Thread Tools Rating: Thread Rating: 4 votes, 2.50 average. Display Modes
Old 12-01-2015, 07:12 PM #1
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
Question Roof Rack Idea - Crossbars ONLY/No Rails
I feel like I've asked this before, but didn't get many responses (if any), and my research has yielded zilch...
When people replace their roof rails with a roof rack (Gobi, Frontrunner...) those typically mount directly into the stock roof mounts for the rails.
My question is this: Does anyone know of the proper base or system (such as Yakima or Thule) that will mount directly into the stock roof mount locations for only the crossbars? I'm not needing a full roof rack, and anything I would carry up top would be long enough to contact both cross bars, and I don't need the adjustability to slide the crossbars back-and-forth.
Anyone know?
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 12-01-2015, 07:25 PM #2
ST1FLER ST1FLER is offline
Banned
ST1FLER is on a distinguished road
Banned
rockyroad outfitters
ST1FLER is offline   Reply With QuoteReply With Quote
Old 12-03-2015, 08:34 PM #3
mbumpus11's Avatar
Real Name: Bump
mbumpus11's Avatar
Real Name: Bump
Is your comment meaning to direct me to their website, or to call them and do a custom job because there is nothing that I can find on their website pertaining to my question?
Old 12-03-2015, 09:07 PM #4
Banned
Banned
Old 12-03-2015, 10:36 PM #5
3wbdriver's Avatar
3wbdriver 3wbdriver is offline
Real Name: CJ
3wbdriver will become famous soon enough
3wbdriver's Avatar
Real Name: CJ
I think he wants to completely remove the rails and replace them with 2 crossbars that attach at the factory points.
@mbumpus11 , you could just get a set of Baja Rack, Gobi, etc bases, and have a local metal shop fab you up a pair of crossbars to attach on those. Might not be as pretty, but should be fully functional.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
3wbdriver is offline   Reply With QuoteReply With Quote
Old 12-03-2015, 11:29 PM #6
Jdavera Jdavera is offline
Jdavera is on a distinguished road
http://www.rocky-road.com/5th-gen-4r...roof-rack.html
Jdavera is offline   Reply With QuoteReply With Quote
Old 12-03-2015, 11:32 PM #7
mbumpus11's Avatar
Real Name: Bump
mbumpus11's Avatar
Real Name: Bump
You've got the idea! I hadn't thought about just ordering rack bases by themselves. Will look into that. I'm sure I could also call Yakima and Thule to see if they have any ideas.
Old 12-04-2015, 03:05 AM #8
mace.'s Avatar
mace. mace. is offline
mace. is on a distinguished road
mace.'s Avatar
Thule and Yakima definitely have solutions for a fixed mount rack or adding a low profile t-channel. As long as your cool with drilling into the roof you should be able to find something.
mace. is offline   Reply With QuoteReply With Quote
Old 12-04-2015, 08:43 AM #9
Lugboot's Avatar
Lugboot Lugboot is offline
Real Name: Brett
Lugboot is on a distinguished road
Lugboot's Avatar
Real Name: Brett
Yakima does not make a base that bolts directly into the existing factory rack mounting points. Unfortunately.
Is: 2015 Trail, with some stuff bolted on.
Was: 1995 80 Series, built. Rest In Rust...
Lugboot is offline   Reply With QuoteReply With Quote
Old 12-04-2015, 09:05 AM #10
sandcrawler's Avatar
sandcrawler sandcrawler is offline
sandcrawler has a spectacular aura about sandcrawler has a spectacular aura about
nor Thule. both companies' stance is that all 4Runner trim levels come with an OEM roof rack, so they won't develop aftermarket options for it.
like @mace. said, they do provide a track kit, but that requires you to drill into the roof. that can be sketchy, and i'd only want to do it as a last resort. suggestions above to get Gobi or Baja rack bases sound solid to me.
i removed my factory rack years ago, and did a roll-your-own Thule rack using podium towers (door jamb mount) and half a Tundra, half a Taco fit kit. it works well for my needs, which are fairly lightweight. i wouldn't trust it with an exceptional amount of weight up there.
your custom direction utilizing the factory roof mounts seems like a good way to go. good luck!
