. And no issues with my aftermarket skid plate.
Dealer wanted to flush my power steering fluid. "It's not burnt, but it's getting close." I'm not really even sure what that means. Dealer actually usually treats me pretty well overall.
And they wanted to do the same top end engine clean. Um... no thanks. This was the first time they've wanted to do this kind of stuff - maybe they're hurting due to covid? Normally they don't try to up-sell me on anything.
The strangest part overall for me was that I'm at 60k and bought a new air filter and cabin filter. And the air filter that is in there looks amazingly clean. Like maybe they swapped it at the last oil change on accident when they got the go-ahead from someone else's 4Runner to change it? Not sure. It looked so clean I ended up not putting the new one in and I'll keep it as a spare. I spend plenty of time on dirt roads and the interior gets full of dust. So either they did it by accident or somehow the 4Runner just gets some amazingly clean air out of the fender well.
Old 12-21-2020, 09:18 PM #50
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Originally Posted by Jetboy View Post
Dealer wanted to flush my power steering fluid. "It's not burnt, but it's getting close." ... And they wanted to do the same top end engine clean. Um... no thanks.
Perhaps they breakeven on warranty work and hope you'll buy a flush so they can turn a profit. Just say, "Thanks for doing the warranty work."
By the way, I siphon out as much as I can out of the power steering fluid reservoir and add the appropriate fluid (Dexron III for my 2011). I did this 4 times at weekly intervals. I used a semi-translucent syringe with a vacuum line extension and I could easily observe the fluid becoming bright red. I now siphon the reservoir once every 6 months and observe the color. If it's still bright red, good, if not, I'll siphon it at weekly intervals until it is.
DougR is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 09:34 PM #51
JeuTheIdit's Avatar
JeuTheIdit JeuTheIdit is offline
JeuTheIdit will become famous soon enough
JeuTheIdit's Avatar
Another good way to do this (which I have done before) - Disconnect the return line, turn steering wheel two full turns, fill reservoir to full, rinse and repeat until clean fluid comes out, connect return line. I try to do this every few years.
2013 Classic Silver TE w/ KDSS - 125k miles
Raptor lined bumpers, fender flares, valences, badges | Goose gear plate | Sound deadening | Hood scoop delete | Tundra fogs | H9 + 9011 bulbs | RCI Skids | Dobinsons C59-300 and C59-599 | Ironman UCAs | 285/70/17 Maxxis Razr ATs
JeuTheIdit is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 10:43 PM #52
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
This, but jack the front up so the front tires are off the ground and perform the procedure with the engine off.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 11:16 PM #53
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I’m not sure if this is true but I’ve heard you need to leave the front wheels touching the ground a little to create resistance when winding the steering wheel lock to lock, otherwise the fluid won’t flow significantly from the res. This seems to correspond with my experience as well.
1000MPH is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 11:21 PM #54
DougR's Avatar
DougR's Avatar
My floor jack failed and I haven't replaced it yet. I'm wondering if I can easily turn the steering wheel if both front wheels are parked over plastic grocery bags on a smooth surface cement driveway. 4 layers of plastic film (two grocery bags) under each wheel might be slippery enough ... I think I'll try this tomorrow just to find out.
Old 12-21-2020, 11:40 PM #55
Dynamo's Avatar
Dynamo's Avatar
I haven't had a chance to do this on my 4Runner (it's a 2019) but I did it on my FJ Cruiser. I had the wheels all the way off the ground and the fluid pumped out easily and fairly quickly. I don't really see how creating resistance would make a difference other than making it harder to turn the steering wheel.
Just to be clear again, this procedure needs to be done with the engine off. If the engine is running it will pump out all of the fluid in a matter of seconds.
2019 TRD ORP
Old 12-21-2020, 11:42 PM #56
Dynamo's Avatar
Dynamo's Avatar
Maybe put a piece of cardboard on top of the bags so the tires don't just tear them up.
2019 TRD ORP
Old 12-22-2020, 05:03 PM #57
DougR's Avatar
DougR's Avatar
Plastic bags and cardboard works .... I can turn the steering wheel relatively easily. For cardboard, I used pieces of a USPS priority mail box because the corrugations are very small. I'm going to repeat the experiment using an Amazon large plastic shipping bag, which is coated and extra slippery when two layers are rubbed between the fingers. The smaller Amazon bags are less slippery (inside coating is darker).
Old 12-22-2020, 05:25 PM #58
CMTAZ CMTAZ is offline
CMTAZ will become famous soon enough
Originally Posted by a47chuck View Post
I've used Techron, but not for years....and just put something in the tank ... if you really feel you need it.
Occasional bottle of Techron, mostly since the pandemic. A tank of gas can last 6 - 8 weeks. Once every 4 -5 months I toss one in the 4runner and her Grand Cherokee when they are BOGO and O'Reillys.
2018 SR5 Premium - Eibach Pro Truck Lift Kit - TRD Wheels - Falken Wildpeak AT/3 - Tyger Armor Step Bars - Clear Bra - Kenwood DMX706s head unit - PowerBass 6.5" coaxial & 6x9" component speakers (tweeters replaced by JBL 3.5" coax) - Kenwood Excelon 5 Channel Amp - Pioneer 12" Shallow Mount Subwoofer - RAV4 Convex Mirrors - LED Headlights - Lexus LED Fog Lights (clones)
CMTAZ is offline   Reply With QuoteReply With Quote
engine , maintenance , top , video , wanted
engine block, how clean is clean enough? mendozer 3rd gen T4Rs 14 07-06-2023 12:26 PM
2002 4Runner SR5 Sport 4WD, Clean frame, Maintenance, Chicagoland Suburbs $5900 00_4runner For Sale: Vehicles 3 01-16-2018 09:40 PM
How (and where) to clean engine compartment? Ray Dunakin 5th gen T4Rs 12 08-27-2016 06:12 PM
SO what does everyone use to clean their engine? Footofgod Classic T4Rs 18 07-06-2013 09:21 AM
For Sale = 2004 SR5 4Runner 2WD, clean, Clean, CLEAN... w/ maintenance records... 4runDiZZLe Classifieds - buy & sell (no commercial ads please) 1 01-19-2010 03:53 AM
