Old 12-29-2020, 12:20 AM #31
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Pro-Jay- I believe there are threads dealing with the ABS wire. Others have damaged theirs and I think they posted the part #'s and sources for replacement. I don't think it's all that expensive for a DIY repair. A quick search should get you there.
Old 12-29-2020, 12:04 PM #32
Po-Jay's Avatar
Po-Jay Po-Jay is offline
Po-Jay is on a distinguished road
Po-Jay's Avatar
Originally Posted by Drobs View Post
Figure that Pre-collision system is ABS related.
Hopefully not too expensive of a fix.
It will be fixed tomorrow. Outside of a ton of my time spent chasing the Radar Calibration with Toyota and aftermarket companies, there is no cost thus far. The shop that installed my lift is ordering the part and fixing the cable, at no cost to me. I literally checked this forum 30-minutes prior to my appointment at Toyota. I really thank you for the response. It potentially saved me several hundred dollars.
I will post again once the cable is fixed. Thanks all!
2020 Barcelona Red 4Runner SR5 Premium
2019 VW Cliff Green Golf R Spektrum Edition - DSG
Po-Jay is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 02:20 PM #33
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
You're welcome.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 03:01 PM #34
flyrv9's Avatar
flyrv9's Avatar
Pro-Jay you might want to check the other wheels for taught or damaged ABS wires as well; if you haven't already.
Old 12-29-2020, 03:34 PM #35
Po-Jay's Avatar
Po-Jay's Avatar
The only one that seemed to be damaged was the drivers front. I think the asshat that worked on it, learned pretty quickly, but decided to NOT say anything... Thanks!
Old 12-29-2020, 03:42 PM #36
Po-Jay's Avatar
Po-Jay's Avatar
Originally Posted by RichinRidgewood View Post
You're welcome.
See, now that is funny.
Old 12-29-2020, 04:34 PM #37
My fans are the greatest fans in the world !
I love each and every one of you !
Rock on
@blutarski
@usdmej
@Jetboy
@Po-Jay
@BlueEyedDevil
Sunroof
Old 12-31-2020, 10:39 AM #38
Po-Jay's Avatar
Po-Jay's Avatar
Well, the issue is fixed. The ABS wire was the problem. I appreciate the help with this.
That wire is really easy to screw up, doing suspension work. I would be willing to bet that it is the issue for most of these problems.
Old 03-05-2021, 09:55 AM #39
Da Runna Da Runna is offline
Da Runna is on a distinguished road
I currently have the same problem but didn’t pop up until alignment was done. Shop said they had to zero the steering angle through OBD. That’s when problem started. Drove with front 1” spacers on then full lift for a while before alignment done (several hundred miles).
Deciding on whether to install factory suspension before dealer visit or not.
Da Runna is offline   Reply With QuoteReply With Quote
Old 10-14-2022, 06:06 PM #40
aneel819 aneel819 is offline
aneel819 is on a distinguished road
Been doing a lot of research finally found this thread and I'm currently dealing with the same issue!
I have a traction light and front radar collision light on. I have been to shops and finally the Toyota dealership. They installed a new radar sensor in the front and came back with some excuse as to why they couldn't calibrate. Nobody has been able to figure it out. Spent close to $1500 so far chasing the issue. Now, I believe my issue is the ABS wire as well because the last shop told me it keeps throwing ABS codes which is why the front radar sensor won't calibrate.
My vehicle was hit on the driver's side and I had to replace a driver control arm, the driver fender and headlight.
My question is which ABS wire did you have to replace to resolve the issue?
aneel819 is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 12:12 PM #41
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
The one that's ripped/crimped/torn?
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 02:50 PM #42
fpainter fpainter is offline
fpainter is on a distinguished road
I bought a set of Bilstein 5100 shocks , and I have been looking to either put it on second position (0.87" lift), or the third position (1.74" lift) . I was worried about the adaptive cruise, etc. as it will change the rake. I am not going to a larger tire, just want the extra ground clearance in the front. With RCI and TRD skids it is only 8". It looks like the 1.74 would make it level. Please give me some feedback as to which you would recommend.
Thanks
fpainter is offline   Reply With QuoteReply With Quote
control , front , leveling , malfunction , radar
Rocker Panel Rust and Related Issues WrenchTech 3rd gen T4Rs 30 06-06-2021 02:37 PM
Front Facing Camera Suggestions Please WanderlostOverland 5th gen T4Rs 11 10-28-2019 11:59 AM
Beatsonic Front facing camera barcainho Off Topic 7 02-05-2018 09:21 PM
AC Switch related Issues? Captain Obvious 4th Gen T4Rs 2 07-31-2015 01:42 PM
Legal issues with rear-facing lights ...? jdkilroy General Discussions 24 02-09-2015 10:34 PM
