Old 12-21-2020, 04:40 PM #16
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Originally Posted by BackOff View Post
I discovered if you cut the flange off the outside bushing sleeve you can press out the bushings easier... now that your done ...not much help.
That's what the FSM says to do.
delloro is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 06:15 PM #17
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Every thing i have seen says Toyota dont sell the lower ball joints or the bushings.
Did that change with the 5th gens?
Toyota says to replace entire lower control arm.
Not trying to argue, just what i have seen... i am sure i have not seen it all.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 11:11 PM #18
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Bushings have a part numbers, but the lbj comes pressed into the lca.
Originally Posted by RedSled View Post
Don’t know if this helps you or not.
Total Chaos makes a replacement LCA for Toyota 4Runners. I think they also make an extended travel, longer LCA that widens the front track. It's a more involved process to widen the track and involves other handling issues, according to posts I've read here by others who have done it.
TOTAL CHAOS FABRICATION
Long travel is a great option. Be prepared to spend about $6k on the front end alone to go full LT.
I rock the standard length O.G. boxed Total Chaos lca's. They've been solid for me, no complaints at all. Just be prepared that bushings and uniballs are comsumable parts which need to be replaced every 20k miles or so.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 12-22-2020, 12:58 PM #19
TheBlandRunner TheBlandRunner is offline
TheBlandRunner is on a distinguished road
I have these in my garage waiting for time to install. It did take a couple months to get them from Australia with Covid.
SUPER PRO LOWER CONTROL ARM PAIR | 2010+ TOYOTA FJ / 4RUNNER – NON KDSS | Apache Offroad
TheBlandRunner is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 11:33 AM #20
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
So, what is the advantage of these? I have a loud pop that I am pretty sure is the ball joint going. So, time to invest in some new parts (164,000 miles on OEM).
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 12:53 PM #21
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
Freedom Offroad just dropped a sneak peak on instagram they are offering a LCA. KDSS compatible. Not sure if they will provide additional caster or just be OEM measurements. No idea on price either.
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 03:43 PM #22
bayaz bayaz is offline
bayaz will become famous soon enough
Originally Posted by PK930 View Post
My lower BJs were shot and so were the bushings.
I replaced them with Dirt Kings and couldn't be happier. I got them for a good deal otherwise I would have just stuck with OEM.
If its really rusted and bad, just cut off the cam bolts to free arms for removal. Then get new cam bolts and use anti-seize.
Any chance you can elaborate? What makes DK lca’s better? Are you getting better articulation or clearance?
bayaz is offline   Reply With QuoteReply With Quote
arm , arms , control , lower , replacing
Auto Trans Shifter Bushing Replacement & Transfer Case Shifter Seat Replacement mtbtim 3rd gen T4Rs 17 09-14-2022 08:23 PM
Lower Ball Joint replacement or dust boot replacement help? dot_tom 5th gen T4Rs 7 01-11-2018 11:52 PM
xreas replacement - shock vs shock/spring replacement amheck 4th Gen T4Rs 21 11-14-2017 08:21 PM
3rd Gen 4runner Rear Coil Spring Replacement and Rear Shock Bushing Replacement mtbtim 3rd gen T4Rs 7 11-28-2016 11:43 AM
CV boot replacement vs entire joint replacement zerowkul98 Maintenance/Detailing 3 06-29-2010 06:30 PM
