12-21-2020, 07:57 PM
Tire Rotation - How to Do it
There are several ways to do tire rotation with the Bridgestone Duelers on my 2020 SR5 Premium.
Tire Rotation: How and Why to Rotate Your Tires | Bridgestone Tires
https://www.tirerack.com/tires/tiret...&affiliate=HM5
None of them are what Toyota has in the manual. Even the two examples don't seem to match.
I used the X-Pattern since the biting front edges of the tread blocks are reversed on both the front and rears when the rotation is done.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
12-21-2020, 08:48 PM
Real Name: Sparky
Real Name: Sparky
I've been told that cross rotation can cause wandering behavior with more aggressive MTs and typical rule of thumb for anything but the gentlest street tires is swap front and back.
BTW side to side is of dubious use for performance cars, I've never had a Porsche dealer recommend it and those guys almost never turn down a chance to charge you for something.
Old and (c)rusty.
12-21-2020, 09:24 PM
I have a 2016 and do front to back only.
12-21-2020, 09:29 PM
I will see if there is wandering when I'm on the highway however that could be caused by many things.
The Dueler is not a unidirectional tire as are many spots car tires.
Sunroof
12-22-2020, 12:48 AM
1. Follow the owners manual. I always believe that the engineers at the factor that designed and built the 4Runner know best.
2. Since all new Toyotas sold in the US comes with free maintenance for two years, just let the dealer do it. The schedule for tire rotations is every 5,000 miles.
12-22-2020, 01:04 AM
Mine is 2 yrs. older, but I do the same. That's what a lot of tire shops do. Not saying it's the best, but i'ts likely better than leaving tires on the same wheel for their life on the vehicle.
Do whatever blows your skirt up.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
12-22-2020, 01:14 AM
With only 4 in rotation, I've always done the rearward cross regardless of drive wheels. Always tracked straight but then again never any super aggressive offroad tires either.
However on almost everything I've had since 1999 I have rotated 5; spare goes to right rear, rearward cross with left front going to spare.
Nice, even wear.
Between outfits.
12-22-2020, 12:49 PM
Most performance cars (Porsche) have different size tires on the front verses the back, thus the only way possible to rotate them, if you rotate them at all, is side to side.
12-22-2020, 12:54 PM
Real Name: Sparky
Real Name: Sparky
Correct, these are asymmetric, but not directional (Scorpions).
Either way, was told that side to side doesn't benefit anything.
Old and (c)rusty.
12-22-2020, 03:49 PM
Not unless you flip them on the rims, which you must do if they're unidirectional....
Between outfits.
12-22-2020, 05:27 PM
Real Name: Mark
Real Name: Mark
Since most of the time our 4Runners are operating in RWD mode, the "biting edges" of the rear tires are to the rear of the vehicle due to acceleration and the biting edges of the front tires are to the front since the greatest forces are from braking. The biting edge will get rounded as it wears and the opposite side of the block will be sharper due to less wear forces. On the rear tires, the rotational leading ("biting") edge of the tread blocks will be rounded and the trailing edge will be sharp. On the front tires the rotational trailing edge will be rounded with the leading edge sharper.
So, by using only the X pattern, you are basically continuing to wear the blocks on the same sides with the rounded biting edge continuing to get worn vs. the front to back rotation that would alternate the biting edges of the tread blocks on each rotation. The front to rear part of the forward/rearward cross rotation patterns compensates for the condition I described and the cross part of the rotation pattern compensates for side-to-side differences in wear causes.
How much difference it makes... who knows?
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
12-22-2020, 05:50 PM
The biting edge of the front tires is the front of the tread block (braking and steering) When in 4WD the rear of the block is the biting edge.
The biting edge of the rear tires is the rear of the tread block (acceleration)
Sunroof
12-22-2020, 05:59 PM
Real Name: Mark
Real Name: Mark
That's what I said but thanks for simplifying it. I get a bit too wordy sometimes. Regardless, using only the X rotation keeps the same edges getting worn whether on the front or rear. This is because you are turning what was the back of each rear tire to face forward when it goes to the opposite side front and vice versa for the fronts moving to the rears.
12-22-2020, 06:05 PM
I've always used the rearward cross.
That way each tire gets to ride in all corners before it returns to its original position.
This lets the tires recover from the front to back tire wear difference (middle of tire wear on rear and edge tire wear on front). Also, this lets each wheel ride in each corner with the different tendencies of each locations shocks, springs, etc.
Just my .02!
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
12-22-2020, 07:26 PM
I always do the rearward cross rotation pattern on my SUV's, which are all Full Time 4WD (AWD) drivelines, not that it makes a difference.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Tire rotation
trdsport253 |
5th gen T4Rs |
1 |
12-07-2015 08:40 AM |
Tire rotation
mbskoda |
5th gen T4Rs |
23 |
01-09-2012 05:03 PM |
tire rotation?
ciaz |
5th gen T4Rs |
1 |
01-29-2010 11:15 PM |
Tire rotation?
ARK_SWAMP_RIDER |
Engines / Suspension / Wheels / Tires / Audio / Accessories |
2 |
01-27-2010 12:55 PM |
Tire rotation
JAC |
4th Gen T4Rs |
3 |
07-23-2009 10:58 AM |
