12-23-2020, 04:31 PM
#31
I think the 6112 is a pretty good all around shock. My beef with Bilstein is WTF didn't they thread the body instead of the snap rings? That one change would have probably doubled the sales volume. It was the main reason I didn't buy them. Price is fair. Performance is pretty good. But the lack of adjustment was a deal breaker for me. And the cost would be almost nothing to do it. I don't understand Bilstein's logic.
I don't think the rear springs will make much difference. But it won't hurt to try it. They're primary task is to hold the weight up. The rest is done by the shocks. For off road performance you'll usually want the softest spring rate you can use and then dampen with shocks to maximize tire contact and body stability. Softer springs will provide more uniform weight distribution over uneven terrain and less body movement over obstacles at higher speeds, but end up with more body roll on off camber stuff in some situations. And of course softer springs don't work well for adding more weight or for highway use. It's all a bit of a balancing act unless you get super fancy with electronics that change behavior in different conditions.
12-23-2020, 04:52 PM
#32
Originally Posted by MAST4R
Good point. But he is the owner of Radflo, not a random guy who answers the phone. If he does not know, who would?
It is possible that what he thinks about is a narrow case of racing applications. That would be common for an expert in a given area.
He's literally just 2 minutes down the street from me (Glen). I'm eating lunch at the Panda express by Radflo lol
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
12-23-2020, 05:18 PM
#33
Real Name: Sparky
Real Name: Sparky
Actually, he talked me out of buying them so the opposite would be true here.
I misunderstood what you were saying, sorry.
Regardless, I researched the hell out of my second lift and that never came up as a pro or a con with the discussions I had with suspension gurus.
Old and (c)rusty.
#34
I was surprised, too, which is why I doubled checked he was talking shaft/rod sizes and not shock dm.
Otherwise, the Radflo 2.5 with no resi are pretty well priced at under 700 for the pair. But I am a big fan of max match between parts. And so wary of mis-matches.
Even if the shaft is okay that still creates a mismatch between front (stronger spring, softer shock) and rear (softer spring, stronger shock).
Bilstein are correct at marketing the 6112 as an adventure, not a performance shock. That's what it is. It can do everything for a long time with no unnecessary maintenance. With 650lb springs, it can go as fast as I care to go. But despite the 2.65 body it is not a powerful shock by any means. I guess resilient would be a better way to describe it. Or a great value proposition at the right price which is how I got it.
Anyway, I will give the B12 Bilstein rear spring a try. The ride is fine under most conditions anyway.
It is just that I want to see if I can do a little better. That's the fun part, no?
Who did you talk to at Radflo? Glenn, or the south African guy?
Dollars to doughnuts whoever it was intended to say piston rather than shaft. As others have said, the shaft has no impact on dampening, but the piston size absolutely does.
If you're that hard up for a set, I'm going to be pulling my Radflo ET 2.5" single tube coilovers and LT remote resi rears off in mid February. They'll have about 90k miles on them, but they just had new seals and fluid in July. Should be good more or less indefinitely provided you rebuild them every 30k or so.
Dm me if you're interested, we'll chat.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
12-23-2020, 05:19 PM
#35
Thanks for those comments, valuable input. The springs are 186 vs 203-204 so it may not be worth the hassle.
This is crazy, Glen, yes. Maybe you can ask him over some honey walnut shrimp!
Seriously, though, if you have a chance to ask, please do
Let's see if he tells you the same thing he told me
12-23-2020, 05:40 PM
#36
What are you replacing it with??
12-23-2020, 05:43 PM
#37
Custom length 2.5" remote resi Elkas front and rear. Eventually I plan to add a hydro bump stop to the rear as well.
12-23-2020, 05:52 PM
#38
Excellent choice! Can take it to the PMs but curious to what you're doing for the rears.
12-23-2020, 07:21 PM
#39
Same 2.5" remote Elkas with compression clickers, but they're doing a custom length for me to accommodate my LT springs (metaltech 104/300 lb/in) and adjustable 4 link setup.
12-23-2020, 08:05 PM
#40
Alright, last off topic post I promise. Planning out a rear LT eventually and curious to what everyone else is doing. You going with a 2 or 3 inch bump stop extension? One fella I was talking to spoke highly of the 2in (27.5 extended) versus the 3in as it would bottom out less frequently. Thoughts?
12-23-2020, 09:25 PM
#41
These are what I run .
I don't see the wisdom in running a shorter bump stop because in that case, the shock is going to take all the force of a bottom out as it reaches the end of its stroke under hard compression rather than the bump stop. So I guess it's a question of whether you want to take a hard hit on your cheap rubber bump stop, or your expensive LT shock.
And in terms of shock length, you want to match your shocks to your springs. There would be no concerns with bottoming out the shock with a proper height bump stop provided you have a legit LT spring. If you find you hit the bump stop too often, you could 1) put stiffer valving in, 2) carry less weight, or 3) get hydraulic bump stops.
01-11-2021, 07:06 PM
#42
Huh? Why would different diameter shock shafts front and rear make any difference at all?
It's perfectly fine to run a larger rear shock than front. .
Originally Posted by LandCruiser
People who want to sell you something will say all sorts of things.
Accutune confirmed that a larger shaft in the rear than in the front is not ideal but, unlike, Radflo, said it is not a show stopper providing correct tuning.
And what happened to Jetboy?
