Old 12-20-2020, 06:06 PM #1
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Toyota (dealer brand) battery leaking
Just replaced the dealer brand “Toyota” battery because there was a puddle on top growing yellow lead salt crystals on the terminals.
They claim that this “never happens” and modern batteries shouldn’t do this.
Off road, washboard use can cause this?
Either way I got a new battery for free and a cleaning of the terminals.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 06:30 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Dealer is right that modern batteries don't leak, but there are always exceptions.
Any battery may have some minor leakage around the posts. That is why it is best to put on the chemically treated felt washers available anywhere batteries are sold. Also a good idea to spray the terminals with terminal spray protector.
Off roading or rough roads will not cause this problem. There is no problem with taking your 4Runner anywhere it is capable of going.
fkheath is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 07:04 PM #3
Real Name: Sparky
Real Name: Sparky
I can tell you this was more than a minor leak, this was heavy enough that even after I cleaned the battery and terminals there was a puddle again on top in 2-3 weeks and the crystals regrew.
Haven’t seen something like this in the last 20 years.
Old and (c)rusty.
Old 12-20-2020, 09:28 PM #4
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
hahahaha that's total bullsh!t they are feeding, "modern" lead acid batteries are the same basic principle, newer materials, as the ones they made 100 years ago. If they can vent they can leak and they do. Just less likely if they are "sealed". I could say I have seen more leak than not leak.
AGM, Lithium ion/polymer, different yes, more modern, more different
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 09:50 PM #5
pianorocks06 pianorocks06 is offline
pianorocks06 is on a distinguished road
Agreed - unfortunately the terminal bushings which are molded into the cover can leak from excess physical stress/heat conditions. There is often only a thin coating on the terminals applied before molding to prevent leaks. Surprising to hear this about an OEM Panasonic unit though, they are typically excellent quality from the factory.
pianorocks06 is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 09:53 PM #6
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
If these "crystals" were sold as-is, do you think someone would smoke them?
This battery can be a money maker.
(I'm KIDDING)
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 11:13 PM #7
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
The battery in my FJ Cruiser leaked enough to eat away some of the metal underneath the plastic battery tray. I never saw it actually leaking, it always looked ok from up top. I had noticed a couple of spots on my garage floor that I thought was from rusty water but eventually realized was from leaking acid. The battery was a regular parts store battery, not the original Panasonic. I replaced it with an AGM battery from NAPA.
Anyway, something to check if you suspect your battery is leaking.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 01:54 PM #8
Real Name: Sparky
Real Name: Sparky
Not Panasonic, "Toyota" brand battery installed by CO dealership back in 2018.
Old and (c)rusty.
Old 12-21-2020, 02:16 PM #9
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I believe the True Start batteries are made by Johnson Controls. Same as Interstate batteries. All lead acid batteries sold in the US are made by Johnson Controls or East Penn. I have a NAPA battery made by East Penn.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 02:26 PM #10
Ah okay, I thought you meant the original factory battery. I believe the TrueStarts are from Johnson Controls (now Clarios) which I have seen leak in the past. Definitely would agree with others who recommend Costco for the quality Interstate batteries and for the warranty. I have used Interstate flooded products in all of my vehicles and only had one leak from the seal. No questions asked when I brought it back a year or so ago.
Old 12-21-2020, 02:38 PM #11
Real Name: Sparky
Real Name: Sparky
Yeah, that's why I put it in quotes. I'm not even sure if there are any obvious differences between the major battery brands in the US as they only come out of two factories if they're Lead Acid.
Old and (c)rusty.
Old 12-21-2020, 09:24 PM #12
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
Johnson Controls sold their battery business last year to Clarios.
This year Exide was sold to Stryten.
Wonder when East Penn will change hands.....
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 12-22-2020, 11:27 PM #13
East Penn has a great operation in PA - they have made significant advancements vertically in their supply chain which give them an advantage. They also make great products with their Intimidator private labels for NAPA and others. While its true that JCI sold their battery division, it was just named Clarios by the new investment group. Too many mistakes leading to poor quality products in a slow moving giant organization is the basic story for Clarios and Exide.
Old 12-23-2020, 12:18 AM #14
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
I have nothing good to say about the dealer-provided Tru Start batteries.
Maybe your luck has been better.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 12-23-2020, 12:41 AM #15
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
The battery posts are the weakest part of the battery case and any hairline fracture at this location will allow gases to escape. These gases attack the clamp and cable. I see this most often on my tractor battery but have also seen this on two of our four cars over the past decade.
Glad they replaced it at no charge.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
batteries , battery , brand , dealer , terminals
Dealer trying to tell me HG isn't leaking inglysh 4th Gen T4Rs 3 11-02-2020 06:22 PM
Oil leaking after dealer oil change whitetiger 5th gen T4Rs 39 08-09-2019 03:05 PM
Left Front Axle Leaking. Replace at dealer? Lolaya 4th Gen T4Rs 24 01-27-2019 07:27 PM
Leaking valve cover gasket and dealer response rra640 4th Gen T4Rs 5 04-02-2009 11:59 PM
Toyota Dealer Ad fees & Dealer Holdback Martin8 4th Gen T4Rs 11 04-06-2006 12:51 AM