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
sandcrawler is offline   Reply With QuoteReply With Quote
Old 12-04-2015, 07:20 PM #11
AZrunner11's Avatar
AZrunner11 AZrunner11 is offline
Real Name: John
AZrunner11 is on a distinguished road
AZrunner11's Avatar
Real Name: John
Hefty Fabworks
When I was talking to Chris at the FJ Summit about roof racks and rooftop tents, he mentioned he could fabricate crossbars for me to be the width of the factory rails. I'm not sure how they would mount as it seems like the mounting point of the factory crossbars are the weak point.
However, RockyRoad's product appears to be a viable alternative to a Gobi or like roof rack.
2012 T4R Trail Edition Magnetic Gray~KDSS~Cooper STT Pro 285/70R17•Pilot stubby•3M Door Guards•WeatherTechs•Console Vault•Canvasback Liner•Interior LED upgrade•BudBuilt BumpOut Sliders and full skids•ICON Extended Travel suspension•Rokmen lower links•ARB•Warn M8000•Southeast Overland rope~CBI rear bumper
AZrunner11 is offline   Reply With QuoteReply With Quote
Old 12-08-2015, 01:32 AM #12
p_j_o's Avatar
p_j_o p_j_o is offline
p_j_o is on a distinguished road
p_j_o's Avatar
Lightbulb
Funny that you bring this up mbumpus11. I have been thinking the same thing for the last little bit, mainly because all the Gobi, Baja, etc cost WAY too much to ship to Canada and it would probably be easier to get one manufactured local...
That being said, what I was thinking - and you might like this idea too - is using the parts in the Rack delete thread temporarily remove the towers and use them to have new ones fabricated to your own shape/desire/accommodation/etc.
That might be a good way to have a "2 post + crossbar" customized rack
pjo
p_j_o is offline   Reply With QuoteReply With Quote
Old 12-08-2015, 09:12 AM #13
Lugboot's Avatar
Real Name: Brett
Lugboot's Avatar
Real Name: Brett
pjo
Something like this crossed my mind, too (no pun intended)...but the thought was to look at the Yakima or Thule tower you want and see if there is a way to modify or fab a baseplate for the towers to mount to, that would then bolt to the factory holes.
Example--Yakima Control Towers:
Get the Control Towers and then figure out what Landing Pad would work...fab an adapter plate out of a piece of stock that can bolt to the factory holes and then the Landing Pad can bolt to in turn...mount the Control Tower to your modded Landing Pad interface.
https://www.yakima.com/control-tower
https://assets.yakima.com/product/instructions/8000214
Old 12-08-2015, 04:18 PM #14
bartvonwolf bartvonwolf is offline
Real Name: Bart
bartvonwolf is on a distinguished road
Real Name: Bart
I have a similar idea but I want to utilize the full length of my roof to accommodate a James Baroud Evasion Evo hard shell roof top tent. For this, I don't really need a basket of any kind, just four stout bars to bolt the tent to.
So, does anyone know if anywhere sells simply towers that bolt right up to the factory roof rack mounting holes? I may end up fabbing my own if it seems like the logical option.
Bart
bartvonwolf is offline   Reply With QuoteReply With Quote
Old 12-08-2015, 04:23 PM #15
mace.'s Avatar
mace.'s Avatar
Bart
Obviously you didn't read thread.
5th GEN OEM Roof Rails and Crossbars, $250 Bay Area, CA jpags13 For Sale: T4R Items 2 11-03-2016 02:19 PM
FS: 5th Gen Trail Roof Rails & Crossbars - Shelton, CT - $200 Adnasty For Sale: T4R Items 6 09-17-2015 03:35 PM
5th gen roof rails + crossbars pre 2013 sr5 blizz86 For Sale: T4R Items 2 09-05-2015 12:16 AM
FS: '99 Roof Rack Crossbars DirtDawg For Sale: T4R Items 0 06-17-2012 06:32 PM
5th gen roof rack crossbars Davemon For Sale: T4R Items 3 01-18-2012 06:32 PM
